MeTheMachine
61 -
Everything posted by MeTheMachine
Selecting Lighting Devices by Channel Range
MeTheMachine replied to MeTheMachine's topic in Python Scripting
Yes! Thank you I forgot about this! -
Based on an earlier script/post about selecting lighting objects by universe... http://[https://forum.vectorworks.net/index.php?/topic/102718-selecting-lighting-objects-by-universe/#comment-449004] Is it possible to select lighting device by a range of channel numbers? For instance 101-103 Using the script from before, how would I loop through and parse the dialog a user enters. import vs vs.DSelectAll() channelRange = vs.IntDialog("Enter a fixture number range", 1) vs.SelectObj("INSYMBOL & INVIEWPORT & ('Lighting Device'.'Channel'='{}')".format(channelRange)) Any guidance would be appreciated..
Selecting Lighting Objects by Universe
Thank you so much! Slowly working myself back into scripting. Thanks again! Worked perfectly. -
Using "Custom Selection..", I can create the following python script import vs; vs.DSelectAll(); vs.SelectObj("INSYMBOL & INVIEWPORT & ('Lighting Device'.'Universe'='1')"); Ultimately, I would like to not have "Universe" hard coded and have the ability to use a PopUp and enter a value for Universe. Any of you python people willing to help me get something going....
MacBook Pro, Mac OS Big Sur 11.3.1, VW 2021 SP3.1 However, like michaelk, it fixed itself.
Anyone ever figure out a fix or workaround for this? Yesterday, I did a Nuke and Pave on my mac.... rebuilt (not imported) all my VW preference settings, and I'm experiencing this same exact issue... Across different files and after VW restarts.
thank you for the help! That makes sense.
First, I'm not the greatest working in 3D, so I have a questions: Is this a bug or me? When I have a truss selected, adjusting its length from the handle will also rotate it... I noticed that when I uncheck "Show 3D Detail", the problem doesn't occur. I've added a GIF to show, I'm sorry about the resolution... You can see, that: - first I shorten the truss - it rotates. - I undo - Check off "Show 3D Detail" - Adjust and its fine. Adjusting Working Plane, Holding Shift, etc doesn't fix the issue. So, is this a bug or me...
PDF on Design Layer Disappears on Zoom
MeTheMachine replied to MeTheMachine's question in Troubleshooting
Thank you for the suggestion -
I'm drawing over a PDF, but when I zoom in close, the PDF disappears. When I zoom out, it will refresh and appear. Is there anything I can do to mitigate this? Using 2 layers, one with the PDF and the other for drawing. The layers are the same scale. I've also tried adjusting the 3 Navigation Graphics settings, but nothing is helping.... You can see in the GIF, that my red area is where I'm drawing the initial footprint.... Any suggestions...
I remember having a similar issue with PyCharm and changing "pip install ..." to "pip3 install..." fixed my issue, even though I set the alias of pip = pip3... I'm far from a programmer and this probably wont do anything, but felt it might be worth mentioning.
Need help tracing over complex walls.
MeTheMachine replied to MeTheMachine's topic in General Discussion
Thanks for the help. -
3D. -
I do a lot of tracing over PDFs for lighting plots. Often, the set designer will draw walls that don't conform to the standard wall tool... or at least with my level of experience. This isn't a complex wall, but it was easy to explain my question. As you can see in the image: # 1 - Starts with a wall 4", which is a standard width for a set wall. # 2 - Jumps to a larger width. # 3 - Adds a little over hang. Typically, I would draw the 4" wall and stop when it changes its size. Then create a new wall with whatever the new size would be, and then just join them. This gets annoying with more complex sets. Is there a simpler way to do this? Using the standard "Create Walls from ...' has produced undesired results. Any suggestions would be great.
Getting the filepath via AppleScript
Thank you very much, Pat! -
Its entirely possible... I was looking at other AppleScripts examples and they were using POSIX path... Applescript makes my head hurt... -
I'm trying to use a program on the Mac called Hook My goal is to link or "hook" all the PDF files I use for a drawing to the vectorworks file I'm working in. Currently, I can have 12 different sets, which is 12 different vectorworks files, and all of them have up to a dozen PDF files from Art Dept. So if I'm working on "Haunted Castle.vwx", when I invoke Hook, it will pull up all the PDFs I have linked to "Haunted Castle.vwx" file. With that in mind, I'm probably going about this all wrong. I wrote a python script that I use to capture the filepath and set it to my clipboard. Keep in mind, Im not a programmer but it works... import subprocess def Path(): filePath = vs.GetFPathName() filePath = filePath[1:] subprocess.run("pbcopy", universal_newlines=True, input=filePath) vs.AlrtDialog(filePath) Path() Following the instructions for creating integration scripts Once I run the python script, in vectorworks, I use this applescript to create the hook path -- Append clipboard to Hook Link set cp to POSIX path of clipboard -- Get Address set hookPath to "file://" & (the clipboard) And I use this applescript to create the name of the hook... using the name of the document tell application "Vectorworks 2021" set current_name to name of item 1 in windows end tell --- I tried to use the "Run python script" in Applescript but kept getting an error. I'm sure its something I'm doing wrong. I didn't know if it was possible to just get the filePath of the document in applescript? It would take the manual execution of the python script, out of the mix... I've hit my afternoon lull, so I hope this makes sense. -
Is it possible to get the filepath of a document using Applescript? I didn't know where exactly to post this question. Thanks for any help.
Seems like something got wonky with my conversion from auto hybrid to normal (for lack of a better word) symbol. Looking into the 3D components, there was also a symbol within a symbol. Fixing this, seems to have fixed my problem. Thanks for the help, markdd.
I'll have you ask the original file owner... So I did notice that editing the 2D components had the same symbol within itself. I fixed that so now its only offsetting by 2 and not 3.... Is it possible its selecting the 2D and 3D objects? I would assume it would indicate 6 objects selected in the OIP and not the 3, which is expected.
No... That being said, I'm pretty certain it is in the symbol itself. The symbol was originally an auto-hybrid, however I tried to convert it to non auto-hybrid by copying ungrouping everything and copying the 2D and 3D parts.. Perhaps something went strange
I'm having an issue with numbering instruments in spotlight. For whatever reason, the lights do not properly increment from fixture to fixture. This has happened in multiple files, so perhaps its the symbol or maybe its a bug? Regardless, I'll include a video to show whats happening. You'll see that I set the channel to increment by 1 and the dmx address to increment by its footprint, which is 17.... VW Numbering Issue.mov
Figured it out.... Under Spotlight Preferences, the "Automatically assigning the class of all lighting instruments" was activated...
I'm experiencing a behavior that I haven't seen before. VW has created a class called "Symbol Name-..." and will not let me change the class for the symbol. It seems to be related to the specific document, when I create a new document and import the symbol, I can change the class freely. Any thoughts?
So I got this working... Thought I would share my steps. First, I created a folder called "Python Modules" and set it as a path in VW script options. I downloaded and copied Pydevd to the Python Modules Folder. Per, PyCharm instructions, I got the "pycharm-debug-py3k.egg" and copied it to the modules file, also. I created a PycharmDebug.py file that imports sys and appends the egg file to the path. In the script I want to debug, I add the following: import PycharmDebug import pydevd pydevd.settrace('localhost', port=1090, stdoutToServer=True, stderrToServer=True) With that in mind, I'm almost certain I made some unnecessary/extra steps. Any suggestions or thoughts would be helpful.
