ubybc
  • Content Count
    45
Everything posted by ubybc
  1. thanks Justin, will try using the loci. the views that challenged me from your screenshot perspective were side L/R and top. Occasionally we floor support the truss vertically and leave the leg cart attached for logistics simpflication. In this case we would rotate the symbol and draw the 3D vertically and the view used would be top. When I was creating 2D for a hybrid version of this symbol, the challenge arose lining up the 2D to be symmetrical. I'll attempt editing the 3D myself and be sure to snap using the loci like you suggested. Appreciate the response!
  2. Using the Tyler Truss GT symbols in Spotlight and I found that the model appears to be incorrect regarding the Truss Cart Legs mounting tubes. The cut out for the leg insert is not symetrical/centered. This makes aligning the Truss and Legs symbols a bit challenging, especially in vertical deployments. Attached screenshots with the problem area highlighted in pink.
  3. Thanks, we'll try "all controls" setting change in System Prefs. hope it gets sorted out in next update. The team here would really like this resolved.
  4. For the Source 4 14deg, I was using the browser search function with the string "source 4 14" and and it was not showing up alongside the other results, but I did find it. Thanks for the direction. We are a SS member, so looking forward to the Chauvets, especially the Wellfit. I saw there was some Elation Protron models in the library so were happy to get this version when it's available. Thanks for the awesome work, much appreciated.
  5. its a Mac issue. Has been an issue for us since 2012. Save pallet positions does not work well, and if you nest the pallets it goes really wonky on you with dual monitors.
  6. We used to be able to tab through (advance to next text box) the data entry fields when entering titeblock info. The new 2019 spotlight titeblock settings data entry fields appear to be missing this functionality.
  7. yes please! some sort of click to rotate type focus tool, like the orbit tool. or a click to point and focus the fixture towards.
  8. I need of the following fixtures for VW 2019 spotlight. Thanks. Chauvet Wellfit Chauvet Colorado Solo Batten Elation Protron Eclypse ETC Source 4 14deg
  9. is there a workaround in place for the time being? Previously, the order was determined by the order within the data record? The new update seems to have randomized the order. Would be nice to have some way to order the entry fields as they appear in the titleblock.
  10. Be nice to get an update on the status of this request? This issue is a primary concern of our drawing team.
  11. I am currently using VW 2015 mostly on a Mac. I am assisting a Windows 7 user with a 2015 installation and when I am arranging tool palettes and move anywhere near the top of the workspace, the VW palettes are trying to snap to a new size across the entire workspace. This is really annoying? Anyway to stop the resize snapping, please... help? Also, anyway to get a similar workspace as with the Mac? I like being able to manage the palette positions over the entire screen and treat the workspace window as a separate entity. Thanks.
  12. I think the menus should be combined. I am selecting a color from the built in color palette.
  13. Is there a place here to post crash reports such as the one below for experts to comment on? VW crashes at least once a day for no real reason, even while drawing in small files. I'd like to know what I can do to help prevent it. Process: Vectorworks [1989] Path: /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/Vectorworks Identifier: net.nemetschek.vectorworks Version: 17.0.4 [162341] (17.0.4) Code Type: X86 (Native) Parent Process: launchd [150] Date/Time: 2012-09-05 15:32:02.702 -0500 OS Version: Mac OS X 10.7.4 (11E53) Report Version: 9 Interval Since Last Report: 114784 sec Crashes Since Last Report: 4 Per-App Interval Since Last Report: 34383 sec Per-App Crashes Since Last Report: 1 Anonymous UUID: 69D15C00-6EDE-40CF-BFD6-60ACB17FAAFB Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x00000000fffffffc VM Regions Near 0xfffffffc: --> shared memory 00000000ffff0000-00000000ffff2000 [ 8K] r-x/r-x SM=SHM Application Specific Information: objc[1989]: garbage collection is OFF Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libpskernel.dylib 0x042f5293 merge_domain + 1083 1 libpskernel.dylib 0x042f5fea DS__SA_alloc_generic + 86 2 libpskernel.dylib 0x042f2db9 