stella
17 -
Never
Reputation
0 NeutralPersonal Information
Occupation
Landscape Architect
Location
Melbourne, Australia
Thanks, I'll give that a go!
Hi! I was wondering if there is a way to get dimensions to round to the nearest 5 or 10, instead of just to the nearest integer. I am using 8.5.2 Thanks!
Thanks Andrew, In the end I created a spiral staircase with really small steps, ungrouped it, and deleted the stairs, leaving the handrail! Stella
Hi! Does anyone out there know a quick and easy way to draw a 3d spiral? Any help much appreciated. Thanks, Stella
Thanks very much! I'll give it a go.
I have a drawing where I need to create something like an AutoCad viewport, so that a section of the drawing can be seen at a different scale. Is there some way of doing this? Thanks.
Thanks! I'll give it a try.
This is probably a silly question, but in some drawings, every time I enter text, or do a dimension, they come up with a solid black fill. This happens even though the Attributes are set to no fill. Any suggestions? Is there somewhere I don't know about that is setting this default? Thanks
3D Chamfer and Fillet?
stella replied to tgrieger's question in Wishlist - Feature and Content Requests
I agree - although it would need to be done carefully as I've found sometimes 3D fillets can do unexpected things on complex shapes. -
I don't know if 9 has it, but I would love to see a 'fence' option in trimming, like in AutoCad, where you can select a cutting edge, then draw a line through a number of objects, all of which will trim back to that edge. It can be a bit of a pain having to pick each object to trim if there are a lot of them!
Thanks! I am using 8.5, I think. I believe I have solved the problem - the drawing I was taking the objects from had put some of the objects into a different class, which disappeared when I took it into a new drawing. Having put all the original objects into the same class, they all seem to stay put in the new drawing.
I am having a strange problem, where a particular object I insert into a drawing (a titleblock) will be visible for a while, then parts of it will mysteriously disappear. They do not just go white. I have tried inserting is a simple cut and paste, as a symbol, or as a collection of objects, and after a few commands, it happens again. Any suggestions greatly appreciated!
We've been using it for about a year, but have trouble finding the time to train other staff members than me! Mary Jeavons landscape Architects, Melbourne, Australia.
We use it... Mary Jeavons Landscape Architects. Melbourne, Australia.
I am trying to do a cut & fill DTM, and keep getting the message " The 'To' DTM must be totally enclosed by, or have the same border as, the 'From' DTM" I have tried using the DTM user boundary thing, and this does not seem to help. Have alo tried reversing the To and From, but this doesn't seem to have any effect either. Any suggestions? Even more confusing is that sometimes this message does not appear, even using exactly the same data. However, if it does not appear, and seems to be calculating the cut & fill DTM, the computer freezes. Would really appreciate some help on this one. Thanks. [This message has been edited by stella (edited 08-30-2001).]
