453 -
Everything posted by bjoerka
Great Tom! Thanks a lot!
I was looking for a function to replace clicking "make all attrivutes by class" with the mouse to the burger menue in the attributes palette, but could not find anything in the vs reference. i´d like to build a custom command for that function...
It won't run VW2024 on my Mac and the system shuts down.
bjoerka replied to lumimimi's question in Troubleshooting
It has been reported by the german vwx forum that there are major problems with Apple´s latest update on Mac OS Sonoma 14.4 and 14.4.1 See the translated information in the german vwx forum. https://www.vectorworksforum.eu/topic/27893-macos-144-kompatibilitätsprobleme-mit-vectorworks/ -- We would like to provide an important update regarding compatibility issues between the latest macOS versions 14.4, 14.4.1 and Vectorworks. Vectorworks has identified significant issues with the latest macOS Sonoma 14.4 updates that are causing customers to experience unexpected slowdowns, crashes and print size discrepancies. These crashes have been observed primarily on systems with external displays and often occur after waking the computer from sleep mode. Apple is currently addressing these issues and we expect a solution in an upcoming macOS update. In the meantime, we strongly advise against upgrading to macOS 14.4 or macOS 14.4.1 to avoid potential disruption to your workflow. If you have already upgraded and are experiencing these issues, we recommend turning off external displays or reverting to an earlier macOS version if possible. We are monitoring the situation and will keep our community informed of any developments as they become available. -- you can also read about the the problems discussed in this thread as you can read, there are problems that not only affect vectorworks as mainly all programms, even Apple´s native apps, are affected by this problems. -
Mac OS Sonoma 14.4.1 makes VW2024 unusable
bjoerka replied to astephens's question in Troubleshooting
Correct. Mostly i use the setup of page sizes throughout the print command. And then i.e. in amostly all applications, i can select the predefinde page sizes for all printers. Kind of weired that the same functionality, done in two different ways, leads to different results .-) So i guess there´s no other way to wait for a fix by Apple. -
Correct. When i directly go into the page setup, there are only standard page sizes available for the Canon printer. Didn´t recognize this... -
Hi Gunther, that looks different to what i see when i select our Canon large format printer. In TextEdit i can select all page sizes that are available for the Canon printer. In Vectorworks i only see what is available as if you print to a standard printer or i.e. pdf writer. page setup in Apple´s TextEdit page setup in Vectorworks... -
That is what Marc Wittwer in Switzerland also said. But in my german localized version of Sonoma all Apple application show the paper options for our Canon large format printer .-) -
also caused by mac os sonoma from 14.4 on is the fact the certain page sizes for large format printers are not available in the printer page setup dialog... https://discussions.apple.com/thread/255525511?answerId=260308788022&sortBy=best#260308788022 the thread in the german vwx forum... https://www.vectorworksforum.eu/topic/27839-papierformat-von-drucker-wird-nicht-angezeigt/#comment-129529 -
Just found the same topic within the german vwx forum. Seems to be a problem related to Mac OS 14.4.x https://discussions.apple.com/thread/255525511?answerId=260308788022&sortBy=best#260308788022
Surrogates. Everybody is sitting at home with their VisionPro V7 and controlling his avatar...
Inside vectorworks i am unable to select standard page sizes that belong to a canon imageprograph TM-305 plotter. All i can select are sizes that relate to standard a4, a3 us letter and so on sizes. Within other applications all page sizes that belong to the large format plotter are available? I already tried uninstalling and reinstalling the printer driver, ran the repair option in vectorworks. Is that a known issue? Any help is appreciated... Specs as in my signature...
Did you try to run the repair function after installing update 4?
If your signature is correct, then i would assume that this is related to OS Catalina...
Just for information, also to reach others... I received an email from techsupport. They could rebuild the crash and it´s related to multiple window panes. When these are deactivated the crash no longer occurs. Will be fixed in update 4 - .-)
I guess i found a procedure to replicate the crash. I just dropped crash reports and a testfile to the tech support via the service select homepage...
Not sure if anyone else has this mentioned before, but since the update to 24.3 resp. 24.3.1 i experience very often random chrashes when updating viewports. My actual project is a complete 3 project where only annotations are 2d elements. So i set up vp with different layer visibility settings (display as grey, setting opacity i.e.) Also when updating sections, where the section line is altered, vwx crashes. I can not find a routine to reproduce a crash but it is a bit annoying...
multiple instances of VW with one click on a file.
bjoerka replied to hollister design Studio's question in Troubleshooting
On windows this also happens if you accidentally click double or more often on the vwx icon in the task bar... You can have so many instances running .-) I will not imagine what will happen to the prefs in the user folder... -
In 2024 this works very well event with complex projects. Last week i did something that resulted in a 1.5gb fbx which worked well in Maya after importing. So maybe it´s related to the vwx version. I rember having problems in 2022 with large projects.
"Your resource manager library catalog is out-of-date"
bjoerka replied to _James's question in Troubleshooting
guess that was me. it disappeared for several days, now it´s back for several days... -
Structural Member Custom Shape, Records and PIO
bjoerka replied to bjoerka's topic in General Discussion
Thank you Pat for explaining. I think i am not able to write a script .-) I stopped scripting 40 years ago in highschool using Pascal .-) For my actual project i just used the smt as is is and attached records after i have drawn my construction. Even without the functionality i was hoping for, a great tool! -
They left the Pro-Users alone a long time ago ,-)
yep. but compare the half-life time of a mac system compared to a win system and the upgrade price is ok. usually the mac systems in our office stay for 3-4 years compared to the win systems, which are replaced nearly every 2 years... but that will be another thread .-)
hm. no reaction from anybody. seems i sting a bee's nest and everybody runs away *LOL*
