Ilay
88 -
Posts posted by Ilay
Another additional question. I'm sorry Matt
Does it possible to install packages separately from package manager?
I save downloaded packages from temp directory.
I see that drag'n'drop to VW and install features were gone
Jim, thanks a'lot!
All works well!
Jim, no.
in mail:
We appreciate your interest in the Vectorworks? product line.We have received your request. Once approved, you will receive a follow-up email containing your serial number and download instructions for your trial.
If you have any questions about your trial please contact our technical support team at tech@vectorworks.net or 443-542-0411.
Best regards,
Nemetschek Vectorworks
and
at trial page
Unexpected Error.Our records indicate that your email address has already received an evaluation download and serial number of our software. Please call us at 410-290-5114.
maybe records from trial 2014?!
The trial has gone live! If you do not have Vectorworks Service Select and want to see what Vectorworks 2015 has for you, give it a spin:
Thanks
Still not have links in trial, anyway will refresh mail
Jim, thanks again
And please send it for development team too
Any word on improvements/upgrades to Landmark?+1
New Roadway and Grade Object ImprovementsNumerous improvements to Landmark and Spotlight vertical industry products
I must say: Thank you, Jim
i mean in VW 2015 directory:
- for old windows XP 32 bit OS - Vectorworks2015 32 bit.exe
- for newer windows 7-8.1 64 bit OS - Vectorworks2015 64 bit.exe
That is how it will be, yes. The installer will check which version of the OS you are running and install the appropriate one.
Thank you. Well-well we will see soon
Will the 64 bit version work on a 32 bit pc?
It will not, however this year there will be a 32bit Windows version as well as a 64bit Windows version.
Hello Jim
You mean VW 2015 still 32-bit or like c4d r13 with 2 executables in directory - CINEMA 4D.exe and CINEMA 4D 64 Bit.exe
or only compilation of VW2015 32 bit with switch to support more RAM
Super, thanks for info!
Hello Jim
Thank you for info
Bruce, look at http://forums.cgsociety.org/showpost.php?p=7883232&postcount=2
or full topic http://forums.cgsociety.org/showthread.php?f=47&t=1213399
Hello Wouter
Great tool!
I have question: has your tool feature to make gradient(different level between tie-in or pipes)?
Calculation of pipe dimensions based on user-input( from worksheet, symbol or manual input ).And with my first question, will it be into table data...dynamic data(pipe network and table specification) too?
Developers of Allplan 2015 made own(imho) real-time renderer(path-tracing closer), moved from c4d(i don't think that is IR renderer in c4d and somehow it was ported)
There is interesting, will VW moved to c4d r16 with new reflectance model of material, will be nice feature for engineers or metal designers, I remember Jim's chrome analysis
Or made something anything
I touch only vis and view-port interactive sides of VW
I am just getting into the demo of C4D, and I was wondering what C4D version does the majority of VW users use? the whole studio or Visualize?
Cheers,
Rob
I think it's cinerender bundle :cool:
Hi
Will it be a possible to add real-time rendering? or pre-visualization?
Of course if will be after 64-bit support to handle data in memory.
Utilize maybe via progressive physical render in c4d r15 or for fine work if possible to add support for otoy's brigade
Please give me 64bit multi-process-everything VW before September...
+1
I had project with massive landscaping for 32 hectares and modeling and positioning objects at it... loose more time with vw...sad time.
I also started work with cadline archilinexp 2014 version, it has support x64 architecture and 2 different viewport handling - openGL and directx. I combine my work in sketchup and archiline(it has direct export to skp format and cleaning features for making of low poly).
Currently have positive using of such pipeline.
Anyone else getting this prob?
I have not this at windows(8, x64)
But still have error after closing of app
Hello Vladislav
Thanks a'lot
Anyway can we use additional math/graphical libs as Numpy an etc.?
honestly i don't like such scheme*:
when a vsm, vsm, or vst runs, VW adds that folder to the python search path. So, when the scripts does 'import import ui.dlgHandler' the first thing python would do is to look for a folder 'ui' next to the vsm.Currently pyAPI has dependence from vwvs
* - hmm, that why i made several test project, and they did not work properly.
vs.Message('Hello')
returns the error:
Traceback (most recent call last):
File"", line 1, in
AttributeError: 'module' object has no attribute 'Message'
Any ideas?
Does it has reference to palette gui?, like c4d status
Hello Michael
Python works for me(win xp sp3 and 8), i download PythonSample_Menu2.
I test it(got errors), when i looked at code:
1. i put ui* dir to site-packages dir, because natively there is not such name of class in VW pyAPI
2. modify main(.py) fuction - this, adding execute() to end
* - dir from sample - PythonSample_Menu2\ui\
Hi to all
Jim, thanks!
I resolve this shutdown of app, also same happens if user changes default user dir in preferences
Single solution as Run as admin does not work. Also need to switch "windows xp sp3" * compatibility mode
* - i use it, seen that vs2005 libs during installation. Seems many companies switch to vs2012 for supporting of win8(-8.1)
(i'm sorry for my English)
Hello Jim
If you attempt to save a file, does it save properlyYes.
But when i try to close VW(windows controls of closing - X) after saving, it crashed
If i close by File > Quit - No crash.
Hi
I tried to report about this:
I download trial version - 2014
Has anybody such bug at windows(my OS - win8 x64):
1. It started normally.
2. Draw anything or install libraries.
3. Then save project(or not), then close VW(do not save) -> crashed.
I often read about sketchup here...
For example i know several architects from russian archicad forums, which used archicad for making of forms and documentation...but main modeling is in sketchup.
One of those architects wrote that archicad bim features limit his fantasy, imagination about finish of building.
I feel same with VW. It means simplicity of VW in workflow
Thanks a'lot for reply.
I understand.
I do not know for sure about Vectorworks 2015 as far as having different "flavors" for 32 and 64bit. (Even if I did I would unfortunately not be able to discuss it until it became official. No offense intended, policies and all that.)I'm sorry for asking(i forgot about nda of vw's roadmap)
But thank you and to your team for python bindings!
(can we also use cython in it's environment?)
VW 2015 Vectorworks Package Manager not downloading
in General Discussion
Posted · Edited by Ilay
There is no sign of responding...maybe, some how
