John Sherwood
    5
Reputation
0 Neutral
Personal Information
  • Occupation
    Teacher
  • Location
    Valencia, CA, USA
  1. I, too, am running 12.5.1 (educational) on an Intel Mac OSX 10.4.9 and am unable to use the PDF batch export function. I've trashed the command and replaced it to no aveil. I sure wisj it worked because having to make up a bunch of multipage sheet layers is a pain.
  2. How can I get the database to automatically number its rows in a report? Each time an item is added, I want its row to be sequentially numbered.
  3. I'm having trouble with the seating tool using VW 10.5.1b with Mac OS 10.3.1. I have a 28' x 12' rectangle and am using 20.5" seats with 36" row spacing, z height of 0" and a rise of 8" and allowing VW to create the symbol. While I get the number of seats I expect, half the back row appears in front of my recatangle and the rise is reversed, too big and starts above my 0 z level. If I use concentric, the rise issue is reduced to just elevating the first row above the 0 z level.
  4. quote: Originally posted by klinzey: This is a known problem. The temporary solution is just don't move the page origin. The objects within the group are referencing 2 different origins when you move the page. There is a fix to the script that involves vector script calls to get and set the user orgin. Is this script available somewhere?
  5. I have been using the Theatrical Lighting features of v. 8.5 and all has been going well except for problems encountered when we use the Move Page Tool or reset the Origin. In both cases the change is not applied to the Data Lables and they are moved away from the fixtures with which they are associated. How can we solve this problem?
