anton
Content Count
6 -
Calendar
Everything posted by anton
Reference viewports moving position on page after being updated
anton replied to Tessuto's question in Troubleshooting
check this link https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=213077Post213077 -
We are having the exact issue with one of our larger projects (over 300 viewports has shifted...), some were restored by the unticking of ignore user origin box, but certainly not all, we are on service pack 4... still no fix in site?
Hi there, thank you for the information, we are using 2015, and still have this problem with shifting viewport contents, our vectorworks reseller help has been of no use so far, he suggested it would have something to do with that the scale of the referenced drawings where different, or that there was some sort of loop in the referenced way, we tried ticking the 'ignore user source origin' tick in the editing reference window, and it solved some of them (by almost shifting it back to its original position, but not quite), but it didn't change other drawings back at all, very odd, and still no solution to the problem, do you have contact information for your vectorworks source that knew about this problem? kind regards
we have had this same issue in some of our projects, by ticking the box 'ignore user source origin' (from within the layers referenced editing window, some of the shifted viewports seems to return to (almost) their original positions, but it's a bit arbitrary and doesn't work in all cases, there is a link here about this very same problem, maybe some help can be found here, https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=198905 we are currently using 2015, but had the same problems with 2014 also, kind regards
yes I agree, this is crazy, why change a way of drawing that was working fine and was quick before, to something that is cumbersome and excruisingly slow.... please revert to the previous options thank you... kind regards anton
This is seriously slowing down the drawing process, is there a way to revert to the former 2012 way of selecting dashed lines etc, as there are now 3 steps instead of previously one step to alter line thicknesses and styles etc, and i cant seem to find a way to customise the toolbar for this option, 3 steps instead of 1 means literally at least double time to finish a drawing, we are a very busy small architect office, and this time is cruicial for the success of the business, something needs to be done on this, thank you... any thoughts? kind regards anton
