CodeGier
21 -
Reputation
0 NeutralPersonal Information
Location
Germany
Recent Profile Visitors
DoMenuTextByName('Export Image File',0); But you have to manually type the filename for every item in the Loop... Not the best solution.
Found a solution in the VectorScript mailing list. Thanks to Bill Wood: function checkstatus : BOOLEAN; Var objty : INTEGER; btest : BOOLEAN; begin locus(0,0); objty := gettype(getparent(Lnewobj)); delobject(Lnewobj); btest := (objty = 31); {Layer} if NOT btest then alrtdialog('Exit current editing mode first'); checkstatus := btest; end;
"convert to lines" does not work in PIOs. I recommend to use an Auto-hybrid. In the attached Record do: Set Field(tempHandle,'Auto Hybrid','display','2D'); So the Auto-Hybrid is only shown in 2D-view. This did the trick in my case. Bye CodeGier
Got reply of my distributor: They are sending me a DVD with the international DEMO-Version. I am impressed of this quick service!
Hello, I am having the following issue (VW 2014 SP4): When editing the path of an extrude-along-path object, the lines of the whole drawing are shown greyed (see attached screenshot). When editing the path of my 3D-Path-PIO only the path is shown. It's hard using the PIO because you don't see the rest of the drawing when editing the path. I tested with this small sample code, and theres the issue too. Tried different projections (2D or 3D, Requires 2D, Requires 3D) but it didn't help. What am I missing? PROCEDURE Test3DPath; VAR objName : STRING; pathHd, objHd, objrecHd, wHd : HANDLE; Procedure DrawTheTest(aPath : Handle); VAR i : integer; aV : Vector; Begin for i := 1 to GetVertNum(aPath) do begin GetPolyPt3D(aPath, i-1, aV.x, aV.y, aV.z); Locus3D(aV.x, aV.y, aV.z); end; End; Procedure DrawTest3DPath; VAR result : BOOLEAN; BEGIN result:= GetCustomObjectInfo(objName,objHd,objrecHd,wHd); IF result THEN BEGIN pathHd:= GetCustomObjectPath(objHd); IF pathHd <> NIL THEN BEGIN DrawTheTest(pathHd); END ELSE AlrtDialog('Error'); END; End; BEGIN SetPref(407,TRUE); DrawTest3DPath; END; Run(Test3DPath);
OK, I am asking my distributor. Thanks for replying. I fear he will say: "ask Nemetschek NA" ;-) Bye CodeGier
I am using VW 2014 german version. For scripting it would be much easier to have an english version. The translations of menu-commands etc. are not alway enlighting. Is a demo version available (without time restriction, no saving, no printing) where I can have a peek at the english commands? I only found a download for a 30 days Trial. With my installation DVD I can install a German Demo, but english? CodeGier
hello, my path-PIO throws errors when double-clicking it and editing the path. The error is thrown in the part of the code where the profile of the PIO is set: PROCEDURE SetProfile(aObjHand : HANDLE); VAR Ergebnis : Boolean; aHand : HANDLE; BEGIN Symbol(mySymbolName,0,0,0); aHand := LNewObj; Ergebnis := SetCustomObjectProfileGroup(aObjHand, aHand); IF not Ergebnis THEN AlrtDialog('Not able to set profile!'); END; Is it possible to check if in edit mode to avoid setting the profile in this case? CodeGier
VW2013 creating auto hybrid object from VectorScript
CodeGier replied to CodeGier's topic in Vectorscript
