Mark Chevalier
    24
Everything posted by Mark Chevalier
  1. We are on a Mac Network via a hub with VW (multi seat license) installed at each station - with that you can disconnect yourself from the network temporarily, either reconnecting once VW is open, or after you finish using it.
  2. See also earlier discussion on a question I asked regarding print / view symbols / objects: http://www.nemetschek.net/cgi/ubb/ultimatebb.cgi?ubb=get_topic&f=12&t=001450
  3. Go via the Resouces palette (command R) > use the scroll bar to select other files with symbols in > hit "import" (or simply place the required symbol in the drawing). The import can be used for multiple selections I think.
  4. This would be useful - also add the ability to show an icon to identify the situation when you are in a saved sheet and you have (temporarily) modified the visibility, ie you may have greyed layers / turned on an extra clsss while working on that saved sheet.
  5. We use a Template with pre-set classes. We also often import other consultants work, bringing with it a slew of new classes. As work progresses it is nice to "purge". However, if any of our standard classes do not (yet) have work on them they are lost and cumbersome to restore. Is there a way that the "purge" command could be more flexible to allow selections of classes to be retained / locked even if they are not yet in use?Thanx!
  6. When opening the windows Edit Saved Sheet / Classes / Layers, the window is only sized for 8 layers / classes (Edit Saved Sheet window) or 12 layers / classes (Edit Classes / Layers window). We rarely have drawings with so few classes / layers. Can the windows for Edit Saved Sheet / Classes / Layers vary in size to suit the number of items in the file. That way we have to "scroll down" only when the Edit window is the full screen height and there are still more items to show. Thanx!
  7. It would be great to have a way to retain symbol folder organization when workgroup referencing? It seems that the file shows referenced symbols but ignores folders. This is a real pain with a library file that you want to workgroup reference having hundreds of symbols. Please add to the VW10 Wish List. Thanks!
  8. PARKING - It would be great to be able to lay out the parking in the way that theater seating can be done, ie set a polygon and set parameters, such as stall size, aisle alignment, etc and, hey presto there it is! RIGHT OF WAY - can you add a ROW option to the road tool (my temporary work around is to use the curb lines as the ROW edge). In most situations the ROW is as important an item as the actual road edge. For more graphic presentations it would be good if the road could be colored fill with the remainder to the edge fof ROW being transparent no fill. SUBDIVISION LAYOUT - it would be great to be able to lay out subvivisions by being able to set parameters, such as frontage, depth, area, etc, and again, hey presto there it is! Thanks for helping simplify our life NNA!!! [ 02-19-2002: Message edited by: Mark Chevalier ] [ 02-19-2002: Message edited by: Mark Chevalier ]
  9. Is it possible to draw a road by drawing a centerline poly and then a command such as create road from polygon" (similar to "create wall / roof from polygon")? We do site planning in concept, and in the early stages it is awkward piecing together starights, S curve beziers and tees for a subdivision road network. Up to now we would draw the centerline, off set, smooth bezier. Any suggestions?
  10. Is there a way to print all symbols without going ... select symbol / place / select symbol / place / select symbol / place / etc... ?
  11. quote: Originally posted by MikeB: Simply open the template. Make your changes to the new document, then save it as a template again, replacing the origional template file. Good Luck Thanks! That was too simple a solution for me to think of - talk about not seeing the forest for the trees!
  12. We have a template for our standard drawing sheet. We cannot find in any paper or online manual how we can edit it once created. Every way I try to open it it opens as the new document not the actrual template document. Does anyone know where we find this info? Specifically we want to edit a workgroup reference link to another document and to add a Vectorscript. Thanks!
  13. Thanks Andrew! I really appreciate the instant proactive approach you have at NM. quote: Originally posted by Andrew Bell@NNA: There will be a plug-in command available at http://www.vectordepot.com that should work to display acreage, regardless of your units, etc. settings. (Note that it has not received more than the most simple testing.) [ 11-04-2001: Message edited by: Andrew Bell@NNA ]
  14. I have been naming objects using the top (title) window of the data tab in the object info pallette. This is to allow the object to be "linked" to a worksheet cell to have a list of areas. When I move the named polygon to a different layer the name disappears from the data tab. Is this a bug or supposed to happen? Is there a way I can lock the name? Thanks! Mark Chevalier
  15. Thanks Katie: An alternative I have found is to make a worksheet for the areas I need to check acreage for, using a formula cell to convert from sq ft to acres. In my case this is a little easier than changing the units setting for the drawing, as the primary use of this particular drawing requires the units in feet / inches.
  16. Is there a way for the object info pallette to show polygon area as acres as well as / instead of sq ft? I see only sq ft and working on site plan parcels this would save a calculation every time. We are using 8.5.2 VW. Thanks!
  17. 1) Can NNA look at having MS Word-like interface for quick editing and viewing of text information, either within the object info pallette or somewhere else on the screen. It seems awkward to always be scrolling down the Text menu for thgings text related. 2) When text is selected to edit can a pop up window appear to allow easier editing. This would help when zoomed out and editing text so you can see what you are doing without zooming in. Thanks! Mark Chevalier
