symo
Content Count
68 -
Calendar
Everything posted by symo
Appreciate that - cheers
Hi there Im having an issue trying to get VW to show barndoors in my schematic views in VW2021 SP2. I can insert barn doors to the fresnel symbol as an accessory - this shows correctly in 2D and 3D views. But I when I update the schematic view it doesnt show. Ive also tried generating a new schematic view for the fresnel w/ barndoors - but to no avail. Is there a secret to this? Cheers
Cheers Pat - but I couldnt make this work-around work in this case. The only attribute that would copy is the colour. So I would still need to individually set each with pan. tilt and kind (spot, point, etc). When dealing with several light objects, I need to be able to edit parameters of several objects together. I cant edit multiple light objects in either OIP or visualisation palette in the design Layer.
I like to use multiple light objects for renders, rather than use just spotlight symbols - as I dont need to create focus points (which can get very tedious). For some reason, VW doesnt like me duplicating a light object after I set this with all the required attributes (colour, type, beam angle , etc) - then editing all light objects together in the Visualise palette. I can successfully duplicate the light object in the design layer: but when I try to select multiple light objects in the Visualiser palette and edit an attribute for all - the names of all duplicated light objects disappear and the objects can no longer be edited. Even better, when a viewport is created from the design layer, most of the duplicated light objects inherit some very odd names: After this happens, I can still only edit the original light object - "Light 1" in this case. It seems to me that this workflow is perfectly logical - would love to know if Im doing something wrong. Heres the VW file. Light Render Issue.vwx Cheers
Hi Kevin Cheers for the update. Looking forward to SP4!
Ive posted this in the Rendering forum also. Ive started seeing a strange issue whereby I create viewports on sheet layers, override the light objects (both from Spotlight & RW lights) until it looks right, render, close the file, re-open, re-render - then all of my Spotlight light objects turn-off for no apparent reason. The VW light object dont do this. I then need to go back to the design layer and re-create the viewport to get it to render properly. Ive attached a sample file with most of the geometry ripped-out (for IP reasons). Render test.vwx Another problem that I regularly run into are VW light objects blanking-out their names when I try to edit them in the Visualisation/Lights palette - normally when I select multiple lights and edit several at once. When this happens, I cant edit them in the sheet layer. Any insight would be appreciated.
Ive started seeing a strange issue whereby I create viewports on sheet layers, override the light objects (both from Spotlight & RW lights) until it looks right, render, close the file, re-open, re-render - then all of my Spotlight light objects turn-off for no apparent reason. The VW light object dont do this. I then need to go back to the design layer and re-create the viewport to get it to render properly. Ive attached a sample file with most of the geometry ripped-out (for IP reasons). Render test.vwx Another problem that I regularly run into are VW light objects blanking-out their names when I try to edit them in the Visualisation/Lights palette - normally when I select multiple lights and edit several at once. When this happens, I cant edit them in the sheet layer. Any insight would be appreciated. Will post in the Spotlight forum too.Render test.vwx
Kia Ora Cookie Cheers for that. Ive come up with workflow that doesn't add too much complexity. I create a layer called LX Vertical and put all my upright lighting and positions on this. For the sheet layer LX Plot, I just overlay a view port with uprights only - will all labels set to invisible. Life is pretty good in NZ thanks - all things considered!
OK got that. Clearly something lacking in the way I create DLVPs - will look into it. Cheers again
Hi @markdd I tried to create a DLVP of just the Schematic View object - but VW would default to creating a DLVP of the vertical truss instead. But no stress - I created the DLVP of the vertical truss and made all the label classes invisible for this from within the VP - and got this which actually works better - gives a proper top view of the truss on a sheet layer. Just need to structure my layers to adapt. Something like: LX Gen - for most fixtures but not vertical positions LX Verts - for 3D views of vertical LX postions (renders and Vision) LX DLVP - for showing vert positions on LX Plots, allows me to set labels to invisible for these only LX Schematics - for showing vert position detail on LX Plots Feels like a hybrid Plot & Model/Schematic View work flow - but seems to work. Many thanks for the inspiration!
Almost moved to a new Schematics Views workflow from a Plot & Model View (RIP) workflow - but one issue remains. When showing 2D labels in Plan View which both schematic view object & linked vertical truss lighting position - I get a bunch of overlaid 2D labels next to the vertical truss as shown: Is there a way not to show the 2D labels for the vertical truss and only the schematic view? With the schematic view object showing the detail - the vertical truss would only be useful in showing the position of the truss. Of course, I need this to be in the correct position for renders and Vision also. Cheers in advance.
