CADD_OPS
Content Count
15 -
Community Reputation
0 NeutralAbout CADD_OPS
Rank
Greenhorn
Personal Information
Occupation
Engineering & Design
Hobbies
CADD
Location
On, Canada
Thanks Jim...
Thanks Frank, It is still giving me wonky numbers for Mass Moments of Inertia (x,y,z) that are not even close to what it should be. Even MMoI for a sphere are incorrect. The numbers are all the same, which is right, but the the numbers are incorrect. It seems like I have tried everything! I appreciate your input.
I am having a hard time trying to retrieve the 3D properties for a simple extruded rectangle. In particular, I am trying to find the MMoI (Mass Moments of Inertia) for it. I am using this simple shape as a test to determine if the VW calculations coincide with my calculations before I move on to the actual more complicated parts that we need this information for in order to run our simulation software. At this point the MMoI does not match my calculations. In design layer, I placed the origin at the CoM (Center of Mass) using "next mouse click is zero (0,0)" in the set origin command. Any tips? -please see attached
Thanks Raymond! Now that I have delved into it a little more, I am having a hard time trying to retrieve the 3D properties for a simple extruded rectangle. In particular, I am trying to find the MMoI (Mass Moments of Inertia) for it. I am using this simple shape as a test to determine if the VW calculations coincide with my calculations before I move on to the actual more complicated parts that we need this information for in order to run our simulation software. At this point the MMoI does not match my calculations. In design layer, I placed the origin at the Center of Mass using "next mouse click is zero (0,0) in the set origin command. Any tips? -please see attached
Can anyone suggest a good stl viewer that can be downloaded from the web? Thanks,
Hi, I am trying to set the origin in a 3D drawing to a midpoint on the bottom of what basically represents a steel bar which is 1/4" thick x 1.5" long x 3/8" wide. When I get the 3D properties for center of mass Cx, Cy & Cz seem to be wonky numbers. Center of Mass: cX: 3.644e-018 in cY: -0.7500 in cZ: 0.1250 in Any thoughts would be appreciated. Thanks,
Thank you Peter!
Hello everyone, I was wondering if anyone could tell me if this graphics card is sufficient to run VW2012? Hardware Overview: Model Name: iMac Model Identifier: iMac10,1 Processor Name: Intel Core 2 Duo Processor Speed: 3.06 GHz Number Of Processors: 1 Total Number Of Cores: 2 L2 Cache: 3 MB Memory: 4 GB NVIDIA GeForce 9400: Chipset Model: NVIDIA GeForce 9400 Type: GPU Bus: PCI VRAM (Total): 256 MB Vendor: NVIDIA (0x10de) Device ID: 0x0869 Revision ID: 0x00b1 ROM Revision: 3454
