99 -
Posts posted by Robert Janiak
Is that capture card supported?
Hey,
Prism still do not work. Beam disapear when I use prism in Robe Robin Pointe, Martin Mac 700.
Any tricks for this?
Thank you Edward. I will try use Mesh or stay with extruded circles.
16 hours ago, salukitd said:
Eddie, You helped me with this a couple of weeks ago and for the life of me I can't remember what you told me. I have some LED strip lights that are pointing almost straight up in the air in Vision. On my VW plot I used the "Set 3D rotation" to get them pointing downstage, but on "Send to Vision" they are still pointing almost straight up.
I'm forgetting something! Thanks!
Pat
Some times ago I had similar problem. Fixture in vision do not affect to "Set 3D rotation" from VW. I resolved this by activate/changing values of each "Set 3D rotation" fields. But i do not know if this is solution for your problem.
Robert
Hi,
How can I change Generic Solid resolution during export to Vision. When I use circles converted to Generic Solid. Export to Vision works fast. Geometry is low resolution. (attached photo) If I use screens extruded from circle then export to vision works very slow but geometry is high resolution. 3D conversion resolution in VW prefferences do not affect with Vision and Generic Solid.
Thanks, that make sense
OK, The only thing that comes to my mind is create many Purpose- classes and make it all visible and use only this class in project.
Dear All,
What is yours workflow for use Automatically assign the class of all lighting instrument option. Devices disapears from all Viewports when I set new purpose. Purpose- class is default invisible in all viewports during creation. Is it possible to change this behaviour? Any script or prefferences? The only thing that comes to my mind is create many purpose classes and make it all visible and use only this class in project.
Dear All,
What is your workflow for use Automatically assign the class of all lighting instrument option. Devices disapears from all Viewports when I set new purpose. Purpose- class is default invisible in all viewports during creation. Is it possible to change this behaviour?
18 minutes ago, markdd said:
Adjust the Gobo Shift parameter in the Object info Palette. That should take acre of it.
Mark
Thank you Mark. I see it. That is works.
Guys are you amazing. That temporary solution is great. Even cam works fine.What do you thing about Spout integration? Resolume has Spout sender. Spout suport Virtualcam and NDI. I used this with old Vision successfully.
7 minutes ago, BrandonSPP said:
So we have confirmed this is a bug and the engineers are working on it.
Thanx for info.
By the way, screen has emision effect if video source is video file. If source is still image e.g .jpg screen is dark without emision shader. Please add still image as source file for screen.
Ok. I am waiting.
Hi,
please confirm if is a bug or my setup problem. Now, Vision is useless for me and I am very frustrating. Still photo rendering quality is awful. Vision please back to ESP Vision 2.3 quality.
2 hours ago, Mark Eli said:
Hey Robert,
You're using the Sunstrip Active, which doesn't have dmx controlled rotation. You want the Sunstrip Pro which does.
Easy fix though, you should be able to just change the fixture mode in the OIP in Vectorworks and reexport.
I know. I was talking about 3D orientation. Vectorworks It does not affect vision orientation. I reinstaled Vectorworks, updated Vision library and started new project. I resolved this . I think problem was with old VW project file. Vectorworks sunstrip orientation still do not corespond vision orientation but I can change it.
43 minutes ago, BrandonSPP said:
Hi
I prepared test file again. I have the same bug. Top screen is a extruded rectangle with texture. Bottom screen is a Video Screen Plugin.
I attached zip included files: .vwx .v3s texture folder and print screen image.
I used Send to Vision... command.
VW version 2018 SP2 (Build 401138) (64-Bit) PL
Vision version 23.0.2.405396
If you need i can do more tests and send you at priv or mail.
Please give me info if you known this problem.
13 minutes ago, Edward Joseph said:
Hey Robert,
Glad to hear you like the new features!
As for the negatives, Render Still improvements are on the list but right now capture devices take priority. DMX Xforms are currently in Vision 2018, in the properties window, we just haven't added the node system back in. We are currently exploring other options for this feature that are more user-friendly.
Object to RGB light conversion is still in the works, it was much easier to implement in the old rendering system of Vision 2.3, but we are looking into it.
Oh, thanx for info. I did not known about Xform. I will be testing.
What is new option "Looked At"?
My first look:
+ Bloom
+ Haze
+ Exposure, Contrast, Gamma etc.
+ Shortcuts
+ Invert Pan/Tilt
+ Fullscreen
+ Better integration with Vectorwroks
- Render Stil, has no save render settings. all the time 4000 x 4000 resolution and default path
- Color Temperature ???
- Move object by DMX ???
- RGB object color by DMX ???
What is Looked At?
Fixture rotation after reopen file
in Vision and Previsualization
Posted · Edited by Robert Janiak
Some fixtures has wrong rotation when I save my project in Vision and open it again. If anyone has this bug? Like some information do not save in file.
