Ferger
    7
Reputation
0 Neutral
Personal Information
  • Occupation
    Architect
  • Location
    Berlin, Maryland, USA
  1. I am working on a renovation to a small 2 story house using stories and levels as appropriately as I know how to. The stair to the 2nd floor was a straight run and worked when viewed in 3D. Client said they wanted and "L" stair, so I changed the parameters to a "L" configuration, which in the dialog box looked like it was working as it displayed 3D, but when I clicked OK and error was displayed and no stair as a result. So I want to another project in 2018 and created a "L" configured stair and it worked. I then converted that project to 2019 and that "L" stair is just line work. What gives?
  2. I'm having the same shoulder length problem as well, any update?
  3. Why is the scale of the hatch so small?
  4. What about walls render mode, Per Component? or Per Object? Ferger, VW2013
  5. I was and still am having problems with the fit to wall tool. I was having trouble with the roof cutting the gable wall, it would not do it until I had the wall on the same level as the roof. I still am having problems under a stair, some walls will fit to the stair others will not. Also, you can re-fit to walls, my stair configuration change and I just selected the wall to fit and they did. Ferger, using VW2013
  6. I am creating a custom title block for my firm to include my logo and have all the bells & whistles that VW2012 has to offer like the sheet name on the title block to coincide with the sheet layer name. I made some serious progress in getting a Title Block to look like I want and would like all the features that VW2012 has to work. So does this mean my sheet index and sheet layer will say "REFLECTED" instead of "REFLECTED CEILING PLAN" because it can't figure out how to wrap text and realize the text block perimeters????? What is the best or most correct way to do this? Is there some kind of work around?
  7. So, why can't this work??? I made some serious progress in getting a Title Block to look like I want and would like all the features that VW2012 has to work. So does this mean my sheet index and sheet layer will say "REFLECTED" instead of "REFLECTED CEILING PLAN" because it can't figure out how to wrap text and realize the text block perimeters?????
