ricky.cole
    7
Everything posted by ricky.cole
  1. I have enabled click-drag. It's almost had to explain! I just remember on PC being able to perform an action with the mouse (whatever it might be) and that action being performed instantly and not having to then move the mouse after for it to happen? For me to move this north arrow I have to select it, move it with the mouse, then I get the square and it's only when I move the mouse again that it moves to the position I have selected. A better example is if I 'command z' that action, the north arrow won't move back until I have then moved the mouse after pressing 'command z'?
  2. Hi all, Have just purchased a MacBook laptop and I'm using the apple mouse. When I click on a function eg: delete, it will not delete the object until I have then clicked something or somewhere else. So essentially I feel like I am having to click twice as opposed to once. Is this an apple mouse thing that I can change somewhere? I feel like there is a lot of 'clicking' going on compared to my old PC! Thanks!
  3. Hi there, All my plants that I have imported from the vectorworks plant library have come in with a low opacity and the attributes drop down menu will not allow me to change it? Any ideas?
  4. Hi all, For some reason I cannot access anything on my attributes palette when on one particular class. It was working fine then now when I go to the drop down box its frozen/dark grey and will not allow me to do anything. It's only on this class, it's fine on other classes. What could I have done? Thank you all so much!
  5. Hi Ray, Thanks I think I just sorted it by composing all the lines together. Are you able to tell me why my when i use the callout tool the text is coming out with the letters stacked ontop of ecah other vertically? Thanks
  6. Hi there, I am trying to type text in the callout but it keeps comming up with the letters on top of each other vertically? Cheers
  7. Hi there, I am just learning vectorwoks and I am having trouble adding a gradient to an area which has an arc in it. It adds the gradient to a small section outside the area? Any help would be appreciated. Thanks
