Bas Vellekoop
    665
Posts posted by Bas Vellekoop
  1. I was working on a symbol and wanted to use the 'set working plane' tool.
    I am able to set the working plane inside the symbol, but not able to use the 'look at working plane' button.
    This only happens when I'm on a sheet layer and open the symbol from the resource browser.
    Is there a specific reason this is not possible?
  2. 1 hour ago, JimW said:
    At the moment, none of that behavior is linked from pane to pane. This gives advantages in letting you have multiple separate editing modes open at a time, which wasn't possible before, but I agree that being able to link two or all panes to edit modes might be useful as well.
    I was hoping for a option in Multiple View Panes menu.
    Maybe it can be a wish item
  3. Sort of a newbie question after all these years working in VW :)
    What is the best way to keep track of changes in drawings in generally and specifically for furniture design?
    Like when you added an extra screw or something relatively small?
    I looked into the issue manager and the revision data.
    issue manager: works globally between all sheets, that's great. But editing/removing the info is on sheet by sheet basis if I`m correct?
    revision block: works only on 1 sheets and is not shown on other sheets if I`m correct?
    And is there a way to place something like a revision cloud with a connection to the revision block or issue manager. Sort of like the detail viewport so it has the revision number / issue number attached and shown and is editable and removeable when you click on it?
  4. I don't trust the deform tool. :)
    In this kind of cases I use the nurbs tools. You can reproduce this and make minor changes to the design without starting from scratch and ending up with a generic solid.
    Not near a pc so I hope you can follow this:
    - draw several 3d loci that follow the pitch line and the circular path
    - draw a nurbs  curve through the loci
    - duplicate the nurbs curve and move into position in the z-axes
    - loft 2 the nurbs curves
    - shell the nurbs curves 18mm
  5. I`m trying to create a bill of materials for a table design.
    The idea was to create a worksheet to count all the symbols in the design (every part of the table is a symbol) and add a column to type a description for every symbol. But this doesnt seem to be possible. Is this correct?
    I want to add text in the blue part.
    If this is not possible:
    Probably attaching record is the way to go.
    Only me is told that i have to 'reload/replace' all the symbols on al the design layers to give it the record/info I attached to the symbol.
    Is there a way to attach the record to symbol and 'send' the information in it to all exciting symbols without replacing them?
    Thanks!
  6. 47 minutes ago, Kevin McAllister said:
    I hope its the modern equivalent to the "3D Power Pack" of tools that were added years ago :D
    (The Subdivision tool fills a great niche but it isn't designed for precision work. Its difficult to make objects that meets specific dimensional tolerances.... its a video game / animation modelling tool adapted to a CAD program to allow the creation of organic mesh shapes.)
    Kevin
    +100
    Agree completely!
    I use the 3d power pack almost at a daily basis.
    Subdivision tool is very cool, but not for precision work. I see it more as a tool for sketching.
