54 -
Everything posted by Ben Wingrove
I often open a worksheet in a floating window whilst checking stuff in a drawing, it would be nice if there was a minimise button similar to the resource browser so I can get it out of the way whilst I am going back and forwards between the drawing and the worksheet. Its ok when I am on my big monitor but is a pain when working on my laptop. Thanks B
Turning Off Classes in Worksheet Images
Ben Wingrove replied to Chris Busch's question in Troubleshooting
Has this been fixed in vwx 2023? -
I am trying to export an MVR from Spotlight 2022 in to L8, We have 20 "Pods" made up of truss and lighting fixtures that we have in our drawing as referenced viewports to allow us to hang them at various angles. When I export the MVR it exports the "Pods" in the correct positions but each viewport is exported as one piece of geometry fixtures included. Is there any workaround for this? Thanks B
Disappearing hanging position elements
Ben Wingrove replied to livespace josha's question in Troubleshooting
Any Fix to this? I am also having the same issue. As soon as I create an object to a hanging position certain elements of the truss disappear! -
Pulling Data from Title Block Borders into Worksheets
Ben Wingrove replied to Andy Broomell's topic in General Discussion
Definitely +1 on this.- 26 replies
- 1
- drawing schedule
- sheet list
(and 3 more)
Tagged with:
Has this been fixed in vwx 2022? -
Is it possible to change the revision/issue data stacking order so the latest is at the top, if I turn on the "Up Page" option it just creates from the text point up which doesn't help, I would like it to appear as it does in the Title Block Manager window. Thanks
Spotlight Lighting Device input flipped between 2D and 3D
Ben Wingrove posted a question in Troubleshooting
In Spotlight the red box indicating the input is on opposite sides between the 2D and 3D view dependent on how the 3D model is rotated. Whilst I appreciate the "Custom Plan Rotation" option is there any way of auto aligning the inputs to avoid confusion. Thanks -
symbol for substractions
Ben Wingrove replied to Bas Vellekoop's question in Wishlist - Feature and Content Requests
Did this ever get looked in to? I could really do with this functionality right now! -
Slicing Sphere causing strange results!
Ben Wingrove replied to Ben Wingrove's question in Troubleshooting
The problem occurred when cutting the last few segments, it seemed Vectorworks felt there was no sphere there to cut, it showed up in the Open GL view but the slice tool had no affect! -
I was trying to slice a sphere in to equal segments, as you do on a Thursday morning. I came across a strange phenomenon! I used the split tool in equal increments starting from the middle of the sphere and working upwards the sphere started "collapsing" on its self. I have attached some screen shots to try and explain, I am using 2020 SP 2.1 is this a known issue? I found a work around by starting my trimming exercise from the top to the middle and then copying and flipping the results for the lower half. Happy Spherical slicing day Ben
Is there any way to use layer tags as a worksheet criteria? We have a main inventory on our front page that auto counts symbols of all different types with different records attached. When we duplicate a layer to try a different symbol layout or show a second position on worksheets our worksheet then adds all these duplicate fixtures. Rather than going in to the worksheet and setting each criteria to ignore the new layers (there are a lot) it would be nice to say to ignore all layers with a certain tag, lets say an "Ignore" tag. Is this possible or failing that does anyone have any cunning ways of accomplishing the same result. Thanks Ben
I have just wasted at least 2 hrs trying to arrange sheets ready for publishing, we have a drawing with 26 sheets, and I am spending at least 25% of my time looking at a spinning ball!! It has taken me 20 minutes to arrange 4 very basic viewports and update text. It feels as every mouse click initiates a wait sequence of spinning ball and fans spinning at top speed. Is there a process for having drawings analyzed for problems?
If I use an AppleScript to detect the new file and then get the file name as a variable can I then pass that to a vector script?
We have a powerful machine in our office we would like to use for doing our publishing so we can free up resources on our personal machines. We are using a piece of software that looks for new files in a folder and then runs a script on discovery. Our ideal workflow would be to send a vwx file to this watch folder over the network and then when it is discovered it opens in vwx, vwx then does a publish to a set folder and then closes the vwx file. Is this even possible any tips would be appreciated. Thanks Ben
Network Publish
Ben Wingrove replied to Ben Wingrove's question in Wishlist - Feature and Content Requests
Will be happy to test for you -
Render Texture not showing when in symbol
Im using VW2019! -
Network Publish
It is mainly the viewports in our sheets when we publish a packet, it consists of Hidden line, open GL, and artistic renders but that varies depending on the project. We have VSS, we did a test between the time on a local and cloud render and found the local was quicker, that was last year though so I may try again. We are in the process of setting up a machine that just deals with our publishing so we can continue working on other drawings whilst it is working its magic. It would be nice to have an option within the publish menu/dialog box to send the publish to a local network machine in a similar way to sending to the cloud. To be able to harness the power of dormant network machines for the renders would be a nice option, especially on some of the bigger drawings. -
I know this has been asked for previously but I was hoping there might be some updated news, we have a whole heap of high spec Mac's that we would love to use in a network publish/render. Is there any plans for this in the future? Thanks
I have an extrude with a perforated metal texture, it shows fine in open GL, Wireframe and Artistic White Model. When I place that extrude within a symbol or if I change it in to a symbol it no longer shows up in the Artistic White Model render and a bunch of other render modes but it does show up in Open GL and Hidden line! Is there a sneaky trick to get this to show up in the other renders, unfortunately removing it from the symbol and placing it on its own is not an option. Thanks Ben (the top object in the screen grabs is the extrude on its own and the bottom is the symbol with the extrude inside)
OpenGL rendering ignores lighting instruments option
Ben Wingrove replied to Mickey's question in Wishlist - Feature and Content Requests
Is this ever likely to be added? I use open GL to grab quick screen shots to send to clients and vendors and it would be nice to not have to hide all the lighting fixtures. thx B -
Hoist Symbols in worksheet flipped
I managed to find a way to "cheat" it. As it stands, all hoist symbols on the drawing have their dimension display automatically orientated to be pointing towards the hoist origin. I added a new hoist origin in the bottom right hand corner, refreshed the hoists so they all have the dimension display orientated the same, refreshed the worksheet, deleted the new hoist origin and then refreshed the hoists so they were showing the correct x,y dimensions again. Simple Well at least the display in the worksheet is aligned and it pleases my OCD, until I find a better solution. -
Thanks Pat, I will add this to the wishlist forum. The main problem with the hoist symbols is that the orientation of the dimension display is dependent on if it is placed to the left or right of the center line, whilst this makes sense on our drawing I don't understand how the worksheets choose what symbol to reference, it must be referencing some from the minus side and others from the plus side. I'm not sure if it looks at the first instance of the symbol placed in the drawing or maybe from the top down. I will have to experiment next time I get some down time. Ben