DS__alloc_permanent_node + 633 3 libpskernel.dylib 0x0432f9f1 DS__alloc_node + 192 4 libpskernel.dylib 0x0432fb86 DS_alloc_node + 121 5 libpskernel.dylib 0x04346a81 MAK_plane + 143 6 libpskernel.dylib 0x041f721c PK_PLANE_create + 1256 7 net.nemetschek.vectorworks 0x0030b1f4 T3DSnapGeometry::CreateEntity() + 832 8 net.nemetschek.vectorworks 0x0030b7a7 T3DSnapGeometry::GetEntity() + 27 9 net.nemetschek.vectorworks 0x00317694 T3DSnapGeometries::T3DSnapGeometries(TransformMatrix const*) + 19302 10 net.nemetschek.vectorworks 0x00351df3 TSnapGeomManager::Push(TransformMatrix const&) + 117 11 net.nemetschek.vectorworks 0x003186d0 TSnapGeomState::TSnapGeomState() + 48 12 net.nemetschek.vectorworks 0x0033e800 GridPalette::LLPaletteGrid_D3PaletteGrid() + 180 13 net.nemetschek.vectorworks 0x00342179 GridPalette::LLPaletteGrid(WorldPt const&, ViewPt, unsigned char, TGripLocation*) + 437 14 net.nemetschek.vectorworks 0x00343a1d GridPalette::PaletteGrid(WorldPt const&, ViewPt, unsigned char, TGripLocation*) + 1839 15 net.nemetschek.vectorworks 0x00343c0c StdPaletteGrid(ViewPt const&, TGripLocation*) + 162 16 net.nemetschek.vectorworks 0x006fd8b6 TToolSystem::EnterToolContext(ViewPt const&) + 86 17 net.nemetschek.vectorworks 0x01315259 CoreHandleKeyDown(KeyboardManager::TKeyEvent const&, bool) + 3457 18 net.nemetschek.vectorworks 0x012eadd5 KeyboardManager::ReceiveKeyEvent(KeyboardManager::TKeyEvent const&, bool) + 25 19 net.nemetschek.vectorworks 0x00cbac23 TDocumentWindow::HandleKeyPress(EventRecord const&) + 211 20 net.nemetschek.vectorworks 0x00cbbc1d non-virtual thunk to TDocumentWindow::HandleKeyPress(EventRecord const&) + 29 21 net.nemetschek.vectorworks 0x00d04c0a PowerPlant::LCommander::ProcessKeyPress(EventRecord const&) + 70 22 net.nemetschek.vectorworks 0x00d04c36 PowerPlant::LCommander::HandleKeyPress(EventRecord const&) + 38 23 net.nemetschek.vectorworks 0x00d88610 TFloatingDatabar::HandleKeyPress(EventRecord const&) + 222 24 net.nemetschek.vectorworks 0x00d886b7 non-virtual thunk to TFloatingDatabar::HandleKeyPress(EventRecord const&) + 29 25 net.nemetschek.vectorworks 0x00d04c0a PowerPlant::LCommander::ProcessKeyPress(EventRecord const&) + 70 26 net.nemetschek.vectorworks 0x00d04c36 PowerPlant::LCommander::HandleKeyPress(EventRecord const&) + 38 27 net.nemetschek.vectorworks 0x00d17198 PowerPlant::LEditText::HandleKeyPress(EventRecord const&) + 1134 28 net.nemetschek.vectorworks 0x00cb6400 CEditText::HandleKeyPress(EventRecord const&) + 96 29 net.nemetschek.vectorworks 0x00cb993d TFloatingDatabarEditText::HandleKeyPress(EventRecord const&) + 259 30 net.nemetschek.vectorworks 0x00cb99e7 non-virtual thunk to TFloatingDatabarEditText::HandleKeyPress(EventRecord const&) + 27 31 net.nemetschek.vectorworks 0x00d04c0a PowerPlant::LCommander::ProcessKeyPress(EventRecord const&) + 70 32 net.nemetschek.vectorworks 0x00d13102 PowerPlant::LEventDispatcher::EventKeyDown(EventRecord const&) + 134 33 net.nemetschek.vectorworks 0x00d12d8a PowerPlant::LEventDispatcher::DispatchEvent(EventRecord const&) + 146 34 net.nemetschek.vectorworks 0x00cb383e TVectorWorksApp::DispatchEvent(EventRecord const&) + 194 35 net.nemetschek.vectorworks 0x00cb3777 non-virtual thunk to TVectorWorksApp::DispatchEvent(EventRecord const&) + 27 36 net.nemetschek.vectorworks 0x00cfe05e PowerPlant::LApplication::ProcessNextEvent() + 572 37 net.nemetschek.vectorworks 0x00cfe125 PowerPlant::LApplication::Run() + 103 38 net.nemetschek.vectorworks 0x00cb466a main + 104 39 net.nemetschek.vectorworks 0x00c6f376 start + 54 Thread 1:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x92fa790a kevent + 10 1 libdispatch.dylib 0x93df0e10 _dispatch_mgr_invoke + 969 2 libdispatch.dylib 0x93def85f _dispatch_mgr_thread + 53 Thread 2: 0 libsystem_kernel.dylib 0x92fa6ab6 __recvfrom_nocancel + 10 1 libsystem_kernel.dylib 0x92fa5536 recvfrom + 60 2 net.nemetschek.vectorworks 0x011708db TMacSocket::ReceiveFrom(TSocketMsg*, TSocketAddress&, bool&, long) + 119 3 net.nemetschek.vectorworks 0x0116d87c TSerialNumServer::ReceiveQuery(TSocket*, TSocketAddress&, bool*, unsigned short*) + 172 4 net.nemetschek.vectorworks 0x0116df0b TSerialNumServer::StartThread() + 365 5 net.nemetschek.vectorworks 0x0116d715 TSNEventHandler::~TSNEventHandler() + 53 6 com.apple.CoreServices.CarbonCore 0x961405e0 PrivateMPEntryPoint + 68 7 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 8 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 3: 0 libsystem_kernel.dylib 0x92fa4d36 mach_wait_until + 10 1 