Boh
1,704 -
Everything posted by Boh
I also tend to have just one file open at a time. This is mainly because I am usually working on one main project at a time. Unfortunately also with VW crashing at random times it means less hassle retrieving drawings.
Choose the way the suits how you work. I like using groups a lot and so having only the active class only visible doesn't work for me as usually the group container object is on a different class than the objects inside. If I make the contained objects the "Active only" class they will still become invisible as the container object class will be turned off therefore rendering all objects inside it invisible. Using layers to keep objects to the foreground is a good method which I use too however sometimes you already have enough layers in a document...
You can set the wall styles to have caps by default. Is that what you wanted? I also wonder why can't walls "heal" automatically. Instead I often have to use the "Remove Wall Breaks Tool" to tidy up wall breaks.
If you group all the objects you want to stay on top then it is just one group to send to front instead of a load of individual objects. Another way is to make a script via the custom selection tool that selects all the objects in a class and then send to front.
Can you automatically link Class graphic attributes to Renderworks Textures?
Boh replied to Cavan Smith's question in Troubleshooting
Hey Cavan. Ok so misinterpreted your query, sorry. 2d objects will show their 2d attributes when viewed in OpenGL (as long as they are not on the screen plane). As far as I'm aware, 3d objects can only have solid fill attributes render in OpenGL (just have no texture and the object will take on the solid fill attribute in OpenGL). -
Textures won’t be applied to objects that have no fill so make sure all objects have a fill. -
There is a render tab in the edit class dialogue where you can assign class textures. Then make the actual objects texture ‘by class ‘ and the assigned class textures she’d be applied to those objects. Just like in the other attributes there is a ‘use at creation’ checkbox so new objects assigned to that class will automatically take on those textures. Cheers -
Do you have another way of doing global note edits?
Global editing of callouts from a database worksheet.
Boh replied to Boh's topic in General Discussion
Thanks Eric. I wasn't sure if editing the note from the worksheet might cause issues with other callout functionality. As you say losing the database link is not a biggie. Are you not using keynote legends then? I haven't used data tags yet but I can see they are a bit of a game changer. -
That's reasonable and I have worked that way too. At the moment though I am drawing all my details in the viewport annotation space. The details may start off as live plan or section detalis from my 3d model but I over draw that and usually end up turning all the layer visibilties off. I've found this means less viewport. Individually scaled details (not influenced by the DL scale), the VP's are just like groups and I can move / align them individually etc plus of course the added benefit of auto referencing.
Drawing Label tool changing default font sizes
Boh replied to MartinFahrer's question in Wishlist - Feature and Content Requests
Cool trick! -
Updating All Callouts From Updated Database
Boh replied to Tom Klaber's question in Wishlist - Feature and Content Requests
It is possible using a database worksheet to do global edits of callouts/keynotes. Not sure how reliable this method is however. Here is a new thread; -
New thread on global editing of callouts/keynotes using a database worksheet. I am wondering if his is a good option?
I've just created a new thread about using worksheets for global editing of callouts. I'm wondering if this is the way to go?:
There has been various threads about auto updating callouts throughout a file with general agreement that this isn't possible except kind of using a database. As an experiment I've created a "Housekeeping" worksheet for callouts where I can change the text of a callout/keynote straight from the worksheet. So by summarising the "Text" column I can then edit the text of mulitiple callouts at one time. I'm using a field called 'Callout'.'Text'. I am wondering if anybody has tried this in practice and if there are anybugs? So far it seems to be ok...
Clicking on the settings icon worked for me but apparently not for Martin. I can't figure out why but suggested the plugin manager might do the same thing. I haven't tried it however.... -
That is odd as I tested it and it works on for me on both vw 2018 & 2019. I did notice that after double clicking on the label tool changing settings it didn't always pick up the changes when placing the label but once tool is activated then going to settings it included the changes. Slightly buggy but I can still get it to work. I couldn't find any particular setting in preferences or document settings on this but you could try playing around with the plugin manager and see if that works. -
If you double click on the drawing label tool it should go straight to settings. Adjust your settings then place a label. This should now be the default setting for that tool for that file. If you do this with your template file then you should have it as your default for every new file from that template. When you create a viewport a label with those settings should appear. Re viewports. It looks like the default is set at 1:1 in the create viewport dialogue so you need to adjust that each time unfortunately. -
My workaround is to use VW 2018!
You could also just crop your section viewport to the area you want to see on your drawing.
Hmm. I've set up the "create symbol" command with short cut keys so actually this might be feasible.
I don't think you can. You can add callouts to a database and then reuse that text again elsewhere but updating automatically as far as I'm aware is not possible. Would love to b proved wrong on that...
ditto
- 1 reply
- 1
If you made each text item a symbol then yes. Though if there are lots of text items then this could get unwieldy.
