Hi yes I got your email thanks and have tried to reply but I keep getting an error message saying 'Cannot send this item'!
Your colours are much closer than mine are.
Hi Jonathan, no those are not the colours, although 1 and 2 look close.
I don't know how to attach an image but if someone explains how I will show the two different colours I am getting.
Ok, the values are:
1) C 68.94, M 0, Y 33.76, K 0
2) C 33.43, M 0, Y 92.65, K 0
3) C 0.96, M 16.11, Y 99.64, K 0
4) C 0, M 66.12, Y 92.22, K 0
5) C 27.77, M 91.98, Y 0, K 0
6) C 69.46, M 98.03, Y 0, K 0
Thank you. Olivia
Hi, I am on a PC and had tried this already. However it only allows me to enter RGB or HSL values. Using the converter I found the CMYK values do in fact show, and strangely are virtually the same values as those used in Illustrator; its just that the actual colour is quite different!
I don't understand it at all
Thanks. Olivia
Did you find a solution for this? I have the same problem with Adobe Illustrator - the CMYK values give different colours in Vectorworks than in Illustrator and I can't think of a way round it at the moment, other than guesswork!
Hi I am on a 30 day evaluation of Vectorworks having attended a short course. I have some artwork designed in Adobe Illustrator and have been given the CMYK values. I would like to use the same colours within Vectorworks and have converted them to RGB values using an online convertor but the colours have come out different. I don't know how to use Illustrator so at the moment I can't create what I want in either piece of software!
Any thoughts would be very welcome!
Thanks. Olivia