OK, answering it myself. Should have done "Export Text" to have a look at it. Silly me ;-) : procedure CreateAutoHybrid(aHandle: Handle); var tempHandle : Handle; boolResult : Boolean; begin tempHandle := CreateCustomObject('Auto Hybrid',0.000000000000000,0.000000000000000,#0.0000000000000d); boolResult := SetCustomObjectProfileGroup(tempHandle, aHandle); if boolResult then begin Record(tempHandle,'Auto Hybrid'); Field(tempHandle,'Auto Hybrid','display','2DAnd3D'); Field(tempHandle,'Auto Hybrid','cutPlaneElevation','1500'); Field(tempHandle,'Auto Hybrid','cutPlaneBase','layerElevation'); Field(tempHandle,'Auto Hybrid','displayCutPlane','Wahr'); Field(tempHandle,'Auto Hybrid','cutPlaneClass',''); Field(tempHandle,'Auto Hybrid','cutPlaneFill','useClass2DAttributes'); Field(tempHandle,'Auto Hybrid','cutPlanePen','useClass2DAttributes'); Field(tempHandle,'Auto Hybrid','displayExtentsBelowCutPlane','Wahr'); Field(tempHandle,'Auto Hybrid','belowCutPlaneRange','infinite'); Field(tempHandle,'Auto Hybrid','belowCutPlaneFiniteDepth','4000'); Field(tempHandle,'Auto Hybrid','belowCutPlaneClass',''); Field(tempHandle,'Auto Hybrid','belowCutPlaneFill','use2DAttributesOfContainedObjects'); Field(tempHandle,'Auto Hybrid','belowCutPlanePen','use2DAttributesOfContainedObjects'); Field(tempHandle,'Auto Hybrid','displayExtentsAboveCutPlane','Falsch'); Field(tempHandle,'Auto Hybrid','aboveCutPlaneRange','infinite'); Field(tempHandle,'Auto Hybrid','aboveCutPlaneFiniteHeight','4000'); Field(tempHandle,'Auto Hybrid','aboveCutPlaneClass',''); Field(tempHandle,'Auto Hybrid','aboveCutPlaneFill','none'); Field(tempHandle,'Auto Hybrid','aboveCutPlanePen','use2DAttributesOfContainedObjects'); Field(tempHandle,'Auto Hybrid','showAsReflectedCeilingPlan','Falsch'); Field(tempHandle,'Auto Hybrid','3DConversionResolution','high'); Field(tempHandle,'Auto Hybrid','bcpDashedHiddenLine','Falsch'); Field(tempHandle,'Auto Hybrid','acpDashedHiddenLine','Falsch'); Field(tempHandle,'Auto Hybrid','smoothingAngle','1'); Field(tempHandle,'Auto Hybrid','generateIntersectingLines','Wahr'); Field(tempHandle,'Auto Hybrid','shadeFactorIndex','2'); end; end; -
Hello, is it possible having a path-PIO acting like a wall? I want to insert doors an Windows and they should cut out their shape as they do in walls. Thanks in advance. CodeGier
Hello, is it possible to read the direction out of a NURBS curve? In VW you can Change the direction in the info-bar but I find no way doing it with VectorScript. Bye CodeGier
Hello, is there a possibility to save the Batch Rendering path in the vwx? Would be a nice feature. It's very boring to change this path every time I am rendering. Thank's for answering. CodeGier
Hello, my VectorScript abilities are a bit rusty since I didn't anything with it for over a year. Testing the new VectorWorks a question comes up: How can I create the new auto hybrid object from vectorscript? Did'nt find anything about in in the 2013 function reference. What do I oversee? Thanks in advance Josef
Hello Miguel, I used SetPolyClosed(polyHandle:HANDLE; isClosed:BOOLEAN); and it worked. Didn't find that in the function reference. Is it undocumented or new in 2012 (or am I unable to find it)? Thanks for sharing that. Josef
Hello, I am working on the 2D look of a 3D path PIO using this function to convert a Nurbs into a polyline: FUNCTION Nurbs2Poly(aPathHD : HANDLE; aPos : REAL) : HANDLE; VAR h : Handle; BEGIN h := CreateOffsetNurbsObjectHandle(aPathHD, aPos); Nurbs2Poly := MakePolyline(h); DelObject(h); END; It works, but in VW2012 the polyline is closed. I do need an open one! Same behaviour with MakePoly the polygon is closed too. I tried to use OpenPoly with my code, but it didn't work either. Any idea how I get an open polyline (or polygon) out of my code? Thanks in advance. Josef