libsystem_c.dylib 0x90ed4439 nanosleep + 388 2 libsystem_c.dylib 0x90ed2cba usleep + 60 3 net.nemetschek.vectorworks.Renderworks 0x1b85b34c _melange_::GeSleep(long) + 115 4 net.nemetschek.vectorworks.Renderworks 0x1b858d44 _melange_::IpKillThread::Main() + 30 5 net.nemetschek.vectorworks.Renderworks 0x1b85b052 _melange_::BaseThread::Action() + 98 6 net.nemetschek.vectorworks.Renderworks 0x1b85b143 _ZN9_melange_L11BeginThreadEPv + 17 7 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 8 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 4:: jpegdecompress_MPLoop 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90ed282a pthread_cond_wait + 48 3 com.apple.QuickTimeComponents.component 0x98166553 0x97a58000 + 7398739 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 5:: jpegdecompress_MPLoop 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90ed282a pthread_cond_wait + 48 3 com.apple.QuickTimeComponents.component 0x98166553 0x97a58000 + 7398739 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 6:: jpegdecompress_MPLoop 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90ed282a pthread_cond_wait + 48 3 com.apple.QuickTimeComponents.component 0x98166553 0x97a58000 + 7398739 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 7:: jpegdecompress_MPLoop 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90ed282a pthread_cond_wait + 48 3 com.apple.QuickTimeComponents.component 0x98166553 0x97a58000 + 7398739 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 8:: jpegdecompress_MPLoop 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90ed282a pthread_cond_wait + 48 3 com.apple.QuickTimeComponents.component 0x98166553 0x97a58000 + 7398739 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 9:: jpegdecompress_MPLoop 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90ed282a pthread_cond_wait + 48 3 com.apple.QuickTimeComponents.component 0x98166553 0x97a58000 + 7398739 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 10:: jpegdecompress_MPLoop 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90ed282a pthread_cond_wait + 48 3 com.apple.QuickTimeComponents.component 0x98166553 0x97a58000 + 7398739 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 11: 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae78 _pthread_cond_wait + 914 2 libsystem_c.dylib 0x90f2af7b pthread_cond_timedwait_relative_np + 47 3 com.apple.CoreServices.CarbonCore 0x960dd3a7 TSWaitOnConditionTimedRelative + 178 4 com.apple.CoreServices.CarbonCore 0x960dd11d TSWaitOnSemaphoreCommon + 490 5 com.apple.CoreServices.CarbonCore 0x960dcf2e TSWaitOnSemaphoreRelative + 24 6 com.apple.QuickTimeComponents.component 0x98044516 0x97a58000 + 6210838 7 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 8 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 12: 0 libsystem_kernel.dylib 0x92fa4c5e semaphore_wait_trap + 10 1 com.apple.QuickTimeComponents.component 0x9851ff00 0x97a58000 + 11304704 2 com.apple.QuickTimeComponents.component 0x980b463d 0x97a58000 + 6669885 3 com.apple.QuickTimeComponents.component 0x9851fe33 0x97a58000 + 11304499 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 13: 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae21 _pthread_cond_wait + 827 2 libsystem_c.dylib 0x90edb42c pthread_cond_wait$UNIX2003 + 71 3 libpskernel.dylib 0x0619cb25 create_wrapper + 386 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 14: 0 libsystem_kernel.dylib 0x92fa683e __psynch_cvwait + 10 1 libsystem_c.dylib 0x90f2ae21 _pthread_cond_wait + 827 2 libsystem_c.dylib 0x90edb42c pthread_cond_wait$UNIX2003 + 71 3 libpskernel.dylib 0x0619cb25 create_wrapper + 386 4 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 5 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 15:: com.apple.CFSocket.private 0 libsystem_kernel.dylib 0x92fa6b42 __select + 10 1 com.apple.CoreFoundation 0x906c4e15 __CFSocketManager + 1557 2 libsystem_c.dylib 0x90f26ed9 _pthread_start + 335 3 libsystem_c.dylib 0x90f2a6de thread_start + 34 Thread 16: 0 libsystem_kernel.dylib 0x92fa702e __workq_kernreturn + 10 1 libsystem_c.dylib 0x90f28ccf _pthread_wqthread + 773 2 libsystem_c.dylib 0x90f2a6fe start_wqthread + 30 Thread 17: 0 libsystem_kernel.dylib 0x92fa702e __workq_kernreturn + 10 1 libsystem_c.dylib 0x90f28ccf _pthread_wqthread + 773 2 libsystem_c.dylib 0x90f2a6fe start_wqthread + 30 Thread 0 crashed with X86 Thread State (32-bit): eax: 0x0681a780 ebx: 0x042f4e66 ecx: 0xbfffb0dc edx: 0xfffffff8 edi: 0x00000000 esi: 0xffdb9010 ebp: 0xbfffb0f8 esp: 0xbfffb0a0 ss: 0x00000023 efl: 0x00010293 eip: 0x042f5293 cs: 0x0000001b ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f cr2: 0xfffffffc Logical CPU: 4 Binary Images: 0x1000 - 0x1fa5ffb +net.nemetschek.vectorworks (17.0.4 [162341] - 17.0.4) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/Vectorworks 0x2f17000 - 0x3407feb +libdcu2d57.dylib (??? - ???) <034A6CBF-AA1E-28E6-162F-DA6674D27354> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libdcu2d57.dylib 0x35c0000 - 0x35c5fff +libpsassemblyrep.