the frog
Content Count
111 -
Posts posted by the frog
There is confusion between software use and reading here because the contractor wants the use of BIM
VW has been BIM forever this is what IFC is for (the little text at the bottom right corner of the OIP).
It's a bit long to explain in this post how to correctly export in IFC but if your objects on the plan have their IFC correlation, (this is done automatically with walls) then any BIM reader can use the file.
I was confused the first time I encountered this case but now it ok. With the BIM but you never work on a BIM file, you just read the other persons work and you are not allowed to touch any of the other members work. If something doesn’t work (like a pipe crossing a structural beam) the pipe builder has to meet with the structure builder who will take the responsibility to make the hole in the structure or ask the pipe guy to change the way.
What is good with BIM is that in return no one can change your work but only send you some messages saying there is a conflict.
When you receive a IFC file open it on a separate document and bring it as an external ref via a viewport .
Of course it would be great to be able to import revit files but again if so you’ll have to consider them as dwg files and not BIM.
Try to find out if the contractor can read the IFC export this is the best. On my side I am checking the quality of my exports with SOLIBRI viewer before sending the files.
Hello
I would like to get the values from the IOP here ‘taille’ (see capture) in the spreadsheet
I found out how to get the node name, not really useful or the generic name in this case Objet Marionette, not really useful when you start having different types of Marionette object in your drawing.
I built a database (very simple) where of course I can have the name of my object. The lg refers to the length I could put in the database, but then it won’t change if the ‘taille’ value changes in the OIP
In the capture, the added column ‘taille’ is just a name in the sheet
It would be great to be able to get the values and all the information we have in the OIP in the spreadsheet.
Anyone has an idea?
Hello
I just return from Light &Building in Frankfurt and asked the manufacturers about BIM and IFC concerning their lighting products (like tracks) and fixtures. Not one has given suitable answer: “they are working on it”.
Before even getting to code numbers, I dream of IFC given by the manufacturers in their tech sheets. This would solve lots of future problems in BIM 2, one could use the BIM file or draw some similar objects and be sure the IFC is equal to the manufacturers one. Therefore export in IFC would be simple and not lotto concerning communication between the different users. At this time a light designer invents, picking up from what exists, at the end the project is loaded with useless IFC copying one another without being accurate.
The second step in vw is just a Marionette node dragging from an Excel or library file and added in the OIP to the design object.
hello
distributor is Cesyam (in France of course)
lot of sense
I’ll have to change my glasses, I didn’t see the – sign in shell2
I will try to convert into solid in the path extrude node in case this is the pb
here it is
Nice Marissa!
Could you explain why, if you divide by 2 and convert into solid they all go in the same direction. I am totally in the fog.
Maybe I should do the same with my picture frame to see if the path extrude node is not converting the result into invisibility…
Marissa
wouldn’t it be even easier if we could get the info straight out of the door OIP in the advanced parameters “façade” where the frame is define. I tried to get the info as shown with the eliodon in the webinar session but you don’t reach those parameters
hello
I worked on your script to try to find a solution
The first part of the script misses the beginning point so I took the info from your object.
Than (I don’t know if this is what you want) instead of having a distance I gave a number of cuts; in my try I could not divide 5000/150= 33,33333 so nothing was centered. it was difficult to see what was wrong.
From this I cut your script after “contour” to see how it worked. In this case the nurbs are placed correctly. I checked the nurbs directions they are all alike.
The bizarre part comes later when you shell. I drew some lines to see how the shell went and you can see some are going left and some are going right, but they stick to the given distance.
I can’t find a reason so lets hope someone understands…
hello
Marissa have you done this with Marionette ? Would it be related to my double frame ?
Great to see it's coming along
Hi Jim I would like the same debug tool that could work inside a script. At the moment you need to isolate the wrapper and cut all the connections or to copy and paste in a new document to be able to read the figures with the debugger.
UNGLAUBLICH
herrliche
I will look at the script to understand the way you achieve it
Thanks Marissa
I also wanted to manage using the parametric constraint but only works in 2D
if you could have a look at my frame pb in the 'visible invisible and ohhhh textures'post it would be great
New goal: I built a frame for a door. When I run the script the frame moves with the door. If I change the door’s place and run the script again, the frame sticks to the door's new place.
Question: I can I achieve the same result when the script is converted into a Marionette object?
As soon as it’s converted it won’t follow my door.
hello
Where can I find the last existing nodes or the one that have been modified without waiting for sp3? I heard something about it in the webinar but… forgot when.
Thanks in advance
Hi
Thank you for the proposal of using symbols. I though about it but not two frames in the exhibit are alike so at the end you have too many symbols with too many names.
What I am trying to achieve is a tool that anyone in the office can use (they are phobic about symbols and 3d so the path is long). That’s why having to change the measures in the OIP as they work in plan view seems to be a good start. Marionette is a try; when I want to go fast I work in VW the normal way with section and path extrude etc.
