Diego - Resuelvector
    374
Reputation
204 Spectacular
Personal Information
  • Occupation
    Architect
  • Homepage
    https://www.vectorworksoutsourcing.com
  • Location
    Bolivia
Contact Info
  • Skype
    diegorodrigo@resuelvector.com
Recent Profile Visitors
3,681 profile views
  1. Thank you, I'll check those options to see if I have the values and settings right
  2. Greetings, I have a Vectorworks model and it is georeferenced but the moment I export the file to IFC the georeference information gets lost, even if in the Site Data the Reference Latitud and Logitud are displayed correctly What other settings must I check to ensure a proper georeferenced export from Vectorworks 2023?
  3. Hi @Pat Stanford, did you manage to fix this issue? I have the same problem
  4. Yes, I don't usually do that,I clip the roof and add a custom Skylight symbol
  5. For Skylights, the only way is create a Custom Record and a Custom Tag to show the desired info
  6. Yes, a quick fix in your situation, could be to use a 2D polygon to clip the underside of the slab, It would give you the desired section detail
  7. I hope there will be an option to access this plug-in through the Partner Products portal, is in german, but the plug-in does some amazing stuff
  8. 1.The section fill is controlled by the Section Style Class, changing it you can show different fills/hatches , etc 2. Are you creating a horizontal Section Viewport or a regular 2D plan?
  9. You need to assign a IFC definition to the symbols, even generic IFC definition will be enough, otherwise the objects will not be recognized by the IFC softwares
  10. You need to define a component in the roof to clip the walls
  11. Put a 3D locus to each of the points you want the fence to lock, then use the 3D mode of the fence Tool
  12. A way to do it is ungroup the main roof and clip just the remaining Roof Face in Top/Plan view
  13. With the cabinet tool you can't do that, un-check the countertop from the cabinet, use the Countertop tool and then you can create an opening for the sink, but you will have to manually adjust the size of the hole in the Countertop to fit the sink
