jb.trystram
    8
Reputation
1 Neutral
Personal Information
  • Occupation
    designer
  • Homepage
    plugins-lab.com
  • Location
    germany, Berlin
Recent Profile Visitors
  1. A special class wich could be call Parent's class, also a class that give an object the class and so the Attribute of the object (group or Symbol for exemple) containing it. This exist already in many PIO. So i could, for exemple, create a Symbol of a table where the top platte have the Attribute of the symbol and so table with different top plate with only one Symbol.
  2. Struktural member tool There is a problem with the Profile that have be set. the PI retain the first item of the menu and not the ohne you choice. that's bad because it make the tool useless. anyway a great tool.
  3. it will be good to have Class 'parent class' so that objects take the class of the container (group, symbol, Plug-ins). this will be usefull by symbol. for exemple a chair with steel structure and a upholstery with parent's class that can be than change. or group with object with a fixed class (other objects have parent's class)
  4. when you want to modify a layers parameters or class attributes you have to go through dialog windows (1 or 2 depending if you go first in the organization window). make the change, then back to the drawing to see the change. If the line color dosen't look as nice as you thought for example you have to do it again. It take time and make fine tuning difficult. how it could be: when you select a class or a layer in the navigation palette (and you have no object selected), the info palette will show all characteristics of the class or layer and you can make change there and see directly the modification in the drawing. Arrows will allow to navigate through the class or layers. In the organization window, it should be possible to make some change directly in the liste (pull down menus, editable values etc). a preview button could be nice. VW Designer 14 + RW
  5. Hello! I just work at the website a bit, make some important change: - I lower the price. - Payment with payPal are possible.
  6. Hello ! I just finish a website where i propose VectorWorks plugins. More services will be proposed there very soon. Plugins-lab.com
  7. Hi, Sorry for the question. I found the answer and i am not proud of it. I just had interactiv scalling off !?! but i didn't remember to switch it off. and and restart VW. maybe it should be automatically being set on start?
  8. I made a 2D path PIO and as i wanted the path to be edited directly with the reshape tool or by double click i make the PIO events enabled and write all necessary to make it working: begin vsoGetEventInfo(theEvent, theButton); CASE theEvent OF {User has single-clicked the object's icon. } 5: ok := SetObjPropCharVS(3, Chr(3)); 3: BEGIN { ... the rest of the script} and it works fine. But by all other Pio that use Controlpoint have them not visible anymore. even the built-in one like callout tool. I'm not sure it come from my path object. I tried before to use CP and to hyde them on purpose but i didn't get it. it looks like i really get it now and that's very bad. Do i switch a VW behavior? Thanks for help VW designer 2014 mac
