Greg Stephenson
    7
Reputation
0 Neutral
Personal Information
  • Location
    Virginia, U.S.A.
  1. Bill, I have encountered the same problem with all of the callout styles. I have submitted a bug request before SP3 was released and there was no mention of a fix in the update. Still waiting because they seem to have taken something that was working (well enough I suppose) and made it worse! Hopefully a fix will be forthcoming.
  2. Does anyone know if it is possible to create associative dimensions within the VP annotations for a symbol. My attempts have all failed. Please let me know. Thanks!
  3. If you turn off automatic associative dimensioning in the document preferences, VW will ask you which object to associate the dimension to when creating a new dimension.
  4. If you turn off automatic associative dimensioning in the document preferences, VW will ask you which object to associate the dimension to when creating a new dimension.
  5. I have been using the callout tool in VW 2011 for some time with success at maintaining a consistent spacing around the text inside the callout. Now, in VW 2012, the callouts add an additional space at the end of the callout, making the text 'lean' to one side. Does anyone know how to center the text in a callout or has anyone run into this issue before?
  6. Nope, no mondo mouse. Are you thinking it could be an application conflict? I do use a program called Butler, which enhances the clipboard functionality, could that be the cause?
  7. I am having an issue while using the Cmd-C and Cmd-V functions. About once per day, I will be in the middle of working, copy or paste some objects and VW crashes. Occasionally I will receive a warning, 'There is not enough memory to complete the command.' but more common is VW to just crash. Is this a known issue? Are there any steps to alleviate this? Does anyone else have the same issue? Thanks,
