MHBrown
Content Count
275 -
Calendar
Everything posted by MHBrown
OK. thanks. That does sound like I was missing something simple. I'll give that a try! Appreciate the quick reply!
I've always only worked in screen plane, but from time to time I decide I need to try using different working planes. Right now, I have a table top that has a hole drilled in it (via solid subtraction). The top is tilted at 45 degrees, but I need to look at it in plan perpendicular to the face. When I switch to top/plan in screen mode it is, of course, showing me the plan of a tilted table. So I set the working plane to be parallel to the tilted table, assuming that I now have the x,y.z coordinates similarly tilted. When I select top/plan or even plan, however, I get the same, truncated view as when I was in screen mode. Why is that? When I'm in an isometric view the indication is that the x,y plane is indeed parallel with the tilted table. So why does my plan, left, right views not show it? Very confusing and not at all intuitive. If I change the x,y grid the other views should follow. I've seen some applications that use what they call j,k,l dimensions for a "temporary" change to the directions. This is not a good idea at all, but does VW use something like this? In summary: how do I look at a table top square on that is tilted at 45 degrees without temporarily swinging it up those 45 degrees? I'm sure I'm missing something simple, but not sure what that is. Thanks for any help. MHBrown
Regardless of how I set my preferences, it still switches from Screen Plane into other planes without my doing anything. This is looking like a bug since the Document Prefs clearly says "Screen Plane Only," yet it changes anyway. I sometimes glance to the info palette and it will say 3D instead of Screen. Then I know I'm in trouble. I think the poor snapping of VW2016 is partially attributable to this, but it's hard to say for sure. MHBrown
Alan, I work exclusively in 3D, but working in 2D is the easiest way to keep things precise. I work pretty much like Kevin, drawing data lines to help me keep things neat. Also, like Kevin, I'm stumped by the inability to snap at ALL intersection points: 2D and 3D "hybrid" snaps, included. Everyone has different ways, I suppose, but Vectorworks's strength for me has always been to work in 3D by carefully limiting one's self to using two dimensions at a time. That doesn't mean I don't use some of the added features. Some of them are great. Since I've been using this app for over 20 years, however, I've gotten picky about which "features" I feel are worthy. Thanks for the tips! MHBrown
In VW 2016, I pull down the "Screen Plane Only" from the menu, but it keeps changing. I'll be working along when things start going a little crazy, objects don't snap, rectangles and drawn and disappear, etc. I look and notice that the selection has changed to one of the others: "Working Plane only" or "Screen Plane or Working Plane." I do not nor will I ever want to use anything other than Screen Plane Only in Vectorworks. Is there a way to erase the other two options or otherwise lock it in to Screen Plane only? Thanks for any help on this. MH
I found a couple of bugs In VW 2016: The rotate tool does not always work in views other than Plan. The date stamp does not update, even when refreshing using the info palette. You have to delete the existing date stamp and replace it to get the file name to update. On a Mac, El Capitan, VW build 288897. I'd like to send these to the VW bug report list, but when I click on it I'm routed to tech support. I thought I read someone said there is a place to submit bugs. Is there? Thanks, MHBrown
Rectangles disappear when editing extrudes.
