173 -
Posts posted by cbaarch
dougd
one glossary term in the software business that you need to learn is "early implementer"
it applies to geeks that have to beta test and/or be the first to try/use software right out of the gate
as with any software, early versions are always buggy (nature of the business)
if you can not deal with the process of reporting bugs, then maybe sit back; relax and wait for later releases.
expecting that version x.0.0 of any software to be perfect is nothing but a pipe dream
viewports = paper space
has version 11 objects in the Old Link section
http://www.vectordepot.com/Symbols1.shtml
in the classes and layers
you have the options of show/snap/modify others
you can select anything with this option
and the class and layer show up in the OI palette
use the Navigation Palette to easily access the options
it turns out that Intellipoint 6.0 is the culprit
so check which version your mouse driver is running
if it 6.0
2 methods for a fix
if you have intellipoint 5.0 then delete installation of version 6 and reinstall 5.0
otherwise you can do the following
Ctlr-alt-del opens task manager
select Process tab and find ipoint.exe
end the process
for a permanent disable during reboot
you need to run msconfig (under Start button)
under startup tab find intellipoint and deselect
this has worked on 3 computers with intellipoint 6.0 and it fixed the problem
cbaarch does have an architectural practice and much more than basic knowledge when it comes to VW
we have been very productive in VW in short order but we have not fully used the full capabilities of the software because it does not work with our work flow methodology.
so stating again,VW has very good and very extensive sets of tools that can be used for single practioners to large groups of users. To get the most dollar value from the program training is essential just like any other software.
and as for the slashes in a window that is so a handdrafting method (I have direct knowledge having hand drafted for 10 years) you need to find new methodology to show windows - the designers prefer gradients/renderings whereas the techies prefer patterns/hatches.
as for glazing not showing up on a job site; obviously nobody specified the glazing with such information as clear or tinted (what percent) or mirrored with info on which side of the lite the mirror needs to be on and if it is single or double glazed with or without argon gas with/without low E coating
dashes on a window in an elevation gives nothing about the latter or if the lite is a spandrel panel with a whole new set of specs such as tempered or laminated, the insulation value with a full galvanozed pan or a foil backing...................we do window types for such and exercise and then reference the windows to a specifications manual.
AND
shop drawings were obviously not submitted to the architect/designer for review and approval before the order was placed if glazing was missing. Needless to say the line of communication was broken between the contractor and the architect
cheers
Conrad
I find it really intesting that VW gets dimissed as not being able to do a feature when "grenmeadow and we" do not seem to have spent a lot of time to learn how do what the advertised features are capable of doing
there is also no mention in greenmeadows' posting of where he is coming from and, what they consider to be traditional drafting convention (maybe autocad???)
if greenmeadows and his band had looked into some training they would have found out that in VW:
drawing is mostly done on a design layer at a predetermined scale in a first file;
that information can then be layed out for printing on a sheet (always 1:1 scale) using viewports (which can be scaled and controlled via layers and classes and other such as view)
a second file can then be referenced into the first file using
WGR - (workgroup references) and can be inserted in a sheets or new sheet in the same file.
the VP's can also be annotated using the annotations feature of a VP - the VP can be scaled and the Advanced properties can control line weights etc.. useful when doing detailed drawings.
and WGR can be linked via LayerLink to create a drawing from multiple sources
so do not dismiss VW until you learn all the features that usually gets you where you need to be in the world of CAD.
VW is a program rich with features that takes years to learn if you want to learn it all. even after 10 years - I learned a feature of a tool which I had not yet fully explored.
so if you have specific details about somethigng you tried
we may try and help - but if you are only going to complain about generalities you will be on your own and you will have wasted your money on VW
my 2 cents
We use the following:
a1.x series for site plan and zoning building info
a2.x series for floor plans
a3.x for elevations
a4.x for building sections and and details
a5.x for assemblies and schedules
a6.x for interior elevations
for batch printing to pdf on winxp paltform
we then use 11 21 etc
and then make a book using acrobat (we have version8)
we do a layout of all the sheets we will need before we start our working drawings.
this system is really good when you did not produce the drawings
and you want to find info when talking to contractors
From another perspective:
I am working on fixing a set of working drawings that were started by a draftman by hand. Yes there are still people out there doing hand drawings.
There is a market for a good 2D cad program; which in our case makes us quite a good income. We seldom use 3D; but we push the limits of presentation using all the 2D CAD tools available in VW
to dimiss 2D CAD and conclude that it is on the way out is only 1 opinion that is not shared by this user.
So for NNA to spend time improving 2D tools is a market that for the time being will, more likely than not, sell new seats and upgrades.
I started a new project today with an existing vw12 - working in 2D
Since I want to keep the class and layer structure
I deleted all previous info and purged everything other than classes and layers
I started with a footings and foundations using
styled wall; call out tool; text; gridlines; created groups and symbols
I then duplicated some info for the main floor plan
and THEN I inserted a window from the windows tool
as soom as the window was inserted the flickering started and has became really annoying as windows and doors where added
so the PIO seems to be the culprit
winxppro - 2 LCD monitors on ASUS Nivia GeForce 5400
Windows XP is still available even though Vista is out
and I usually pick up older releases of software I know I will have limited use of from retailers that still have them on the shelf.
and
there is the option of creating your own :-(
this is standard VW behaviour
you will need to adapt if you want to use the program
and if you use the CTRL to zoom in/out you will always have to be aware that you may get a copy
I also could not find a palm tree in a limited search of xfrog
but we have used image props as a work around
image props folder does have Palm trees
the residential furniture is located in
C:\Program Files\VectorWorks 12.0.0\Libraries\Object Sampler\VectorWorks Basic
if you are windows version
should be similar location for Mac
to get a 24x36 sheet on 11x17
we use 38% (37.5% rounded up)
with imperial scales you then
get 3/32 and 3/64 etc... which are found on a stand ruler
so that marking up a check set you can scale to something real
try using the wall tool for simple elevations of cabinets
then you can join heal etc....
the z value is not used in that case
Where is the first viewport and what size sheet
are you trying to print to what I assume a larger sheet layout on 11x17 or, do you have a completly different layout on the 11x17?
I assume that you are not using sheets and VPs
with this method there is really no need to create a separate print file
walls styles are basically walls that have a name rather then not.
they both can have components
the styles walls show up in the drop down menu
they NNA walls are stored in the Libraries Folder
custom walls are stored in the document (unless copied to the default mcd drawing in the library)
check out
for VW
then
http://www.imageprops.com/page3/page3.html
for renderworks
the latter will save you weeks of learning
and will create great renderings
if you are only sending the RO to the manufacturer once
use Save a copy as
and work on that file so you do not have to back track
you are probably looking for specs of the CPU
Intel Dual Core min 3 gHz
winxp will only uses 3.5 gig of RAM - 2 should be enough unless you do a lot of rendering then 4 gigs or 2 x 2 gig paired RAM
video card that will handle 2 monitors using DVI connectors
with min 512K RAM
hard drive has large as you can afford
winxp pro instead of Vista if you have existing peripherals
DVD read/write
and 2 monitors: 17" are good deals and gives you good screen space.
the above did a rendering in about 3 hours.
instead of 6 hours on a single core 3.0ghz - 2 megs of RAM
hope this helps
Symbol and Object downloads for 11.5.1
in Architecture
Posted
you did not say free so
http://www.turbosquid.com/3d
http://www.digital-furniture.com/shop/accesories-c-27.html
