796 -
Everything posted by Hippocode
Apparently there is a UUID collision between my custom plug-in and Marionette. That's what causing it. Will have it fixed tomorrow.
Toggle Show 2d not working properly in VW2015
Hippocode replied to billtheia's topic in Vectorscript
Yes. If you look at the VS function reference under "Document Settings" you'll see even more functions to set preferences for various variable types. Also, the following overview lists which function (and variable type) you need for each preference. http://developer.vectorworks.net/index.php/VS:Function_Reference_Appendix -
3d xyz tool
Hippocode replied to digitalcarbon's question in Wishlist - Feature and Content Requests
We offer 2 packages, Extensio and Extensio Pro. The object he used is the SymbolObject, which is present in both bundles. You can find more about it here . -
Any drainage packages for landscape architects that work in VW?
Hippocode replied to Rossford's topic in Site Design
No, at this point not. -
3d xyz tool
How did you get them on the 3D plane ??? I've tried everything without result. Also, I don't have the mode "show as 2D graphic only" which probably makes it work for you. I can't get rid of the 3D locus, thus it remains hybrid. EDIT, found it. Badly badly translated into Dutch. -
Well, the piping plug-in can be used for any kind if pipe but has no auto dimensioning associated with it. The drainage is derived from the piping tool which has a calculation for indoor sewerage. I will add some more information about the calculation method in the MEP manual prior to the new release. If there is something specific you need give me a shout. In fact, the new update features about 90% of user requested changes! -
I was waiting for the next update of my module to be released prior to announcing it on this forum. It should be ready before the end of 2015. The new version 2016.02 will (finally) have an installer, the previous can only be installed manually. That, and a lot of new features are worth waiting a week. You'll see the post appear pretty soon in the third party subforum. -
3d xyz tool
The problem is that the stake object is a hybrid object, thus not showing the coordinates while in 3D view... -
How to get Symbols of 3D objects to show dimensions
Hippocode replied to Lance_M77's topic in General Discussion
If you want to keep it simple, a script just gets the 3D bounding box of your symbol definition and stores these dimensions somewhere, preferable a record attached to the symbol definition. This allows you to retrieve these values as well in a worksheet. If you modify a symbol definition, there is no way to have it automatically update. You would need to run the script again. There are several ways of displaying this data inside your drawing if that is also what you are after: - Edit you symbol definition to show the record fields attached to a text field. - Let the script just print a text field next to each symbol. - A custom label object, probably not what you are after. There are several coding examples to be found under the vectorscript / python section. If you don't want/can spend the time you can always ask for someone to do it for you, might be at a small cost -
What exactly defines the dimensions ? Just the bounding box of the symbol ? Some inner content of the symbol ? Can it retrieved the same way for all symbols ? You could just have a script, to iterate all your symbol definitions, find the bounding box and save it into an attached record, or even the symbol name. -
Not all preferences have the same variable type. Some are true/false = boolean. Some are one of many possible integer values 0,1,2,3... = integer ... -
EAP with a non destructive path
Hippocode replied to Bas Vellekoop's question in Wishlist - Feature and Content Requests
1) Yes. I believe everything is being converted into a NURBS, even a 3D polygon. 2) This has to do with 2 things: - Not all planar objects are PATH based, for instance a rectangle. - The EAP default behavior just turns anything into a NURBS, but there is a workaround: Create your own object that creates internally an EAP just by passing the path and the profile. This way, you have more control of your path -
ability to select the outer boundary of an EAP
I'm not sure what you are trying to do. There is only one object in the drawing and I can select it in any view. -
VS is derived from the Vectorworks SDK for programming in C++. If you download the SDK and search for "minicad" in the file names, those files hold ALL the constants vectorworks uses, for instances for events of dialogs, plug-ins etc etc
How do I retrieve info for a Point-PIO by clicking on a drawing element?
Hippocode replied to VvierA's topic in Vectorscript
After taking a quick look at the VS function reference, there is a section for "tool events". So it might be possible after all Note that you need to create the hovering part on your own. This is what I use for one of my tools in the SDK. It will highlight any object compared with an array of object names. void CMEPLabelToolDef_EventSink::MouseMove() { if(this->GetToolPointsCount() == 0) { MCObjectHandle OverObject; short OverPart; SintptrT Code; gSDK->TrackTool(OverObject, OverPart, Code); if(OverObject != NULL) { //if(OverObject != Object) { gSDK->EmptyToolHighlightingList(); if(VWParametricObj::IsParametricObject(OverObject)) { VWParametricObj Obj(OverObject); TXString ObjName = Obj.GetParametricName(); // Valid object ? if(std::find(fTaggableObjects.begin(),fTaggableObjects.end(),ObjName) != fTaggableObjects.end()) { HighLightedObject = OverObject; gSDK->AddToolHighlightingObject(HighLightedObject); } else if(std::find(fTaggableGroupObjects.begin(),fTaggableGroupObjects.end(),ObjName) != fTaggableGroupObjects.end()) { HighLightedObject = OverObject; gSDK->AddToolHighlightingObject(HighLightedObject); } } } } else { if(HighLightedObject != NULL) { gSDK->EmptyToolHighlightingList(); HighLightedObject = NULL; } } } //return VWToolDefault_EventSink::MouseMove(); } -
I'm not sure this is possible with VS. What you need to do is to overwrite the tool behavior, particularly the mouse move and click events. If there is no way of overwriting the tool, you might do it with a menu command instead or object event: http://developer.vectorworks.net/index.php/VS:vstGetPickObject You could trigger this by a button in the OIP. I do exactly what you describe for a custom tool myself, but it's made with the SDK so I have no idea how to do this in vectorscript. -
That's not entirely true.... Well behavior is different between object types and even Vectorworks versions. I just always do it to make sure it's properly reset.
You need to reset the objects you changed for them to reappear with the new attributes.
How do I convert a symbol to a custom plug-in object?
You don't need the tool, ok. But the thing is, when creating a plug-in with VS, VW will automatically create a tool for it so you can place it in the drawing. Luckily for you you don't need to code that tool which leaves you to the object only. That is why you need to choose the plug-in type (2Dpoint, rectangle, polygon....) If you use the SDK, you can keep this separate. I've got several objects that don't have a tool because other objects / tools place them in the drawing. That being said, a tool or not, the only way to add an object this way is trough CreateCustomObject. This won't trigger the tool btw. -
The only solution you have is what I've highlighted. You can't aspect VW to generate an object for you from scratch, without knowing what it should do. This is something you need to set up. -
What you are trying to do is possible, but I believe you don't understand what a plug-in object is. You need to DEFINE a custom plug-in object, that takes a symbol or easier, a symbol name so it can generate it on resetting. This is something you can't do automatically, its coding work to do With your menu command, you search the poly you wish to label, then call CreateCustomObject to CREATE an instance of your custom object, bound to the polygon you have a handle on. -
Well, just use CreateCustomObject or the equivalent for path based objects. What you then pass as parameters or content depends on your plug-in. You can for instance use the symbol name in a parameter of the object or maybe your object requires a symbol in the path/profile group etc etc... Also keep in mind that you will need to use the offset of the symbol as insertionpoint of your object. Depending on your needs, rotations about axises as well. -
Have you tried ReDraw ? -
1) When you create a report, you can choose to show only selected objects by modifying the criteria. 2) If you have objects selected, there is no "command" available to turn this selection into a report. If you did create your report as mentioned in step 1 you can relalculate it to show your new selection.
