Hi,
I am experiencing a bizarre scaling problem for the first time.
I am using an HP Officejet 7500A Wide Format printer, but have also tried on a Brother MFC-J5625DW A3 Printer.
I have tried this with two completely different versions of Vectorworks (Spotlight 2014, and Fundamentals 2016). However i am still seeing the same problem. I have also tried this on two different machines, both Macs, both running El Capitan (one 10.11.2 and one 10.11.3)
I noticed the problem when scaling a plan that some of the lines along the X axis of the page were slightly longer than the correct scale despite the Y axis lines being correct. So, to begin troubleshooting i took the problem back to basics. I have set-up an A3 drawing in 1:25. In Page Setup i have ensured the Horizontal and Vertical are both set to 1 and i have selected an A3 page in the Printer Setup (ensuring the scaling says 100%). To be sure i have created a custom sized page (the problem occured with a standard A3 selection also). I created a 297 by 420mm zero margin page and selected this as my paper size.
I have tried using a Viewport and setting the page scale to 1:1 and Viewporting to 1:25, the same problem occurs.
I have also tried printing directly from Vectorworks and exporting to PDF. The same problem occurs.
I am sure its a Printer Driver issue, but the weird thing is i have never had this problem before, even though i am using the same version of VWX and have not changed my printer.
Has anybody else experienced a similar issue?
I have attached a bunch of screenshots showing a basic box drawn at 7500mm by 6000mm, as well as a picture of the line against an architects ruler showing the 6000mm line reading at 6020mm.
Thanks in advance,
Rob