I tried you idea of ending with attributes node, the script is working even when you envelope but not if you convert into object.
As for the texture problem it shows in my showcase example we spoke about where textures are switching without advice if you move some sizes in the OIP. For an exhibit,in the showcase I should have a texture for the back, one for the glass and I can have one for the sides. So we are talking of 2 different classes for 1 showcase, not including the glass (same for all showcases) and the external frame (usually painted the same as the wall). If I have 30 showcases my class palette is too long to be efficient, the way it works in the OIP (scrolling) is the good solution.
The truth is that being curious I want to understand the why of this situation.
This new topic refers to disappearing object between 2d and 3d. This time part of the frame becomes invisible after crossing the path extrude node when you switch to resultant object. If you only envelope no pb the script works fine.
any idea (Alan I have been trying almost everything I could)
Second part of the topic
Textures are turning crazy as soon as you change a number in the OIP if you are in open gl or in render mode. Usually ‘Verre mineral’ becomes ‘R_Verdure1’ or something else
Please help
The goal is to be able to add a second frame to doors inserted in walls. For the moment if you add a frame it goes only on one side. I would like to have it on both sides.
Thanks to webinar IV, I know how to get the info about the door (object by criteria, get parametric records, etc) in this case you only get the first set of info 17 parameters very useful to shape a new frame but…
Where do I get the second set of info (advanced button in the OIP) that gives the size of the frame so I could link them to my new frame. As well I need to get the wall info and in this case execute the script returns and error (see picture)
any idea ?
No thanks a lot
I will use the "image from url" node (slightly modified) to place the paintings right in the back of the frame. The goal is to get the info out of a Filemaker base where all the infos about the paintings are stored and link the frame size to it. This way at the instant I pick up a painting it will be at the back of the frame at the right size, a good way to highjack Sarah’s script in the last webinar session.
Not all paintings have glass and then reflexion will be too long to calculate for my poor render (usually 4 to 8 bounces).
If you have any idea why textures are getting crasy or why the frame does not appear...
Alan
I opened your file and you encounter the same problem as I do
See the pictures top view object and top view wrapper
When you convert into object, the only part you get to see is the back rectangle of the frame. The path extruded part, where you can change the size and the deepness of the frame, does not appear if you stay in wrapped it works.
Concerning the textures I don’t know why they are moving from one name to the other, what I found out is that when you try a texture it won’t appear unless the texture is already in the document. Then if you change a parameter in open gl mode (like a size) the texture at the end of the script will switch to a new name.
Truly when I am finished with the museum objects modeling I would like to use them to work and at this minute the marionette textured object is not safe enough to be included in a project where I can have lots of different textures.
At the end Marionette should make us gain time and not flip out because rendering is crazy inside the script
Hello
I use the same topic for a new problem
I made a script to frame my paintings. It works fine but when I convert it to object it becomes invisible. The only part I see is the last rectangle (retrait in the OIP).
If I try the script without the path extrude node all parts are shown. Is there a pb with my script?
Be sure your script is not the only one that crashes VW, Personally I record every 5 to 10 actions switching from name V1 to name V2 and keep the VW backup file as well. This way I don’t have to rewrite my title name every 1mn (this is the frequency of crash if the script is wrong somewhere).
About the crash it depends of the mac system version I don't crash the same way in 10.10 and 10.10.5
THANK YOU Sarah
It is great
The object runs fine and I added an insertion point in the OIP. So now it moves inside the wall the right way.
The last bizarre thing comes with the textures. If I change dimension in the OIP being in open GL or render the glass texture switches to another randomly. If I change being in wired? (filaire in the French version) textures are kept the way they should be.
hello
there is something I don't understand in the way you want to work.
If you modify a symbol all the symbols in the plot will be modified, so you cannot change the Z value of each symbol otherwise every same type of fixture would end at the same high.
If you want to change the whole plot at once (or a class or a sheet) you group what you want, you name it in the OIP, then apply the script (see image). You get a new place that will depend of your plot size. From that point (get bounding)with the math node you can write a script to get the centerline and use the deepness of the stage to get the center point.
But if you are in a 2d view the new object will still be in 2d view so no “Nice view”. To change the view you would have to rotate in 3d the group.
In the script I used the topz but of course you can use the bottom for stage 0 level.
Hope this helps
data base and OIP
in Marionette
Posted
sorry for the late continuation I couldn’t log in
For those following this post, with Marrissa’s help, the solution is in the attached file.
At the moment this is an Erco lighting track. if you go in control geometry you can change it for whatever you want.
It helps a lot when you have to get the info from the spreadsheet.
Please fill free to use.
Later I will try to change the name because when you sort by name = 0, by type it comes as Marionette object (normal). Not easy when in the document you start to have plenty of different Marionette objects, they all get selected at the same time
