391 -
Reputation
208 SpectacularPersonal Information
Occupation
Architect
Homepage
https://www.vectorworksoutsourcing.com
Location
Bolivia
Contact Info
Skype
diegorodrigo@resuelvector.com
Recent Profile Visitors
6,496 profile views
Greetings, from where you imported your BIM objects? Revit?
I think the best approach could be do a rotated cabinet and you can cover it with a countertop
I'm having the same issue after a Vectorworks 2026 crash, all the PF where I'm not the admin are asking to be reseted, I've reinstalled Vectorworks with no luck
Stair Tool Rehab for 2050
Diego Rodrigo - RV replied to bc's question in Wishlist - Feature and Content Requests
Light years ahead..... -
The best approach to create a simple, solid standing seam is to use the Framing Member and add a custom profile of a standing seam metal sheet, then duplicate it along a roof. However, this method will break down if you have complex roofs. Alternatively, you can use a Surface Array with a 3D symbol of a standing seam metal sheet. Both methods are somewhat overkill and can make your model a little heavier to manage.
Review of whether you are using the right Section line class and if that class is ts with a solid fill
- 1 reply
- 1
Hi Mike! I usually start by slicing the model very thinly at 2 or 3 feet intervals for all the floors of a point cloud and saving views for the Floorplans, and also several slices for sections And try to find averages between corners of rooms, because the point cloud will have a ton of points and they are not like perfectly aligned in straight lines A good software for extracting lines from point clouds is PointCab, it's a little expensive if you do a couple of point clouds a year, it's a cross-platform software and great for point clouds
You will need to use several NURBS curves to achieve that or a play with subdivision modeling
Sadly for the underside of the stairs, I find myself doing some acrobatics too if there is a lot of space between the underside and the actual stair structure Usually, I leave that part for the CD set, in DD sets I use 2D linework in sections until the design has been ironed out When, if, the design moves forward then I'll play with Roof faces and wall components to even obtain schedules and BOM
Is better to not use the railings built on the stairs, I had better results using the new Railing tool in 2024, you can control better how different flights of railing connect to each other
IFC with georefereced geometry fails to export correctly
Diego Rodrigo - RV replied to Diego Rodrigo - RV's question in Troubleshooting
Thank you, I'll check those options to see if I have the values and settings right -
Diego Rodrigo - RV posted a question in Troubleshooting
Greetings, I have a Vectorworks model and it is georeferenced but the moment I export the file to IFC the georeference information gets lost, even if in the Site Data the Reference Latitud and Logitud are displayed correctly What other settings must I check to ensure a proper georeferenced export from Vectorworks 2023? -
Hi @Pat Stanford, did you manage to fix this issue? I have the same problem
Creating a skylight schedule/ data tags.
Diego Rodrigo - RV replied to jtempleton's topic in Architecture
Yes, I don't usually do that,I clip the roof and add a custom Skylight symbol
