TKA
229 -
Posts posted by TKA
the stair tool doesn't allow for stair that is composed of two raisers and one tread, is this right??? or is there a trick?
I have been using small intuos Touch (very useful for scrolling and zooming), and various versions of Wacom tablet before Intuos. Small works fine for me, and yes its just the right size relative to the natural movement of hand, similar to small sketching writing.
Boh, you are right, I have misunderstood your question, may be if you . What I understood is that let's say you have 6 layers and 3 different types of seating spread across all layers. You want to have box in a spreadsheet showing just type 1 seating on layers 1,2,3, that will be scenario where both chair type and layer will have to be present in order to register in the box. But I suspect you might have something else in mind.
it depends which version of Vectorworks you are using. Normally there is an option to add layers and other criteria from pull down menus.
select whatever cells you want then go to format cell and under "number" you can force it to no fractions
22 minutes ago, Mark Aceto said:
http://osxdaily.com/2018/10/21/download-macos-high-sierra-from-mojave/
However, I wouldn't say the Mac Mini has a great CPU by any means, and if your desktop computer requires an eGPU to run your CAD software, it's not a workstation. And if recent history has taught us anything about jamming a 6-core CPU into a 4-year old thin and light enclosure, we can expect the usual thermal throttling from Tim, Jony and Phil.
Take a look at the 2017 iMac with a 4.2 base clock and built in 8GB VRAM. It's a sleeper.
thanks for the info about Sierra, I have been using Mac minis in my office for years now, one I have now is from 2012 and works fine for me, however, I wouldn't mind speeding up rendering times. I use it as a portable device: I have screens in my office and at home and I bring my mini with me hence my questions about it. But I see the point about graphics, usually it is the most limiting part which rendered all my old iMacs unusable at certain point.
so the new Mac Mini has been released, I have been waiting for this quite a while, obviously it will come with Mojave. Is there a timeline for VW to be compatible with the new OS. Alternatively, has anyone (I know nobody has an answer to that today) successfully downgraded new Mac mini to High Sierra?
this is something I have been trying to get done to avoid having two independent documents (drawings and cur sheet specs). So far the only way to accomplish that is to have all the cut sheets uploaded to to your website project folder and then create web link column in your schedule. The cut sheets have to be individual files in subfolders and so on, not a single book, so the sis not ideal. However, the good thing is that if you have cur sheets online than you use "link" tool to connect not only schedules but also the items on the plans to the cut sheets.
also., I would recommend the best graphic card you can get on iMac, I have been using iMacs and Mac minis (which is essentially the same thing) and I always run into graphics card issue, while the processors and ram are fine the graphic card is the one that limited Mac useful life span.
I am trying to change one of the space tools settings: I want to change or eliminate Space Tool Area suffix - sf. ft., I would like it to be just SF in capitals. Anyone knows where is the setting for it?
I have looked around at all the options and still cannot figure out whether it possible to separate tool set from tool sets: I would like to have more than one subset displayed simultaneously. For instance I use
yes, this has been a problem and I don't know exactly why this is not fixed as the path for drawing names etc works so why wouldn't it work for the sheet number? My work around it is via drawing list, I managed to make it feed the title block sheet numbers. It is easier to change the numbers in worksheet but then you still need to double click each title block to actuate the change. It seems like the title block needs another command similar to the worksheet - "recalculate all title blocks".
- 1
I have faced a similar problem and ended up using issues as revisions. For whatever reason the issues are scripted to work like revisions, at least for USA architect.
you need to redo/resize manually the TB @ 1:1 scale in order for it to work on the sheet layer.
I think this is a question to Jim W/VW staff. There has been treads regarding the door and window tags not being able to resize in viewports. I was wondering why not to have the tag as another item in viewport advanced properties? It would solve so many problems.
when resizing worksheet column (making it wider) with just text in cells (set to wrap text) for some reason the text reshapes as it supposed but leaves blank space at the bottom of each cell as if there were extra blank lines (there are none). The only way to get rid of the blanks is, so far, to cut the text directly from the cell, hit return and paste it back in. Is there a trick to globally fix it?
you can control that label in design layer: size if the circle is set via "info" box and then the text via text pull down menu. You can control this label in the viewport via "advanced properties" in the info box with viewport selected. There are treads regarding this issue, but in the end there is no perfect solution, problem being that if you use the plan at 2 different scales then you will have a label size issue.
same here, I was unable to customize the labels at all, though suggested a while ago that these labels should be more like simple mini title blocks.
- 1
I made some screen shots to illustrate the issue, there are 3 screen shots:
1. cursor indicated middle of the first object
2. cursor indicates corner of the second object
3. second object is forced dragged horizontally to align right above the middle of the first object, there is no indication that it is picking up the middle of the first object.
Now when this happens in midst of regular drawing with many object it is not possible to know what I am aligning too.
however: I am always in click and drag mode and when I roll over a deselected object it shows mid or center, once selected it does not, second thing, when dragging an object by whatever point to snap to center the cursor will not show spell out any acquisition points, it will just highlight them which depending on zoom may not work.
definitely related, thanks, it definitely improves snapping to mid points.
- 1
Strange Cones:
in General Discussion
Posted
I think these are lights and cameras, go to light and views palette and make them invisible