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsassemblyrep.dylib 0x35ce000 - 0x36e1fef +libpsgeneric.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsgeneric.dylib 0x3766000 - 0x3788fe3 +libpsiges.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsiges.dylib 0x37b0000 - 0x37e1fdf +libpsinterop.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsinterop.dylib 0x3810000 - 0x3812fff +libpspropertiesbase.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpspropertiesbase.dylib 0x3819000 - 0x381cfff +libpspropertiesbrepimporter.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpspropertiesbrepimporter.dylib 0x3823000 - 0x396dfc3 +libpsxcore.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsxcore.dylib 0x3a3c000 - 0x3c0d037 +libpsxiges.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsxiges.dylib 0x3d36000 - 0x3dc4ff7 +libpsxlatorbase.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsxlatorbase.dylib 0x3e55000 - 0x3e7cff2 +libpsxmil.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpsxmil.dylib 0x3e9d000 - 0x67a2ffb +libpskernel.dylib (24.0.0 - compatibility 24.0.0) <7F9B61B8-4787-A340-2AD6-9B4CC74C8599> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libpskernel.dylib 0x68f0000 - 0x727e1f3 +libPDFNetC.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libPDFNetC.dylib 0x7723000 - 0x7760fff +libHSIMac.dylib (??? - ???) <3604CC43-6C1B-438A-681E-E2391C865A3B> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libHSIMac.dylib 0x778a000 - 0x778cfff com.apple.ExceptionHandling (1.5 - 10) <7C514CC4-7951-31CA-AEB3-D4AF49F44AE7> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling 0x7792000 - 0x7796ff7 +libZipArchive.dylib (??? - ???) <0F0F2B76-B87F-4625-F6B5-31017565DC2E> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libZipArchive.dylib 0x779b000 - 0x779efff +com.yourcompany.VWMM (1.0 - 1) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/VWMM.framework/Versions/A/VWMM 0x7dce000 - 0x7dcfff0 +cl_kernels (??? - ???) cl_kernels 0x7ff8000 - 0x7ff9ffc +SketchUp (??? - 0.0.1d1) <35687321-0B10-F904-3BA8-16D7E4CEC027> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/SketchUp 0xbaf5000 - 0xbafaffb +libgif.4.dylib (6.6.0 - compatibility 6.0.0) <64758051-B3FF-DEF5-E94C-8EDA7C9D7049> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/libgif.4.dylib 0xbcf2000 - 0xbcf3ff1 com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings 0x10da1000 - 0x10dceff8 GLRendererFloat (??? - ???) <70ADE58D-B399-3279-9774-2D5929D5FCB1> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat 0x127ab000 - 0x127adffd com.apple.PDFImporter (2.2 - ???) <97B2F1FB-8D5F-3F55-A071-736C41662BC4> /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter 0x127d1000 - 0x127f2fff +com.adobe.ICUData (3.4 - 3.41) <0FFCAE98-2B47-C298-ACE2-03D28F90214F> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/ICUData.framework/Versions/3.6/ICUData 0x13000000 - 0x1316dffb GLEngine (??? - ???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine 0x131a1000 - 0x13298ffb libGLProgrammability.dylib (??? - ???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x132bc000 - 0x1355dfe7 com.apple.ATIRadeonX3000GLDriver (7.18.18 - 7.1.8) <2CA55B8F-F4A4-3421-B92C-BB5FE4413850> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLDriver 0x1358e000 - 0x13925fef com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.18.18 - 7.1.8) /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver 0x13af2000 - 0x13af7fe2 libcldcpuengine.dylib (1.50.69 - compatibility 1.0.0) <864BA467-5F11-3B41-B261-894067B8209E> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib 0x13afe000 - 0x13afeffb +cl_kernels (??? - ???) cl_kernels 0x13e00000 - 0x13ec3ff3 +net.nemetschek.vectorworks.3DS_Library (??? - 1.0) <153A430F-1EEA-E917-D6C7-BA91A7E898E7> /Applications/Vectorworks 2012/*/3DS Library 0x13f57000 - 0x13f98ff3 +net.nemetschek.vectorworks.AlignDistribute (??? - 1.0) <67D0C389-BA65-D4D7-7460-D0119A0EFD92> /Applications/Vectorworks 2012/*/AlignDistribute 