cbaarch
    173
Posts posted by cbaarch
  1. I like Jonathan's solution but this also works
    go to the file 1 which is were you want your classes from
    turn on the classes that you want to bring over to the new file
    (this only works if there are objects in the classes)
    either create 1 object per class or
    select all (classes is set to Snap/show/modify)
    group the object(which should be on the none class)
    copy and paste in file 2
    in file 2 ungroup
    (dialog comes up asking if you want to ungroup wiht classes info)
    say yes
    then delete the objects you pasted
    the classes are now in the new file
    close File 1 without saving
  2. A method I use to find the missing viewports
    go to Viewports under navigation palette
    double click on a name
    the sheet is resides on will be active and the handles will show
    check the class in the OI palette
    and change it to NONE
    repeat for each viewport
    since None class is most likely to always be on
    (while there edit the name so you know what VP1 etc. is for)
  3. This applies to mostly 2D working drawings:
    Do as much work as posible in the design layer
    this will pay off if you do a lot of exporting to dwg for the consultants.
    title blocks on sheets at 1:1
    drawing labels as annotations since it picks up the scale of the VP
    annotations and some dimensions when doing larger scale details OK since the engineering consultants rarely need those details
  4. We create a whole apartment(building) plans with different classes and then create a symbol.
    we then turn classes on and off depending on what we want
    to show in the VP i.e furniture, text, wall types, door types or ID etc...
    the symbol is usually resides on the None Class but the object inside the symbols has many classes
    that method has been around since forever
  5. And make sure that if you are doing all this "EXTRA" learning
    that you get Extra pay for all your efforts.
    If you think that you will be doing it all at the same old rates just tell your clients that you will need an engineer to get all those calculations done then add a processing fee to get the engineer and you win.
  6. the technical font is probably "locked" especially if it is one by Corel
    in acrobat after creating the pdf
    select the T (touch up text tool)and select a text block that has technical then right click and select attributes
    in the dialog box you then check "embed".
    this needs to be repeat only once if you create a book
    but needs repeated with new files
    this is a site for a non-Corel technical font
    http://www.webpagepublicity.com/free-fonts-t.html#Free%20Fonts
    or
    you can try Font mapping in VW
    and delete any references to technical or mapping to technical.
  7. you can find the tool(s) using workspace editor
    you can edit your workspace any which way you want with the editor.
    you can also create toolboxes for third party plug-ins that you can find in places like vectordepot.
  8. they are in
    C:\Program Files\VectorWorks 12.5\Libraries\Objects-Imperial
    if you have VW architect 12.5
    the above is for winxp version
    should be the same folder for Mac
  9. we tried using
    acad drawings done by other to make revisions and enhance the acad files
    at the end of the day we used VW walls and tools to draw over the acad plans and elevations and abandoned the acad file altogether
    it took very little time compared to try and modify a mixed acad/vw drawing later in the process
  10. Just draw a rectangle or polygon around the area of the saved view
    leave the rectangle selected
    create a viewport
    the object(s) in the view should be in the VP created
    if you have the rectangle set to NONE and NONE fill
    it will not show in the VP
    and to edit you select all to see the object used for the crop.
  11. symbols reside in 2 places
    the first is found in libaries
    these are the common symbols/plug-in that can be reused
    they can be added as favorites to the resource browser for easy access
    the second instance they reside in the current drawing(s)
    a symbol can be created in a current drawing
    but should be copied to a library if it will be used often
    changing a symbol in a drawing does not change the symbol in another file
    to do that, you have to open the 2 files
    and then go to the resource browser at the aboslute top of the list you will find the 2 drawings
    you then select the symbol(s) and "replace" them
    we have 1000 of files I would not want have my symbols changed in all our files if I change only 1
    you should duplicate the symbols if you want to make changes
    that way you will not make the mistake of changing symbols that are not meant to be changed
    if you want the same info in 2 files you need to learn WGR - Workgroup reference
  12. It is easy to get metric to stick
    the drawing that opens when VW starts is based on the Default drawings
    all the properties that are set in that drawing will be used when VW starts or you create a new drawing using Default
    after customizing the Default file you save it as a template
    replacing the Default.sta in the Templates folder.
  13. if you learn the VP on sheets you will find it a lot easier
    not much to it.
    create a view of what you want on your sheet
    draw a rectangle around the area (none fill, none line)
    leaving the rectangle selected
    create a VP
    in the dialog
    when you go to sheet you are allowed to create a sheet here
    (if you have not created a sheet before
    the VP will then be on the sheet
    you can scale it to fit the page
    (pages are setup in edit in sheet properties)
    you then insert you title block on the sheet which is already 1:1
    you can get the scale of the view using drawing bubble tool
    in the annotation mode.
    worth the effort to learn
    we use it for every type of work
    from 1 sheet to 20 sheets
