symo
107 -
Everything posted by symo
I have a dual-monitor setup for my Win PC. For some reason, VW has decided to open all windows on my right monitor, despite moving the main window to my left monitor for all my work. Ive tried saving the palette positions. How can I tell VW to open with the same arrangement every time? Could this be a corrupt preferences file? Cheers
Many thanks @bbudzon & @BrandonSPP for coming back to me. Yes - I actually found that nvidia post and concluded that this was the reason my MBP wasnt allowing Vision to work. In the end - I installed Vision on an Asus laptop and it worked fine. So its looking like a VW2020 and Vision 2020 workflow for me. The only remaining issue for me is not being able to display vertical LX positions in a 2D layout - like I normally would - with the usual 2D labels. Once I find a solution for this (rather than having to show my verts in 3D with 3D labels) - I will be sorted!
Im trying to find a seamless, efficient and reliable workflow between VW & Vision - and havent been able to crack it thus far. Having said that - Ive only just started using Vision - thanks to this becoming available in service select. The reason I work across Win & OSX is that I work in Win PCs at work and a Macbook at home. What I have tried.... VW2020 (Win 10) ->Vision 2020 (Win 10): Using Send To Vsion command. The only combo that has allowed me to successfully export to Vision. However, Im having serious issues with Schematic Views (which seem to be shared by others) as I do a lot of vertical LX positions and I cant seem to easily show my vertical positions in a simple 2D view with lighting labels. Im having to create 3D labels and show vertical trusses & booms in a 3D view to show the required info - too time consuming. I could export my VW2020 file back to VW2019 (for LX plots) but then I would need to rebuild my vertical positions. VW2019 (OSX 10.14) -> Vision 2020 (OSX 10.14): I prefer to work in 2019 as I can use Plot & Model View - not perfect by any stretch but at least I can show both 3D views and LX plots the way I want to. I can do this quickly. I cant use the Send To Vision command and VW cant find Vision 2020. When I try to export to MVR and open this in Vision, the Fixture Mode & Patch info isnt transferring. Do I need to separately values into the GTDF Fixture Mode Window for this to work? The help file mentions having to build GDTF files but VW already knows the fixture mode. Do I need to go to the trouble of building GDTF file via the GDTF website to get this to work? VW2019 (OSX 10.14) -> VW2020 (OSX 10.14) -> Vision 2020 (OSX 10.14): The idea here is that I do most things in VW2019, which means that I can do everything I need in VW, then open in VW2020 to tweak and export to Vision 2020. Everything (Fixture Mode & Patch) seems to export fine to Vision, but Vision crashes when I select a light fixture - every time. It does this after using both Send To Vision & Export To MVR commands. Ive attached the VW 2020 & v3s file for anyone who cares to try it. I would appreciate any wisdom here - cheers in advance. Vision Test File.vwx Vision Test File.v3s
Got that. Makes perfect sense now.
Sorry - visualisation lighting overrides for sheet layer viewports. So I create my SLVP from the design layer then tweak the lights from the SLVP.
Hi Peter - yes sounds perfectly logical but had thought that the sheet layer overrides would take 100% control of these in the SL. But many thanks for responding - much appreciated.
Ive actually found out thru another thread what the problem is - the light needs to be turned on in the design layer in order for shutters and gobos to render properly in the sheet layer!
Well, that did it! Thank you so much. Would buy you a beer if I could. Id hate to think how long that would have taken me to figure-out.
Having an issue where gobos arent rendering correctly in sheet layers. I read somewhere that rendering gobos is more reliable in sheet layers - and I have found this to be true. Heres a render of the problem: Gobo Render Issue V1.pdf The profiles over the tables should show dot gobos in all 9 of them - but they dont show in the render. I used a custom render with all setting set to low. I tried a final quality render - but no change. I have tried swapping-out the symbol, but this hasnt made any difference. Any help with this would be much appreciated. File here: Gobo Render Issue V1.vwx
Having an issue trying to get VW to render light from light symbols that have had shutters inserted so that my stage wash doesn't light the ceiling, etc. The beam shows correctly in wireframe but not always correctly in fast & custom renders. This happens in both the design layers and viewports. I have made sure that the "soft shadows" check box hasnt been selected. I have done this successfully before. Ive tried different symbols but this hasnt fixed the issue My file is 150MB, so thought I would ask for anything obvious before trying to upload it. Cheers
So after a few days of pain, I finally have a stable VW workstation. Summary: It seems that my PC came back from the supplier in a broken state whereby it was missing some basic windows functionality (Microsoft Store). This became apparent when I tried to upgrade to Win Pro and my PC point-blank refused to do so - was missing the store app. After a few hours on the phone to MS support (who were actually very good and quick to call me), I reinstalled win 10 a couple of times and then upgraded to pro Ive managed to install all the right drivers & software and things seem to be running pretty good - PC performing well in benchmarks. The only thing that didnt work is the Aura app for LED control - but I can live without this. Are there any risks in enabling Windows Restore? I only like to restore from my system from Acronis backups if I really must Are there any other win 10 tweaks I should consider - now that Ive upraded to pro?? Cheers for all the help with this - hoping I get a few good months of pain-free rendering.
