173 -
Posts posted by cbaarch
the first thing I do on any new install
is turn off snap to grid,
I either want to snap to a real dimension
or to an object in the drawing
this applies to an architectural drawing.
and the grid is almost never where I want to be.
you can have your areas as formulas in the worksheet
first you draw a polygon for each room etc..
then in the DATA field found in OI palette (top box)
you give it a specific name such as (E)office etc...
then in the worksheet cell you insert
=AREA((N='xxxxx'))/144 xxxx=name of polygon
the 144 is to get sq.ft.
use CRITERIAAREA instead of AREA if you go back and forth to metric.
you have to recalcute the worksheet after you make changes
it is not automatic
move it over manually rather than healing/snapping
in the VW Help
search for Undo gives:
"....Select Issue undo warnings to open a warning dialog box when attempting to undo an action that cannot be undone....."
so there are items that can not be undone
select Drawing Label after inserting in the drawing
go to the OI palette you manually change the "Sheet: _____"
and
you should create viewports for printing
and insert the drawings label as annotations in the VP
that way you always get the correct scale since it changes with the scale of the VP
If the model of the condos are slightly complex
you may want to create them in separate files and use WGR (workgroup reference) to bring them in to the site plan.
then once they are WGR; you create a layer link as per Robert's response
report already submitted with B059316
Is NNA going to offer a fix to the problem of quicktime 7.1.6
not allowing the program to start
or instructions on how to backtrack Quicktime to version 7.1.3
we use Ichat/AOL as a file sharing program
you can create multiple accounts and restrict access
not saving cache of for VP keeps files dowm when working with offsite personel
zipping files is also recommended.
www.yousendit.com; paid subscription also works well to send to consultants.
but in our experience we do not have any engineers
that use VW so an exported acad file (with only the info required by the engineers) are usually small
Quicktime 7.1.6 is the problem
install on second computer that had 7.1.3 and it worked
You do not have to rerender or update the VP's if you have not made any changes to the drawing
you get the red outline of the VP on the screen; but printing is not affected.
I have one file that I use to show clients that has 2 sheets
that will reopen to the view without a rerender and switches to sheet 2 without a rerender
vw12.5 designer ; winxp pro
www.fypon.com
for polyurethane foam
look at the advanced properties of the VP
you scale text ..... in this dialog
My Computer
Tools
File types
find mcd (extensions)
delete it
next time you open a file it will ask if you want to associate
an unwritten rule of using sheets
never used the Move Page tool
move the viewports to fit the sheets
to regain the origin
go to organisation palette or navigation palette
and edit the sheet
Origin needs to be x=0 y=0
forgot to mention
you have to unlock you LL first to move it.
you create a layer link for the workgroup referenced layers that you bring in
in 12.5.1
there is a query if you want to LL when you firt create the WGR
at the bottom of the dialog box
then you can locate/rotate/flip the layer link
which will get updated when wgr is updated.
we have our title block on the sheet layer at 1:1
then only 1 tb is required for each type we use.
we then use annotation for the detail/plan title
because it then uses the scale of the VP
and you do not have to manually change it every time
we have sheets set up for the printer we are using
never multiple pages per sheet
that was our "old" way of doing things before sheets and vp
where implemented.
The concept is that a sheet is always actual size that you would send to the printer, the VPs are scaled
if you want to send an Arch D size drawings to a smaller size sheet on a selected printer you scale in the printer properties dialog box (Ctrt-Alt-P)
Instead of importing the symbols or folders
and increasing your file size
you should go to "add favorite files" to your resource browser
you then have access to all the symbols from the RB
they then only get saved in the file when they get used
that is what libaries are for.
you can also create folders in the resourece browser
so you do not have to scroll the long lists
If you have a lot of rendered views
turn off cache viewports
and
save views with only the items needed when working on parts of the project
This looks like a good candidate for WGR (workgroup referencing)
with a careful management of layers and classes
Use full screen cursor
and nudge VPs in place
the object your are aligning will change colour
Cross Platform Print Layout
in General Discussion
Posted
the problem usually is GIGO and not much to do with platform,
the sheet layers once learned are "magic"
they are so fundamental to the printing process
that someone should teach the non converts the errors of their ways
