Ilay
88 -
Posts posted by Ilay
Hello
Still not have trial, yes i got message about approval of my request.
And i do not find sdk/manual for 2016. So, will Marionette have something like api? I see post about scripted interface for this tool?!
And http://www.vectorworks.net/support/online-help-system addressed to 2015 version
Yes, we will have it up and running later on today. We are working on it
Thank you!
I tried and always get step 4
Vectorworks Trial Version
Unexpected Error.
Our records indicate that your email address has already received an evaluation download and serial number of our software.
will reset cache of browser...
Upd.
after reseting similar error
Hello
Will be trial version?
No
It's add-on for Large Hadron Collider.
VW team get [anti]-matter of BIM!
about sketchup import.
c4d r17 got skp import(skp 2015 version too), but remesher is not so clean as in vw and can not convert skp's component to c4d's instance. But it also import camera and skp's curves
What's going with skp import in vw 2016?
Hello
Does possible to support pbs of RW by this http://www.maxon.net/en/news/singleview-default/article/cinema-4d-gets-native-support-for-allegorithmics-substance-technology.html
and like http://frostsoft.blogspot.co.uk/2015/04/pixelberg-update-release-14-b.html
pbs - physically based shading
Hello
If you have c4d, several versions how to do it:
1. using of bezier nurbs(this method is closer or similar for objects of VW)
2. or using of cloth simulation for modeling of such tent structure
It should export to C4D the same as a mesh object or NURBS (depending on the kind of shape you make) do now in Vectorworks 2015.
It simply reminds me work with mesh-cage/fdd modifiers
about second, i see situation that several teams move to use own solutions. For example Revit moved from nvidia mental ray/iray
Anyway thank you for answers and i'm sorry for English
Hello
Marionette will be cool thing!
Can we transfer object from subdivision tool as Subdivision/hypernurbs surface to c4d?
Also will VW team support RW/C4Dware? Or develop own ray-tracer, like allplan team or revit 2016 gave new ad's rt raytracer.
Strange.
Can't be a IFC version that is too new.
I check out via different ifc's analyzers/checkers/viewers, ifc file has a few issues in nodes of ifc specifications. I sent bug report to developers of another AEC app.
But of course wanted to know or look up to log, what does vw "dislike" in ifc file?!
Hello
How can i get more info or log why VW can not import IFC file?
I test export from one AEC app to VW
(win8x64 and vw 2015)
Hello Pat
Sorry for delay answer. My colleague and i solved problems by other tools.
Thank you for your tips
Another software tool made tooling path at unfolded, set position in cylinder coordinate system and drill away <- Boolean by driving path of drill
Sometimes it is easiest to make things similar to how they will really be machined. Other times it is easier to make a positive and subtract it as one piece.Yes, this part will be drill for oil-gas industry by cnc machine or something that.
(I'm sorry for my English)
Hello
Second variant, it will be to make by milling cutter from solid form.
I will prepare 3d model.
And i got model from my colleague. Look at step format(remove stl, leave as pick_up_barrel.stp) in attachment
Hello
Can VW to make such drill?
At unfolded from right side, 42 degree
or especially side holes drilled for bayonet?!
BaRa, you're wrong,we can use arch.tools and plug-ins in c4d
there are:
1. native new polypen tool in v.16 and snapping with guides
2. from Japanese developer - DragPrimitives/-Splines - example of solid wall -
web site - http://coffeestock.lk6.co/Blog/?page_id=19
3. or extensions from Caleidos4d - http://www.caleidos4d.it/plugin_cinema4d.htm#estensioni
Hello
i often meet such videos made in game engines or based at it, like Lumion. Architect prepared "volume", project docs in archicad, revit and etc., then made presentation by himself or by assistant-visualzer in lumion and speak with clients with showing of project's presentation.
I'm beginning rare to use C4D standalone in my works .
Before i used it for example to make organic forms with non-organic characteristics. Sample, need to make artificial rock-wall. I used sculpting and explode geometry by xPlode plug-in in c4d - It got form like if i used displacement but it was really realistic and procedural.
But today, game engine got physical based rendering(PBR), AO and etc. If needs flora - speedtree flora tech. in lumion - http://byzantos.com/speedtree/
http://byzantos.com/lumion-45-the-garden/
(i'm sorry for bad English)
What are you trying to do?
i'm rethinking model which has not thickness of wall, like paper.
Hi
Does possible to import mesh 2-sided materials from sketch-up?
I mean plane with 2 materials on it
upd.
Sorry i missed in manual
The SketchUp format supports materials on the front and back of each face of an object. When importing as 3D polygons, only the front material is assigned to the imported objects, as Vectorworks only supports one material for 3D polygons.When importing as architectural objects, both materials are imported and assigned to the imported objects, as Vectorworks supports several materials in this case.
Anyway Jim, there is interesting if Maxon made concept of future for CineWare(they pointed at product at their web page). Maybe they will include TR(TR client and server)...
or still will be CineRender, hmm
Would this time out on the Vectorworks Cloud?
Did you mean like Vectorworks Remote?
Will be nice to see local cloud for (cluster or peer-2-peer) rendering via TeamRender Server
But need to forget about wifi look at - http://www.c4dcafe.com/ipb/topic/84923-how-do-i-utilize-my-laptop-to-run-team-render-with-my-desktop/
Wouter, thank you!
(will be possible to compile for VW 2015, 64-bit?)
Hi
Does it possible to add source data from an external file - from sketchup guide points? For creation of land prototype
How to make in pic:
1. i add geo-location in sketchup, show 3d-layer with terrain data
2. unlock mesh, select and mark vertexes(put guide point) by sketchup plug-in - Fredo6 Tools - "mark vertices"
i add sketchup file too
I really like new help system... i have not love to adobe air based
I have not make complex project yet. All works well for me.
Congratulations to Jim and the NV Team!
in General Discussion
Posted
HL, I knew it. Jim, you show alien from another portal... from one sneak peak
Thanks a'lot to team!