0x13fb9000 - 0x141c9ff3 +net.nemetschek.vectorworks.ArchitecturalObjects (??? - 1.0) /Applications/Vectorworks 2012/*/ArchitecturalObjects 0x142ed000 - 0x14324ffb +net.nemetschek.vectorworks.TesterModule (??? - 1.0) <10B2AA9B-1CEB-49A6-0373-425BBF2EE259> /Applications/Vectorworks 2012/*/CheckForUpdates 0x1434e000 - 0x14422ffb +net.nemetschek.vectorworks.ColorPalettes (??? - 1.0) <65DD594A-899D-D053-A3D5-2695F8B5B396> /Applications/Vectorworks 2012/*/ColorPalettes 0x144b4000 - 0x14672ffb +de.computerworks.vectorworks.CWLibraryUniversal1 (D17.0.0 R1 [12203] - 1.0) <892BD55B-666A-8A35-58EC-F72FDA89F7B5> /Applications/Vectorworks 2012/*/CWLibraryUniversal1 0x147f1000 - 0x149b4ffb +de.computerworks.vectorworks.Durch Symbol ersetzen CW (D17.0.0 R1 [11536] - 1.0) <0A96F5C0-24E2-9BEF-D069-B726383F224C> /Applications/Vectorworks 2012/*/Durch Symbol ersetzen CW 0x14b3a000 - 0x1681cfe3 +net.nemetschek.vectorworks.DWG_Library (??? - 1.0) /Applications/Vectorworks 2012/*/DWG Library 0x17f05000 - 0x17f3bfff +net.nemetschek.vectorworks.EditShader (??? - 1.0) <21EFB909-3033-5FC3-2B07-4D89EF2657E4> /Applications/Vectorworks 2012/*/EditShader 0x17f58000 - 0x18014ff7 +net.nemetschek.vectorworks.Fundamentals (??? - 1.0) /Applications/Vectorworks 2012/*/Fundamentals 0x180a7000 - 0x1819dffb +net.nemetschek.vectorworks.GeometryLib (??? - 1.0) <7ABF0674-A52D-ED0A-F628-CF4E3FF75066> /Applications/Vectorworks 2012/*/GeometryLib 0x1821f000 - 0x18659ff3 +net.nemetschek.vectorworks.GIS (??? - 1.0) <2F9A1467-9767-522F-EC09-38D787B6208F> /Applications/Vectorworks 2012/*/GIS 0x18942000 - 0x18bf8fff +net.nemetschek.vectorworks.IFCLibrary (??? - 1.0) <8F8EB64E-ECC0-9A0A-4664-ABF5CC2809B0> /Applications/Vectorworks 2012/*/IFCLibrary 0x18db4000 - 0x18e50fff +net.nemetschek.vectorworks.PDFUtilityLib (??? - 1.0) /Applications/Vectorworks 2012/*/PDFUtilityLib 0x18eb0000 - 0x18ff2fff +DL90ACE (90.1.9 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90ACE.framework/Versions/A/DL90ACE 0x19040000 - 0x190b1fc0 +DL90AdobeXMP (90.1.4 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90AdobeXMP.framework/Versions/A/DL90AdobeXMP 0x190df000 - 0x196a1fc7 +DL90AGM (90.1.12 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90AGM.framework/Versions/A/DL90AGM 0x19a3c000 - 0x19a82fe9 +DL90ARE (90.1.5 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90ARE.framework/Versions/A/DL90ARE 0x19abb000 - 0x19ae2fd2 +DL90AXE8SharedExpat (90.1.6 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90AXE8SharedExpat.framework/Versions/A/DL90AXE8SharedExpat 0x19af6000 - 0x19b0ffff +DL90BIB (90.1.4 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90BIB.framework/Versions/A/DL90BIB 0x19b2f000 - 0x19b4efff +DL90BIBUtils (90.1.4 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90BIBUtils.framework/Versions/A/DL90BIBUtils 0x19b73000 - 0x19e4dfc7 +DL90CoolType (90.1.4 - compatibility 90.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90CoolType.framework/Versions/A/DL90CoolType 0x1a029000 - 0x1a0e6ff2 +DL90JP2KLib (90.1.5 - compatibility 90.0.0) <280823AF-2E07-41FB-AEE9-2C48CEFD4AB5> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90JP2KLib.framework/Versions/A/DL90JP2KLib 0x1a11f000 - 0x1a84bfef +DL90PDFL (90.1.17 - compatibility 90.0.0) <2014EE1C-2BD9-4155-A1C7-05DAF8F41971> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/DL90PDFL.framework/Versions/A/DL90PDFL 0x1ac43000 - 0x1acd4ffb +com.adobe.ICUConverter (3.4 - 3.41) <6948908A-AE5F-FD99-1431-688F4E9B3D44> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/ICUConverter 0x1acf3000 - 0x1aea6ff3 +de.computerworks.vectorworks.Pflanze VBvisual CW (D17.0.0 R1 [11536] - 1.0) <916DD0DA-D54B-2E40-9F05-4D0ABBED11B3> /Applications/Vectorworks 2012/*/Pflanze VBvisual CW 0x1b01d000 - 0x1b113fef +net.nemetschek.vectorworks.Plug_In_Support (??? - 1.0) <38DB90AC-8AD5-EB2E-7B3F-8C7B63E2CD95> /Applications/Vectorworks 2012/*/Plug-In Support 0x1b183000 - 0x1b4e1ff7 +de.computerworks.vectorworks.Raum CW (D17.0.0 R1 [12800:12801] - 1.0) <41E2E3D0-3996-F270-AF41-177E580FA9CD> /Applications/Vectorworks 2012/*/Raum CW 0x1b6e6000 - 0x1b719ffb +net.nemetschek.vectorworks.RenderSettings (??? - 1.0) /Applications/Vectorworks 2012/*/RenderSettings 0x1b735000 - 0x1b8d8ffb +net.nemetschek.vectorworks.Renderworks (??? - 1.0) <2ED2F434-93AF-0E14-F4FE-CE876CE5CCEE> /Applications/Vectorworks 2012/*/Renderworks 0x1b9aa000 - 0x1babefff +net.nemetschek.vectorworks.SpotlightModule (??? - 1.0) <830459DA-AB50-4DDB-AF5E-6F3B98E160F2> /Applications/Vectorworks 2012/*/Spotlight 0x1bb8f000 - 0x1bc62fff +net.nemetschek.vectorworks.SU2VWLib (??? - 1.0) <3E8509BE-CF7F-5D94-D24E-21F40ED0EF56> /Applications/Vectorworks 2012/*/SU2VWLib 0x1bd2c000 - 0x1bfdefec +SketchUpReader (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUpReader.framework/Versions/A/SketchUpReader 0x1c149000 - 0x1c163ffc +libjpeg.62.dylib (63.0.0 - compatibility 63.