Clive Abben
    74
Everything posted by Clive Abben
  1. When choosing the rectangle tool and setting it to automatic working planes, I am unable to select any faces. Any ideas why this would be?
  2. What do you think is the best format to make movies in animationworks in windows 7? It seems a bit hit and miss and I forget the ways that worked! I have had success in the past by adding .mov when saving, but on the file I am working on it says that it has changed the file extension to .M4V and i then get either a very short movie or an off centered movie showing only a corner of the movie.
  3. I pasted the roof onto a black document and it came up fine! There must be something wrong with my settings in that document but I cant seem to find anything.
  4. Ive tried that, using the same texture nominated as class texture and picking out from the texture drop down list but still no luck!
  5. Thanks for that, I edited the component and it was set to no fill, but when I put class texture in it still did not show?
  6. I can not get my roofs to render in 3d. I create the walls and they are fine and when I create the roof it shows up in plan but not in 3d. I have created 100s of roofs with no problems and this seems to have happened only after I installed the last service pack. I exported the file to VW 2015 and the roofs appear perfectly?
  7. I have just made a new movie with animationworks and when I make the movie only about 1/3 of the picture shows. I have tried making the movie in other formats with no luck and have used animationworks successfully on other files.
  8. Thanks for that. I left the symbol in place and then clicked on it and it worked!
  9. for some reason I cant seem to create symbols anymore.I select the object, go to modify-create symbols, follow the prompts but nothing happens, they just stay as objects. I also tried creating a group first but no luck.It has only recently happened and have had no problems previously.
  10. Benson, I went through the workspace editor and it was there. It is now in the Architectural section and works well! thanks for that
  11. Thanks for that, I have the same drop down menu, but no Fit Walls to Objects!
  12. I have been following Jonathan Pickups recent posts about walls. I am in the landmark workspace but when I go to landmark-architectural, I cant find the fit walls to objects command?
  13. I have information on my plants regarding height and spread, but when i create a worksheet the information does not match, eg, i have Epicaris impressa as a plant with a spread and height of 1.2 x 1.2m, but it comes up on the schedule as 2.4 x 3m? I recently submitted a plan to council for a permit and it was rejected due to the information on the spread sheet which had exaggerated all the plants heights and widths.
  14. I turned Vectorworks on and off again and it worked! I feel so dumb!
  15. i have had a look for it, but cant find it? If it is hidden is there a way to find it?
  16. I cant seem to edit textures. I go to the resource browser and right click to edit but nothing seems to happen. Is there a change in 2015 regarding this?
  17. when i use the reshape tool to move grade limits, Vectorworks freezes and i have to close and re-open. its fine with pads, hardscapes etc but not grade limits?
  18. Thanks for that. I ended up giving the computer a full antivirus, malware scan and removed unwanted programs with msconfig and it seems to be working now!
  19. The rendering bar starts showing it is working, the viewport goes black, but does not progress from there
  20. I dont know if this is a problem with my computer or vectorworks. I can render in design layers but can only render with open GL in my viewports. It has only started happening in the last couple of days so am confused!
  21. I managed to play it in quick time. It was not on the open with pop up, but once I opened quick time it was fine. I do have a problem with rendering. Open Gl is fine, but with renderworks I would get to about 17-19 seconds of 25 and it would freeze. I guess maybe try short 5-10 movies and join them? If so, what movie editing programe would you recommend?
  22. I have just made a movie in animation works, the preview works fine in openGL, but when saving the movie it just appears as a file with no suffix and i cant open it. I have tried saving it with various compression methods to no avail.
  23. Thanks for that. I tried tools/purge, closed and re-opened the file and it seems to be working now, you have saved me a lot of heartache!
  24. I have been working on a VW2014 file, its currently about 650mb in size and if i do anything to it (even in top plan view) the screen goes blank and it comes up with an out of memory notice.The task manager tells me that only 54% memory is being used and cpu is currently at 0%, but I guess thats because it has frozen. Any ideas about what to do?
