megan
    2
Reputation
0 Neutral
Personal Information
  • Location
    NC
  1. According to post quoted below, CineRender is a separate, 64-bit multicore app running in parallel to VW. Presumably, that means it's running in its own memory space and can address as much RAM as is available. That suggests that RW operations would benefit from more RAM, though VW itself is still limited to 2.5 (REALLY? STILL? What's up with THAT?) Gb. -- source: Renderworks 2011 or 2012, iMacs, memory, and 64-bit addressing
  2. The tool tips might be generated by Vectorworks, but the timing and control of these tool tips is part of the windows operating system. What you can do it go edit the RegEdit and adjust the time delay before the Tool tips appear. I suggest that you do a google search for this and see what you can find. I found this article... Jonathan, thanks. That takes cares of Windows. Here's what I found for OS X: Configure Tooltip Properties in Cocoa applications If you want to change the delay just for VW, replace the -g with the name of the .plist file for your version of VW, which for VW 2012 is net.nemetschek.vectorworks.2012.plist Thank you for this. We're migrating from 12.5 to 2012, and tool tips has been driving some of us crazy! We could live with it in 12.5, where it's only the tool name so it only partially covered up the tool the pointer was on, but these multi-line tool tips are just idiotic. +1!