I have a dual-monitor setup for my Win PC. For some reason, VW has decided to open all windows on my right monitor, despite moving the main window to my left monitor for all my work. Ive tried saving the palette positions. How can I tell VW to open with the same arrangement every time? Could this be a corrupt preferences file? Cheers
Many thanks @bbudzon & @BrandonSPP for coming back to me. Yes - I actually found that nvidia post and concluded that this was the reason my MBP wasnt allowing Vision to work. In the end - I installed Vision on an Asus laptop and it worked fine. So its looking like a VW2020 and Vision 2020 workflow for me. The only remaining issue for me is not being able to display vertical LX positions in a 2D layout - like I normally would - with the usual 2D labels. Once I find a solution for this (rather than having to show my verts in 3D with 3D labels) - I will be sorted!
Im trying to find a seamless, efficient and reliable workflow between VW & Vision - and havent been able to crack it thus far. Having said that - Ive only just started using Vision - thanks to this becoming available in service select. The reason I work across Win & OSX is that I work in Win PCs at work and a Macbook at home. What I have tried.... VW2020 (Win 10) ->Vision 2020 (Win 10): Using Send To Vsion command. The only combo that has allowed me to successfully export to Vision. However, Im having serious issues with Schematic Views (which seem to be shared by others) as I do a lot of vertical LX positions and I cant seem to easily show my vertical positions in a simple 2D view with lighting labels. Im having to create 3D labels and show vertical trusses & booms in a 3D view to show the required info - too time consuming. I could export my VW2020 file back to VW2019 (for LX plots) but then I would need to rebuild my vertical positions. VW2019 (OSX 10.14) -> Vision 2020 (OSX 10.14): I prefer to work in 2019 as I can use Plot & Model View - not perfect by any stretch but at least I can show both 3D views and LX plots the way I want to. I can do this quickly. I cant use the Send To Vision command and VW cant find Vision 2020. When I try to export to MVR and open this in Vision, the Fixture Mode & Patch info isnt transferring. Do I need to separately values into the GTDF Fixture Mode Window for this to work? The help file mentions having to build GDTF files but VW already knows the fixture mode. Do I need to go to the trouble of building GDTF file via the GDTF website to get this to work? VW2019 (OSX 10.14) -> VW2020 (OSX 10.14) -> Vision 2020 (OSX 10.14): The idea here is that I do most things in VW2019, which means that I can do everything I need in VW, then open in VW2020 to tweak and export to Vision 2020. Everything (Fixture Mode & Patch) seems to export fine to Vision, but Vision crashes when I select a light fixture - every time. It does this after using both Send To Vision & Export To MVR commands. Ive attached the VW 2020 & v3s file for anyone who cares to try it. I would appreciate any wisdom here - cheers in advance. Vision Test File.vwx Vision Test File.v3s
Got that. Makes perfect sense now.
Sorry - visualisation lighting overrides for sheet layer viewports. So I create my SLVP from the design layer then tweak the lights from the SLVP.
Hi Peter - yes sounds perfectly logical but had thought that the sheet layer overrides would take 100% control of these in the SL. But many thanks for responding - much appreciated.
Ive actually found out thru another thread what the problem is - the light needs to be turned on in the design layer in order for shutters and gobos to render properly in the sheet layer!
Well, that did it! Thank you so much. Would buy you a beer if I could. Id hate to think how long that would have taken me to figure-out.
Having an issue where gobos arent rendering correctly in sheet layers. I read somewhere that rendering gobos is more reliable in sheet layers - and I have found this to be true. Heres a render of the problem: Gobo Render Issue V1.pdf The profiles over the tables should show dot gobos in all 9 of them - but they dont show in the render. I used a custom render with all setting set to low. I tried a final quality render - but no change. I have tried swapping-out the symbol, but this hasnt made any difference. Any help with this would be much appreciated. File here: Gobo Render Issue V1.vwx
Having an issue trying to get VW to render light from light symbols that have had shutters inserted so that my stage wash doesn't light the ceiling, etc. The beam shows correctly in wireframe but not always correctly in fast & custom renders. This happens in both the design layers and viewports. I have made sure that the "soft shadows" check box hasnt been selected. I have done this successfully before. Ive tried different symbols but this hasnt fixed the issue My file is 150MB, so thought I would ask for anything obvious before trying to upload it. Cheers
So after a few days of pain, I finally have a stable VW workstation. Summary: It seems that my PC came back from the supplier in a broken state whereby it was missing some basic windows functionality (Microsoft Store). This became apparent when I tried to upgrade to Win Pro and my PC point-blank refused to do so - was missing the store app. After a few hours on the phone to MS support (who were actually very good and quick to call me), I reinstalled win 10 a couple of times and then upgraded to pro Ive managed to install all the right drivers & software and things seem to be running pretty good - PC performing well in benchmarks. The only thing that didnt work is the Aura app for LED control - but I can live without this. Are there any risks in enabling Windows Restore? I only like to restore from my system from Acronis backups if I really must Are there any other win 10 tweaks I should consider - now that Ive upraded to pro?? Cheers for all the help with this - hoping I get a few good months of pain-free rendering.
Cheers for that. Might need to do as woody says and upgrade to win 10 pro.
