Robert Janiak
    92
Everything posted by Robert Janiak
  1. @Rob Books When I am in the office, I will send it, but you can do simple test. Create blank file Add 3xProlyte S36PRF-L305 Add 2xHoist Calculate should be ok Select All (Ctrl+A) Rotate tool about 15 deg Calculate should be wrong I tested it on two different PC and get the same wrong result with S36PRF-L305 only.
  2. @SCParker This is a strange problem. Concern only Prolyte Touring Truss. I thing Cross Section is broken. If I change cross section to other manufacture. I have no problem. I have clean VW. I use blank file for test it. I have all classes on. I use VW SP3 PC Won 10 Pro. If I use blank file, calculate dialog box do not show any errors but on pdf raport some Tube workload are red and have no value. If I use old file where i find this bug, calculate report show errors and raport show Tube workload at 300% I do not Braceworks expert but Why this problem is only on Prolyte Touring Truss? Coul you try replicate my proble on yours machine?
  3. Diagonal PRT Tuss is red after calculation. Why?
  4. Hi All, Vectorworks are hunging if I try Reset button from VW Preferences dialog box on Win 10 Pro PC. Anybody has this problem? I tried this on different mahines and it is this same.
  5. Hey All, Thank you for your time and help. Reset VW resolved my problem. I will do reset VW first before post next bugs. Special thanks to @jcogdell for on-line meeting and helps !!! Good Job. Update: I Think Template file was a problem. Problem come back if I use old custom template. If I use Blank project, have no bugs. I had to redefine my templates 😞
  6. @Wesley Burrows Try duplicate this issue with Prolyte H40V-200 or Eurotruss. TomCat seems to be fine but Workload is Grey. Why? It something wrong with Prolyte and Eurotruss library. How I do it: 1. Add H40V-200 2. Add 2xHoist 3. Recalculate All Objects... 4. Change Trim Height of System... 5. Recalculate All Object
  7. Hello, Static system is not suported and Hoists disconected after change entire system Trim Height. I can not attach it again. Red line not showing. Only adding new hoists resolve this problem. Do you have any solution for that? Is any hoist reatache function or something like that? Update: I use VW 2019 SP3 Win10. Truss is converted to Hunging Position
  8. Hi, I try publish images from different sheet size. I thing publish image has bug. If I select All Page as Single Image in Publish Export Image File Option, VW locked image size to print area from active Sheet Layer. I can not reset it again to desired size. All image are wrong size ekported. For Reset image size: 1. I had to change active sheet layer, add image to publish and reset All Page as Single Image option. Without this VW remember last wrong image size. 2. Or duplicate sheet layer and publish new sheets. Publish to PDF have no this bug. This bug exist during publish image only. VW 2019 SP3 build 476990 64-BIt Win10 Pro
  9. @Kevin Allen That is what I need. Thanks. I do not use DLVPs a lot but It is a very powerfull tool as I see.
  10. @scottmoore ok, but you have duplicated objects if you need count screens or other worksheet function.
  11. Hi, Is it possible to have one led screen object and different images in different viewports? I am looking workflow for vizualization. Now, I duplicate screen and put it into another class. Is something better than that?
  12. He, I have ErrorLoading DMX Provider after gMA-ESPVision[3.100][6.800]-v1.220 instalation. If i use oryginal grandMA.dll, i have no error. I think gMA-ESPVision addon is broken. How is best practise to connect GrandMA to Vision?
  13. @DBLD Hey Dan, did you resolve your problem? I have the same on old PC / Win10 / GTX560Ti
  14. @David Dauphin I found it. You sould set unit and show unit mark in Unit dialog box then set Dimmension cell format in worksheet.
  15. @Ben Marx https://3dwarehouse.sketchup.com/model/fa0d52833c5d30f011f78834d904cc01/Wurlitzer-200A
  16. @David Dauphin I have no idea how do that. I am looking answer too. It is very strange that lenght have no suffix even if enabled in unit setup.
  17. I've done some tests. first worksheet: I used in Lenght column database function =VALUE('Truss Record'.'Length'), but not fixed this problem secound worksheet: I used in Lenght column database function ='TrussItem'.'Length', it fixed this problem @David Dauphin Is this a solution for your problem? @Sam Jones Do you known difference between Truss Record and TrussItem? Trusses-worksheet-sv.vwx
  18. @David Dauphin I have no pc right now but try =VALUE() function. May be this is a text field.
  19. My Elgato HD60 S is limited to 640x480 in Vision too. I use Windows 10 Pro. I can not force more resolution. It is not enough If i need crop some screens. In other software i get 1920x1080 from that device.
  20. I maked simple plugin for add individual focus point to all selected device by Pan/Tilt angle. Plugin take into account 3D device rotation. It helps me focusing conventional devices like Led Par or Led Bar and speed up my work with Vision. Please ask me if you are interesed in testing it. 04 Focus Point.mp4 .
  21. @klinzey Thanks a lot. I'll let you known if bug exist.
  22. Texture are missing when I merge .esc files. Is it a bug or my wrong workflow?