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/libjpeg.62.dylib 0x1c16a000 - 0x1c1a0fff +libpaintlib.1.dylib (2.0.0 - compatibility 2.0.0) <621DD32B-3C0D-79A7-B9FD-B8A69D32C7D8> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/libpaintlib.1.dylib 0x1c1c3000 - 0x1c216fef +libtiff.3.dylib (13.2.0 - compatibility 13.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/libtiff.3.dylib 0x1c21e000 - 0x1c23eff3 +libCommonUtils.dylib (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/libCommonUtils.dylib 0x1c253000 - 0x1c46bfc7 +Xerces (??? - ???) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces 0x1c6a4000 - 0x1c6c5ff3 +libpng12.0.dylib (45.0.0 - compatibility 45.0.0) <94045094-6A4B-765A-65F4-810C817AE4F9> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/libpng12.0.dylib 0x1c6cc000 - 0x1c6faff0 +libGeometrySU.dylib (??? - ???) <45EA32C7-964F-0528-C7DF-AD6F28E45C97> /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/Frameworks/SketchUp.framework/Versions/A/libGeometrySU.dylib 0x1c712000 - 0x1ca6fffb +net.nemetschek.vectorworks.Support (??? - 1.0) /Applications/Vectorworks 2012/*/Support 0x1cd03000 - 0x1cd3cffb libiodbc.2.dylib (4.18.0 - compatibility 4.0.0) <51AD48FC-F152-30D0-AB04-5197A5244B53> /usr/lib/libiodbc.2.dylib 0x1cd49000 - 0x1d12bff7 +de.computerworks.vectorworks.Treppen (D17.0.0 R1 [12203:12204] - 1.0) /Applications/Vectorworks 2012/*/Treppen 0x1d35f000 - 0x1d3d8ff3 +net.nemetschek.vectorworks.TrueType (??? - 1.0) <691F9F1D-369C-2F74-EE4F-F6BE9A17245B> /Applications/Vectorworks 2012/*/TrueType 0x1d429000 - 0x1d45dff3 +net.nemetschek.vectorworks.UpdateCheck (??? - 1.0) <11620A55-B9E1-E33C-E879-DE792CD5C201> /Applications/Vectorworks 2012/*/UpdateCheck 0x1d47c000 - 0x1d4bbffb +libcurl.dylib (6.0.0 - compatibility 6.0.0) /Applications/Vectorworks 2012/Vectorworks 2012.app/Contents/MacOS/libcurl.dylib 0x1d4c5000 - 0x1d508fff +net.nemetschek.vectorworks.VectorScriptEditor (??? - 1.0) /Applications/Vectorworks 2012/*/VectorScriptEditor 0x1d52e000 - 0x1d56cff7 +net.nemetschek.vectorworks.VS_Shared_Library (??? - 1.0) /Applications/Vectorworks 2012/*/VS Shared Library 0x1d58d000 - 0x1d5bdffb +net.nemetschek.vectorworks.VWLibrary (??? - 1.0) /Applications/Vectorworks 2012/*/VWLibrary 0x1d5d7000 - 0x1d639ffb +net.nemetschek.vectorworks.WebServices (??? - 1.0) <902B480D-EE6A-D9AA-D350-C0585DE9EB6D> /Applications/Vectorworks 2012/*/WebServices 0x1d671000 - 0x1d6ecfff +net.nemetschek.vectorworks.Workspaces (??? - 1.0) <2313F541-8E1F-9508-5C87-FE275AB4C9CA> /Applications/Vectorworks 2012/*/Workspaces 0x1d7f4000 - 0x1d7f6fff libCoreFSCache.dylib (??? - ???) <5B141DE1-6FC9-3155-833B-23A447A598AB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x1d7fd000 - 0x1d7feff6 +cl_kernels (??? - ???) <12F489FD-0A16-42AB-AFB7-2DFC4C85338F> cl_kernels 0x1ec1f000 - 0x1ec31fff libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib 0x1ec66000 - 0x1ec66ffb +cl_kernels (??? - ???) <7802873B-0BD9-4A5A-9CCE-9D0C968CD4E1> cl_kernels 0x1ec7c000 - 0x1ec7cff3 +cl_kernels (??? - ???) cl_kernels 0x1ed1e000 - 0x1ed58fff +net.nemetschek.vectorworks.MovePage (??? - 1.0) /Applications/Vectorworks 2012/*/MovePage 0x1ed77000 - 0x1eda7ffb +net.nemetschek.vectorworks.SU2VW (??? - 1.0) <92ACFA51-D2EB-AB77-500E-A86E084A1DFA> /Applications/Vectorworks 2012/*/SU2VW 0x1ef69000 - 0x1efacff7 +net.nemetschek.vectorworks.CeilingGrid (??? - 1.0) <0FDAC999-A0EA-0085-3FA9-AE49B6D4B99C> /Applications/Vectorworks 2012/*/CeilingGrid 0x1efd0000 - 0x1f008ff3 +net.nemetschek.vectorworks.DesignLayerViewport (??? - 1.0) <399BC898-CF8A-B3EE-CD17-4C6BB311509C> /Applications/Vectorworks 2012/*/DesignLayerViewport 0x1f027000 - 0x1f035ffb libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <4378B89F-0BDA-3072-9C67-DE1A371DD816> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib 0x1f1da000 - 0x1f21bff7 +net.nemetschek.vectorworks.ExtrudeAlongPath (??? - 1.0) /Applications/Vectorworks 2012/*/ExtrudeAlongPath 0x1f23d000 - 0x1f276fff +net.nemetschek.vectorworks.HelixSpiral (??? - 1.0) <77CCEEAA-133A-BEF7-09D6-B8AB9201AC06> /Applications/Vectorworks 2012/*/HelixSpiral 