MJasonM
    5
Reputation
0 Neutral
Personal Information
  • Occupation
    Architect
  • Location
    South Carolina
  1. I need to find a way to create window/door schedule by layer.. For instance, in the same file i have the existing model floor plan design layer & proposed floor plan design layer and I want to create a seperate window and door schedule for each, but when you create a window/door schedule it has information for all design layers. One thought was, perhaps I could create a window/door schedule then in the header add criteria to limit to one design layer, but this didn't work... or at least everything I tried failed I would appreciate any suggestions.... thanks
  2. Submitting the bug was the first thing i did... I have been using VW since MiniCad 4.5... I love VW, but the first realease of each version is always buggy. For this reason I stayed with Ver 2008 till I went to 2012. Anyways, I look forward to the issue getting worked out, but for now, I am sticking with 2012
  3. thank you for the suggestion, but this did not solve the issue. I grabbed a stopwatch to get a more accurate time on the delay. Example #1 - In the edit viewport box, from hitting "OK" to being in a 3D wireframe viewport 10 sec Example #2 - In the edit viewport box, from hitting "OK" to being in a 2D plan view 9 sec Example #3 - Changing between sheet views 9 sec Example #4 - double clicking group to edit 5 sec These are significant delays. Any other suggestions????
  4. I am experiencing approx 3 second delay when changing sheet, editing viewports, extrudes, groups, etc.... very frustrating. I am going back to 2012 till this issues is resolved. I hope it is fixed soon.
