Robert Janiak
    92
Everything posted by Robert Janiak
  1. Some fixtures has wrong rotation when I save my project in Vision and open it again. If anyone has this bug? Like some information do not save in file.
  2. This is a comprehensive answer to this topic. Thank you @bbudzon @klinzey By the way Blackmagic should be add to Vision in the near future. It is very popular video equipment.
  3. Hey, Prism still do not work. Beam disapear when I use prism in Robe Robin Pointe, Martin Mac 700. Any tricks for this?
  4. Thank you Edward. I will try use Mesh or stay with extruded circles.
  5. Some times ago I had similar problem. Fixture in vision do not affect to "Set 3D rotation" from VW. I resolved this by activate/changing values of each "Set 3D rotation" fields. But i do not know if this is solution for your problem. Robert
  6. Hi, How can I change Generic Solid resolution during export to Vision. When I use circles converted to Generic Solid. Export to Vision works fast. Geometry is low resolution. (attached photo) If I use screens extruded from circle then export to vision works very slow but geometry is high resolution. 3D conversion resolution in VW prefferences do not affect with Vision and Generic Solid.
  7. He All. What do you think about build galery with user renders?
  8. OK, The only thing that comes to my mind is create many Purpose- classes and make it all visible and use only this class in project.
  9. Dear All, What is yours workflow for use Automatically assign the class of all lighting instrument option. Devices disapears from all Viewports when I set new purpose. Purpose- class is default invisible in all viewports during creation. Is it possible to change this behaviour? Any script or prefferences? The only thing that comes to my mind is create many purpose classes and make it all visible and use only this class in project.
  10. Dear All, What is your workflow for use Automatically assign the class of all lighting instrument option. Devices disapears from all Viewports when I set new purpose. Purpose- class is default invisible in all viewports during creation. Is it possible to change this behaviour?
  11. Thank you Mark. I see it. That is works.
  12. Dear All, How can I change gobo position and size. I need it without white gap at edge.
  13. @bbudzon@Edward Joseph Guys are you amazing. That temporary solution is great. Even cam works fine. What do you thing about Spout integration? Resolume has Spout sender. Spout suport Virtualcam and NDI. I used this with old Vision successfully. http://spout.zeal.co/
  14. Thanx for info. By the way, screen has emision effect if video source is video file. If source is still image e.g .jpg screen is dark without emision shader. Please add still image as source file for screen.
  15. Hi, please confirm if is a bug or my setup problem. Now, Vision is useless for me and I am very frustrating. Still photo rendering quality is awful. Vision please back to ESP Vision 2.3 quality.
  16. I know. I was talking about 3D orientation. Vectorworks It does not affect vision orientation. I reinstaled Vectorworks, updated Vision library and started new project. I resolved this . I think problem was with old VW project file. Vectorworks sunstrip orientation still do not corespond vision orientation but I can change it.
  17. Hi Sunstrip library is broken. I can not control rotation.
  18. Hi I prepared test file again. I have the same bug. Top screen is a extruded rectangle with texture. Bottom screen is a Video Screen Plugin. I attached zip included files: .vwx .v3s texture folder and print screen image. I used Send to Vision... command. VW version 2018 SP2 (Build 401138) (64-Bit) PL Vision version 23.0.2.405396 If you need i can do more tests and send you at priv or mail. Please give me info if you known this problem. Video bug.zip
  19. Hi, MySql generates much more table rows than symbols counts when I am duplicating Lighting Device symbol. Normal symbols seem to be ok. Anybody has the same problem? Is a VW bag or ODBC/MySql problem?
  20. Oh, thanx for info. I did not known about Xform. I will be testing. What is new option "Looked At"?
  21. My first look: + Bloom + Haze + Exposure, Contrast, Gamma etc. + Shortcuts + Invert Pan/Tilt + Fullscreen + Better integration with Vectorwroks - Render Stil, has no save render settings. all the time 4000 x 4000 resolution and default path - Color Temperature ??? - Move object by DMX ??? - RGB object color by DMX ??? What is Looked At?