0x1f2b5000 - 0x1f2b9ffb com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn 0x1f2f3000 - 0x1f3ddfff +net.nemetschek.vectorworks.Callout_Tool (??? - 1.0) <9FCC504F-8C50-EA9F-1D88-F3AF7EE828CD> /Applications/Vectorworks 2012/*/Callout Tool 0x1f489000 - 0x1f4e0ff7 +net.nemetschek.vectorworks.Eyedropper_Tool (??? - 1.0) <14220779-1E48-378F-D636-A1752219B01C> /Applications/Vectorworks 2012/*/Eyedropper Tool 0x1f50f000 - 0x1f549ffb +net.nemetschek.vectorworks.Trim_Tool (??? - 1.0) /Applications/Vectorworks 2012/*/Trim Tool 0x1f57c000 - 0x1f5beff7 +net.nemetschek.vectorworks.PDFPage (??? - 1.0) <15673B77-368D-B7DD-1832-D46FF327727A> /Applications/Vectorworks 2012/*/PDFPage 0x1f800000 - 0x1f8feff3 +net.nemetschek.vectorworks.Callout (??? - 1.0) <57C779B5-FAE3-963F-9C3E-F5E436E32284> /Applications/Vectorworks 2012/*/Callout 0x1f9b8000 - 0x1faa1fff +net.nemetschek.vectorworks.FramingMember (??? - 1.0) <35593E53-C345-9D7C-2F44-45069C45CB17> /Applications/Vectorworks 2012/*/FramingMember 0x1fb4b000 - 0x1fc34fff +net.nemetschek.vectorworks.General_Notes (??? - 1.0) /Applications/Vectorworks 2012/*/General Notes 0x1fcde000 - 0x1fdefff7 +net.nemetschek.vectorworks.HumanFigure (??? - 1.0) /Applications/Vectorworks 2012/*/HumanFigure 0x1fe95000 - 0x1ff9cffb +net.nemetschek.vectorworks.IFCEntity (??? - 1.0) <6ED3FA6B-F3DE-E592-5418-3AE858AA808E> /Applications/Vectorworks 2012/*/IFCEntity 0x20068000 - 0x2014bffb +net.nemetschek.vectorworks.Keynote_Legend (??? - 1.0) <18A0C43F-F5C7-128C-F34F-9C8D67E4044C> /Applications/Vectorworks 2012/*/Keynote Legend 0x201f2000 - 0x20222ffb +net.nemetschek.vectorworks.SectionLine (??? - 1.0) <1B4C1C92-CBAA-42D4-29FF-98BF6F9B8FE2> /Applications/Vectorworks 2012/*/SectionLine 0x2023c000 - 0x20286ff7 +net.nemetschek.vectorworks.TaperedExtrude (??? - 1.0) <5335F9A1-5411-55DA-82F2-D35FDB926FF0> /Applications/Vectorworks 2012/*/TaperedExtrude 0x202a9000 - 0x202eafff +net.nemetschek.vectorworks.TextAlongPath (??? - 1.0) <417434CD-1248-53CF-9482-5F9B367E9A4A> /Applications/Vectorworks 2012/*/TextAlongPath 0x2030d000 - 0x2034eff3 +net.nemetschek.vectorworks.Textured_Prop (??? - 1.0) <43B5215E-A98F-8B66-C490-B33B007EA8E5> /Applications/Vectorworks 2012/*/Textured Prop 0x20370000 - 0x203c7ff3 +net.nemetschek.vectorworks.Offset_Tool (??? - 1.0) <83FEC643-9620-3F3E-45B6-BCF49CF7D9B4> /Applications/Vectorworks 2012/*/Offset Tool 0x20500000 - 0x20673ffb +net.nemetschek.vectorworks.Select_Similar (??? - 1.0) <30057C2E-B1F5-B528-6432-AFF2157C0DEC> /Applications/Vectorworks 2012/*/Select Similar 0x20729000 - 0x20764ff3 +net.nemetschek.vectorworks.Shear (??? - 1.0) /Applications/Vectorworks 2012/*/Shear 0x20783000 - 0x207bfffb +net.nemetschek.vectorworks.Resize (??? - 1.0) <97D906CA-F85D-3308-E023-077FB4986791> /Applications/Vectorworks 2012/*/Resize 0x207de000 - 0x20818ff7 +net.nemetschek.vectorworks.TapeMeasureTool (??? - 1.0) <42A79115-7C6D-2314-E49E-66BCFEE8D21D> /Applications/Vectorworks 2012/*/TapeMeasureTool 0x20837000 - 0x20875fff +net.nemetschek.vectorworks.Protractor_Tool (??? - 1.0) <28886CE9-DA17-A015-8EAE-517A42EC1BFB> /Applications/Vectorworks 2012/*/Protractor Tool 0x20895000 - 0x208d2ffb +net.nemetschek.vectorworks.Duplicate_Symbol_In_Wall (??? - 1.0) <348D8787-8378-91A3-36DB-C8DB296686D9> /Applications/Vectorworks 2012/*/Duplicate Symbol In Wall 0x2093a000 - 0x20a1affb +net.nemetschek.vectorworks.General_Notes_Tool (??? - 1.0) <65DAA06F-40D8-3515-AFC8-6E5F0C7FB6F8> /Applications/Vectorworks 2012/*/General Notes Tool 0x20b56000 - 0x20c15fff +net.nemetschek.vectorworks.3DS_Import (??? - 1.0) <452BA240-8E4C-66C5-96AE-D51A271CC8C8> /Applications/Vectorworks 2012/*/3DS Import 0x20ca5000 - 0x20d65ff7 +net.nemetschek.vectorworks.3DS_Export (??? - 1.0) <9AC75480-307E-FFC8-8E66-40BAFA5471DB> /Applications/Vectorworks 2012/*/3DS Export 0x20df5000 - 0x20e25fff +net.nemetschek.vectorworks.Fit_To_Objects (??? - 1.0) <725F773A-41A5-C8F4-F6A1-F92D3F0A19F3> /Applications/Vectorworks 2012/*/Fit To Objects 0x20e3f000 - 0x20e78fff +net.nemetschek.vectorworks.AlignLayerViews (??? - 1.0) <90E4F137-4027-0BB9-C583-225AAA7BA058> /Applications/Vectorworks 2012/*/AlignLayerViews 0x20e97000 - 0x20ee6ff7 +net.nemetschek.vectorworks.ExtrudeAlongPathMenu (??? - 1.0) <52974D46-4E1C-E0D1-557E-10DDDD48159D> /Applications/Vectorworks 2012/*/ExtrudeAlongPathMenu 0x20f0c000 - 0x20f52ffb +net.nemetschek.vectorworks.TaperedExtrudeMenu (??? - 1.0) <86A82719-D396-8BB4-30D4-BD74698EF7B3> /Applications/Vectorworks 2012/*/TaperedExtrudeMenu 0x20f75000 - 0x20faeff7 +net.nemetschek.vectorworks.HelixSpiralMenu (??? - 1.0) <3C4DDF01-F0EB-55AC-D39A-451E3EC7FC89> /Applications/Vectorworks 2012/*/HelixSpiralMenu 0x20fcd000 - 0x2100fff3 +net.nemetschek.vectorworks.Export_Quicktime_Movie (??? - 1.0) /Applications/Vectorworks 2012/*/Export Quicktime Movie 0x21034000 - 0x2106fff7 +net.nemetschek.vectorworks.Orbit_Animator (??? - 1.0) /Applications/Vectorworks 2012/*/Orbit Animator 0x21090000 - 0x210e1ffb +net.nemetschek.vectorworks.Path_Animator (??? - 1.0) <37E5E5D4-ECAF-4B92-278A-3853B907D526> /Applications/Vectorworks 2012/*/Path Animator 0x2110d000 - 0x2114cfff +net.nemetschek.vectorworks.Roofer (??? - 1.0) /Applications/Vectorworks 2012/*/Roofer 0x2116c000 - 0x21227fff +net.nemetschek.vectorworks.Workspace_Editor (??? - 1.0) /Applications/Vectorworks 2012/*/Workspace Editor 0x21300000 - 0x21365ff7 +net.nemetschek.vectorworks.CheckSpelling (??? - 1.0) <70C09B95-EAE0-41C9-5E06-820FB1347EA1> /Applications/Vectorworks 2012/*/CheckSpelling 0x21390000 - 0x213ccfff +net.nemetschek.vectorworks.TrueType_To_Polyline (??? - 1.0) /Applications/Vectorworks 2012/*/TrueType To Polyline 0x213ed000 - 0x2143cff7 +net.nemetschek.vectorworks.TextAlongPathMenu (??? - 1.0) /Applications/Vectorworks 2012/*/TextAlongPathMenu 0x21462000 - 0x21576fff +net.nemetschek.vectorworks.Notes_Manager_Menu (??? - 1.0) <18C99A25-74BE-DAA5-33A2-8872E4AFCFAA> /Applications/Vectorworks 2012/*/Notes Manager Menu 0x21642000 - 0x21673ff3 +net.nemetschek.vectorworks.Guides (??? - 1.0) /Applications/Vectorworks 2012/*/Guides 0x224ec000 - 0x224f3ffe com.apple.AppleGVAHW.component (1.0 - 1) /System/Library/QuickTime/AppleGVAHW.component/Contents/MacOS/AppleGVAHW 0x22600000 - 0x2269fff7 unorm8_rgba.dylib (1.50.69 - compatibility 1.0.0) <3A06E8EA-0335-348A-BCCB-21C3E94AED31> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_rgba.dylib
  14. I want the 2D to remain flat for a simple 2D plot. The 3D plot could be shown using the 3D orientation of symbols. That way you can have both. NO need for 2D to rotate or angle in 3D space.
  15. Seems silly to have to navigate between the OIP, Edit Light, and Edit menus to change parameters for lights.
  16. Thanks MichaelK, but I already know how to do that, and your suggestion has no real bearing on my issue. The color is already in the OIP, but it remains plan white in the render.
  17. I selected a blue color from the drop down, and then tried a pink. No change. Can you also help explain why when I select a light fixture, right click, there are two edit options. "edit", and "edit light" They both have their own field for color? These menu's should be combined...just a suggestion. thanks for the quick response with my issue.
  18. Can anyone please tell me why when I right click a light, select "edit" and change the color the light remains white when I render?
  19. Seems to be already incorporated into the truss tool and instruments tools. Why not apply this conceptually to the entire program? All hybrid symbols 2D stays in place regardless of what you do to the 3D orientation of the symbol. VW is a 3D drawing program. You should be able to rotate, spin and control every symbol or primitive with just a mouse like you can in Cinema4D. This seems like it would be a critical improvement to the software. Am I alone here?
  20. Thanks so much for the file. I find it pretty silly that we are forced to........ "You are better off creating your own light objets for rendering purposes." Whats the point of buying a self contained light designer application that doesn't have a complete library of working lights?
  21. When I enter an extrude to edit a 3D shape the other drawing elements are greyed out and I can easily still snap to them moving vertices with the reshape tool. When I got to my next 3D object to reshape all the other drawing elements disappear and I have no reference for snapping or editing the 3D shape. Whay does one edit extrude show the rest of the drawing while another one on the same layer, same class does not? thanks......
  22. I insert a fixture into a drawing. I change to a 3D view I use the OIP to rotate a Colorblaze or IBeam to the desired hanging angle. The fixtures rotate but the clamps in the symbol stay put? This looks really odd when a fixture is correctly rotated 180 degrees and the clamp is 12" off in the space opposite the fixture floating in mid air. Any ideas? or just "another" VW bug..... BTW - the colorblaze 72" does not turn on or show any light in renders.