Cheers for that. Might need to do as woody says and upgrade to win 10 pro.
Got my PC back today and all seems to be well again. Heres what they said they did: Update MB bios Fixed windows folder which was corrupted by the crashes (but not reinstalled win 10) Updated all win updates Wound the CPU clock back from 4.4ghz to 3.5ghz. This was based on an earlier suggestion but they did this anyway. Im loath to crank it back up now its running OK - but may do a bit further down the track. Its running great - renders might be slightly slower - but I can live with that. They were adamant that there weren't any hardware issues - but seem to think it might have been a windows update. Ive learnt that some apps give false CPU temp readings - I was getting up to around 76° C mid-render with AI Suite. But have been using Ryzen Master which apparently gives much more accurate readings. Final quality renders are taking it up to 61°C max - so within the 68°C max limit. Adding to my woes were issues trying to restore from a "clean" Acronis backup - which ended-up being corrupted. Now that its running well - Ive disabled win updates as I dont want a repeat experience. Im thinking of doing this periodically - so I have more control of this. Is this recommended?
Hi Art V Cheers for that. Ive sent my PC back to the supplier - so I really hope they nail it. Will reply with any useful info I get.
OK - cheers. All makes sense. Will let you know how I get on.
Hi Zoomer Seems you are right: Im pretty sure it was running at 4.4GHZ. Will try it running at the base clock speed. Is it a known that a PC will completely freeze then break windows when it reboots - when the CPU becomes unstable? Lastly - I see that the max temp is 68 degrees C. Given that mine reached 75 - does this mean I have a cooling issue?? Nice to know there are other with similar setups that are running well.
Hi Zoomer Im not tricky enough to delve into the overclocking world - pretty sure its stock. I did some CPU load tests and it was fine - got up to around 75 degrees C (I think). Just seems to be VW mid-render that kills it. Really odd - my macbook takes forever to do final renders - but it gets there in the end. Ive boxed the PC back up and sent it to the supplier whilst I go on holiday!
Many thanks zoomer. Will try a CPU test app next.
Hi there Things were going swimmingly on my new AMD Ryzen "Threadripper" Win 10 PC - then it started to hang on final/custom renders. It seems to have started doing this after a period of intense rendering - usually on final or custom renders - but occasionally fast renders. Ive ascertained that its not file-specific. Prior to this, the PC would crank through any rendering job I threw at it. Towards the end of the render, after the CPU has been maxed-out on 99% for 10-20 secs, its like the PC just gives up and become completely unresponsive - no mouse movement or anything. The only way out is a hard reboot. The first sign of trouble was a render that ended with all my windows being re-arranged over my 2 screens. After the hangs started happening regularly (within a few hours), I restored the C Drive to an Acronis backup that was done 24hrs earlier. This didnt fix it. The last time the hang happened, I rebooted to find that my desktop had changed and that the Win 10 start menu wasnt working. My next step is a Win 10 Memory Test - which I have started and will take a couple of hours. There were no problems flagged after 1 hour of starting the test. Can anyone suggest the next steps to trying to resolve this? Cheers in advance.
Brilliant - all makes sense. Many thanks
Also - removing the parts records - is this just editing symbol in 3D, highlighting each part - then unticking base/yoke/body/lens/point?
Hi Markdd Many thanks for that - and the file. Re your suggestion of removing the parts record - what negative consequences will this have? I see it fixed the issue I was having perfectly - but wondering what issues I might discover also. Cheers again.
I tried posting this in the Entertainment forum - but its still driving me nuts. Im trying to use the PAMV command to show LED strip lighting symbols on vertical trusses for both lighting plots and renders/section viewports. The problem Im having is that the most of the LED strip lighting symbols I import rotate in the Model viewport after I run the command. Most of the LED strip symbols I import do this - some dont. All Im wanting to do is have the strips remain vertical on the trusses. The LED strip will show perfectly in the Definition layer, even in 3D views but will almost always end-up being rotated in the Model layer. The angle of the LED strip changed when you move the DLVP in the model layer. Ive tried using different truss symbols - but the problem remains. Ive used the PAMV command for conventional lights (profiles & cans) successfully, so Im pretty sure Im not doing anything wrong. VW file attached. Plot_and_model_view_issue.vwx
