I am fairly new to worksheets and have not found any good tutorials so I have some questions.
1. How can you get a list of all the functions available to you for all the possible objects in VW. Example. The door ID tag, what is the worksheet function code to insert it into the database heading?
2. Can you have a database heading with a column that has no overall function and then insert custom manual information for each object in the database list. Example: I have a window schedule and I want to indicate what elevation the window is on, without using the user field data line. Can I manually input N,S,E,W in the column below the database header. I cannot seem to custom insert anything for any objects contained in a database.
3. Can you write an IF statement to assist with the above window problem. Example: I can return the ANGLE of the window and that angle can tell me N,S,E,or W. But Can I make a statement that says something like "=if ANGLE=90, VALUE=North"
4. I tried using the "within view" criteria for a database header, but it results in zero objects, yet I know there are doors and windows in the elevation that should come up. What am I doing wrong. I set the criteria to "location" "is within" "west elevation" (a saved view and viewport). Nothing comes up?
Thanks
JmacArch
VW 2013
Mac 10.8.4
