Rocko & others: until you get an official response (and I am anxious to hear it) consider this. If you have access to an HP designjet plotter, you can use the Zoom Smart feature of the driver to scale your drawing. This takes care of your line weight and arrowhead problems, and has the added benefit of helping you avoid one of those accidental saves you might make after you have scaled your drawing objects for some miniature print-only purpose. Scaling using the driver will also present some headaches as the plotter clips the margins of the drawings using byzantine dimensional formalae. Getting the driver and the print window to both show what you want takes some manuvering. Go to Page, Set Print Area, choose One Page at the top of the list & close out. Go to Print Set-up, choose your HP plotter, click on Properties, choose the Page Size tab and set the desired scaling factor. Often your scaling factor will cause conflict with the application page size and will require adjustment or reshape of your print window. I have found that by closing-out of page set-up after setting a small scaling factor, and then returning to print set-up allows me to choose from a larger variety of application page sizes than when starting from the presumption of 100% scale. Try different "application page sizes" in the print setup until the print window in your drawing shows what you want to see. If you have to plot reduced copies of many drawing files, note the specifics of your print configuration, once you have gotten them correct and set them up as the default configuration for your plotter working from the Windows Start/Settings/Printers path. When you do this, the greif of matching scaling factor and "application page size" to show what you want is not relived each time you go to plot. If you are a professional using VW for work, and don't have a plotter give it some serious serious thought. I bought a refurbished HP 350C for $2,500 three years ago, and it changed my LIFE. Work life anyway. The plotter has been almost completely trouble-free and when it has not been, he plotter regime of HP tech-support guys is worthy of your professional time. If you just want to do 11x17 check plots, there are some cheaper HP's that would be good. If you need to do reduced size plots very seldom, you could get the HP driver and make prn files and e-mail to you local reproduction house. Hope this helps you.