MHBrown replied to MHBrown's topic in General Discussion
Thanks Kevin. I can't for the life of me see how that would be the default, but I'll check it out. -
That's not really helpful to me because I'm trying to snap the joist to another joist, so I have to see both pieces. If I go into the 2D profile of the extrude to edit it I can't do that. I can't select a "face" of the extrude to use the push-pull tool because it is "inside" the other joist. That's why I need to make it shorter. Furthermore, the most accurate way to snap objects together is to eliminate one of the axes, x, y or z. That way you are certain to snap to the correct spot. Lastly, it makes no sense to have a tool such as the Reshape tool that works in "...a side or front view" and not plan view. What do you have against Plan view? Sure, points would be located on top of each other, but I've been able to drag extrusions under that condition for years in both MC and VW. In short, I want to grab a tool and have it work in all situations. Many of VW's tools seem to be conditional and those conditions do not seem to have a logic behind them. At least I don't see it. Thanks MHBrown
VW 2016 SP1, Mac OS 10.11 (El Capitan) I notice that the Reshape tool does not work. Here is an example. I am looking in top/plan at an extrusion, a 2x6 joist. I want to make it shorter, so I select the Reshape tool and draw a marquee. I get the little circle with the four radial arrows around a vertex of the extrusion. I move the vertex, but it does not move. I try every possible combination, but none of them accept the movement. Shortening a joist in plan should be simple, but it is not. This tool doesn't work. The joist is sitting at 45 degrees, so I can't simply drag it. I suppose if I could figure out how to change the X-Y coordinates to align with this joist I could do it that way, but that is really the tail wagging the dog. The 3D reshape tool should work, but it doesn't. Can anyone explain why? Thanks, MHBrown
I've now noticed that when I exit the extrude edit window all of the rectangles I've drawn are suddenly visible. This is really a mess. -
Curved double line tool
MHBrown replied to MHBrown's question in Wishlist - Feature and Content Requests
Thanks to bcd (cute name), but, no, that is nothing like the double-line tool or curved wall tool. I'm talking about something that works like the curved wall tool at a minimum, but more like the polyline tool only instead of drawing joined curves and straight segments it would draw joined curved and straight closed shapes. Additionally, you could snap from point to point. That is what I'm asking for. I already know the workaround you suggest, but clearly that is a ham-handed way to create what I'm talking about. Using your method would require many more steps. If I could draw a complex line with the polyline tool and then use the offset tool as you suggest that would almost be useful (requiring only one extra step). Alas, the offset tool does not work on the lines created with the polyline tool, although there is no reason why it shouldn't. I was fairly clear, I hope, on what I was wishing for. I'm not sure why you suggested something unrelated. MHBrown -
This thread is listed as happening in 2010, but obviously it is more recent than that since it is discussing VW2016. Please let me know if this is wrong. If I am speaking from five years in the future (2015) let me warn you that the snapping ability between VW2010 and VW2016 is night and day: as in VW2016 has horrible snapping. VW2016 will snap on the imaginary rectangle that encloses a shape, for example. That's right, the same annoying flaw as Adobe Illustrator. If something is on top of something in VW2016 it is almost impossible to select the lower object...even if it is "sticking out." Yes, just like Illustrator. I'm very disappointed because I used to complain to Adobe how they should look at VW as to how object selection should work. Well, I can't do that anymore. Trying to snap two objects together is equally flawed. I've never had to zoom in super close just to put a couple of corners together. It is slooooowwwwing me down. This has to be fixed. I appreciate Donald's list of solutions above, but these are all things a seasoned VW user will have already tried. I fear this is a software bug and I hope it gets fixed soon. VW has plenty of information to go on from this thread alone that something is not right. Thanks, MHBrown VW2016 SP1 iMac El Capitan
This is so basic that I'm almost embarrassed to ask for it. I think remember asking for this is the late 1990s: a curved double line tool. That's the best name I can come up with, but it's easy to describe. It is exactly like the double line/polygon tool except it draws curved objects. It's also like the curved wall tool. It would snap just like the arc tool (or just like the curved wall tool). Ideally, it could switch between double-line and double-arc as you draw so you could make a series of connected rectangular and curved solids. Form-Z had this tool years ago and probably still has it. To draw a curved solid object in VW now you have laborious work arounds. Let's say you want a "C" shape that is 3" thick and 36" x 18" in size. I have to draw an 180 degree arc 36" in diameter. Draw a concentric arc, 33" in diameter. Clip the smaller arc from the larger arc. Now fill in both ends with rectangles and "add" them to the previous construction. What a pain. Give me a curved double line/object tool. I'm willing to bet I'm not the only one asking for one.
Vectorworks 2016 is here, ask us anything!
