pfalvi
40 -
Reputation
13 GoodPersonal Information
Occupation
Lighting Designer/Master Electrician
Location
United States
Recent Profile Visitors
2024 Projector Tool NDI Stream in Vision
pfalvi replied to pfalvi's topic in Vision and Previsualization
And I think I just found the answer. Does Vision Plus only allow one NDI stream? -
Months later I've finally had time to test it in a way I felt like I actually figured some things out. @bbudzonYou were absolutely right on the NDI quality setup, that gave me a very crisp and clean image like I wanted. I still am having inconsistencies with using two NDI streams. I can consistently make one stream work, or one NDI stream and a webcam, but two NDI streams mostly did not work for me. I tried multiple computers, multiple sources, changing the names, everything I could think of. In maybe twenty tests, I made two individual streams work once. When I put a second stream in, the second one goes black, even though when I'm assigning the stream it shows an accurate, live preview of what it's seeing on the NDI stream. Thanks! -
Schematic Views Data Viz (Spotlight)
pfalvi replied to pfalvi's question in Wishlist - Feature and Content Requests
After a chat with VW, turns out you can do this, it just doesn't seem straightforward to me. Turns out you have to include "__NNA^1 In Schematic View" in your criteria: And then it works. I think it should still be more straightforward, but there is a built in way to do it that's not quite a workaround. -
This is largely a request from someone I work with: He'd like the ability to move a lighting accessory from one unit to another, so that all of it's OIP info can stay with it (channel, address, etc). He's a Master Electrician of a space, and it would save him some significant time when he has to shuffle things around the plot. Anybody else feel like this would be useful?
pfalvi posted a question in Wishlist - Feature and Content Requests
I'd love to be able to make lighting devices in Schematic Views take my data viz info, so that my 2D draftings can show my data viz across the entire plot. Right now if I use schematic views, there's no way to use data viz (that I can find) to specify things (i.e. I use Data Viz to show which lights are rentals, part of the rep plot, adds, etc.), while the rest of the plot can show that info well.- 1 reply
- 1
Data Viz with Spotlight Accessories
I'd love to see Data Viz have the capability to change the visualization of accessories, both with the lighting devices they're attached to and independently. When I want to show differences in accessories (What universe they're in, what Gel Scroll they have (yes, I know that's an ancient use case), etc, it would be great to have a set of Data Viz options set up for that. Currently I think they only take the Data Viz from the lighting device they're attached to. Happy to explain more if that's not clear! Thanks. -
Thanks for your response! I did note to make sure that there are two different named streams, in both the Isadora output and the Video Source Inputs, but there’s a world where that bounced around as I was figuring it out. I’ll check back on that in the next couple of days. I’ll look around vision preferences for this. I have seen the content on a separate monitor, and it isn’t as fuzzy as in Vision. -
Two issues: 1- it looks like I can only use one NDI stream into vision projectors, even if I have two active streams on the network. I can select the second one, but it doesn’t seem to let me output the second. Maybe a limit to only one active allowed somewhere? (for clarity, I have two projectors, projector A is looking at a stream from stage 1 of Isadora, and projector B is looking at a stream from Stage 2 of Isadora. Both show content when I select the preview of them, but content only comes out of projector A when in the scene. Running a M2 Mac Mini and Vision 2024) 2- the ‘High Bandwidth’ version doesn’t seem to give me an increased resolution out of the projector, it seems to stay the same as the low bandwidth, content wise. This might be an issue somewhere else down the line, but I believe I have my settings set correctly. Thanks for any help!
VWX <> Vision XYZ Axis Consistency
pfalvi replied to allannathan's question in Wishlist - Feature and Content Requests
I’m a little shocked that this is still an issue. Consistency from VW to Vision would likely make it a usable program for me. -
Thanks so much, Pat! That got it working the way I expected. I'll keep digging and asking questions as they come up!
Hey Pat, Thanks for your response! My code now looks like this: PROCEDURE InsertMSArrow; {Inserts an specified Symbol arrow and adds a User Definable Text Field} VAR X1, Y1, X2, Y2 :Real; BEGIN GetPt(X1,Y1); {gets point from mouse click} Symbol('JMC MS Arrow', X1, Y1, 0); GetPt(X2,Y2); {gets point from mouse click} MoveTo(X2,Y2); CreateText(pTextData); End; Run(InsertMSArrow); But the object shows me the attached when inserted. I'm not seeing a field in the OIP for the TextData, and they appear to be two separate objects. Any thoughts?
Hey Raymond, Thanks for this! I’ve done it that way before, but my long term goal is to make a script based PIO to make the text be read normally no matter how the object is rotated. I think I found the code to make the rotation happen, but (I think) I’d need it to be built into an PIO object first. I’m also hoping to eventually be able to control the color of the geometry inside the object on a per instance basis, which I don’t think I can do as a symbol. Thanks!
Hi there! I'm slowly digging into this all, trying to do some basic things before I go for more complicated scripting to make sure I understand how it works. Right now I'm trying to insert a symbol and a text field into the drawing, and let the text field be adjustable in the OIP. So far what I'm seeing is that it will draw the symbol and text field as two separate objects (symbol and text field respectively), where I'd like to have them be one object together. Below is the code I'm using- it's a Point object so far. PROCEDURE InsertMSArrow; {Inserts an specified Symbol arrow and adds a User Definable Text Field} VAR X1, Y1, X2, Y2 :Real; textData :String; BEGIN GetPt(X1,Y1); {gets point from mouse click} Symbol('JMC MS Arrow', X1, Y1, 0); GetPt(X2,Y2); {gets point from mouse click} MoveTo(X2,Y2); CreateText(pTextData); End; Run(InsertMSArrow); What can I do to make this function properly? I'm sure I'm missing something pretty basic. (Eventually, I'd love to be able to click once, and then click to set the rotation of the object together, if that matters for advice!) Thanks! I'm hoping once I get past some of this stuff, I can hit the ground running!
Hey Pat, This is incredible, thank you so much! Let me dig into it and digest, then I'll come up with better and more specific questions to ask to get what I'm looking for. I appreciate it!
I’m thinking VectorScript, and trying to make a plug in that would insert a symbol or geometry (still deciding) and some text. Trying to make a couple of colors definable in the OIP as well as have the text rotate in a specific way and be definable as well. I’ve been interested in this stuff for a while, and this came up as seemingly a good way to dip my toes in. Thanks Pat!