MHBrown replied to PVA - Jim's topic in General Discussion
I think I posted it on the wish list in the late 1990s, so I'm not sure it would still be there. It would be better to post it again. I would be very, very surprised if this request is not already on the list. It seems pretty fundamental, especially since there are two tools—double line tool and wall tool—that are very close. -
I can't believe that there is still no way to draw curved solids analogous to the double-line tool. The entire list of "improvements" is mostly, if not all, enhancements that are not critical. I can't tell you how many times I've needed a curved solids tool. Sometimes I try to use the round wall tool as a workaround, but walls are so clumsy to use (if you aren't building wall that is) it becomes useless. What is so hard about taking the Arc tool and all its ways of creating arcs and making it work for solids of any thickness? THAT would be something worthy of a list. VW2016 is nothing more than VW2011 v.5. Big deal. Disappointed here. -
I just upgraded to the latest version of VW Arch 2016 two days ago (6 November 2015). I believe I'm using the first version of OS 10.11, which I think they are calling El Capitan, or something insipid like that. I'm on a late 2012 iMac with the 1GB video card and 16GB of RAM. It may work since I upgraded, but there is no way to know until the situation comes up again in my normal workflow.
Thanks, but does anyone NOT have a custom workspace? Regardless, that for the tip. I'll just keep an eye out for commands that don't work anymore and switch them to something else.
It happens with any object type. Thanks. -
I'm using VW Arch 2013 at home and I tried the Import Sketchup menu command. Nothing happened. It didn't try to import. It didn't do anything. Nothing came into my blank VW document. Yes, I did select all and Command-6. Trust me, nothing happened. I'm sure VW Arch 2016, which I use at work, will behave the same. What is the point of having a menu command that is empty? VW help suggests importing SU files as DWG/DXF, which, of course, is nonsense. SU files are grayed out when importing is set to DWG/DXF. I'm not sure I understand VW's reasoning here. MHBrown
OK. I found something that works similarly under File/Publish as opposed to the Cloud menu. This seems to work fine, but I wonder why it was moved? MHBrown
In VW2016, the export PDF (batch) is grayed out. It says it is missing the plug-in. I've used this in just about every version of VW and I don't ever remember installing a plug-in. There is something referred to as "Publish" under the Cloud menu, but anything and everything having to do with the "Cloud" or "cloud" is useless and too primitive for my use. I've looked, but I can't find the batch PDF export plug-in anywhere. Am I looking in the wrong place? So far very unhappy with VW2016. Thanks, MHBrown
I think Kevin has it figured, though the switch to top/plan view didn't work either. It happens when I'm inside a symbol. I suppose I'll send it to the bug list. I'll also add the Date Stamp, which no longer updates the file name. This is really dangerous since I depend on that to keep my title block with the correct name. Yes, I realize I have to manually go to the object info and de-select/select the "show file name" field, but that no longer works. My title block is a symbol (obviously) so maybe that is the problem. Pretty annoying. MHBrown -
What is wrong with VW2016? I'm in an extrude edit window. I don't like the profile that I have. As I have done since MiniCAD 5 or 7, I draw a new rectangle that has the correct size, but when I do the rectangle is on the screen for just a moment and then disappears! Whatever is causing this to happen, I want to turn off. I do not care if it is some sort of "new" way of drawing. VW is NOT a 3D drawing app. It is a very good 2D app for creating 3D drawings. Please let me know what I can do to remove this unwanted feature (although I find it hard to see how having a drawing vanish immediately as it is drawn is a feature.) Thanks in advance for any help. MHBrown
Yet another problem with VW2016. 1. Edit a 3D symbol 2. Look at it is one of the side views 3. Draw a rectangle to help guide changes. 4. Save while there. 5. Nothing, nothing, nothing can be selected. Command-6 shows nothing, Command-A shows nothing. The object is gone. 6. Suddenly, you are back in the original window with the object as you changed it. 7. Summary: you cannot Save the file while in conditions 1 - 6. Is anyone else seeing this type of problem? Thanks, MH
