JSZitelman
    3
Everything posted by JSZitelman
  1. Do you know of a way to just select the .03 lines so that I can adjust them to .05 line weight?
  2. Thanks for the thought. While changing the line weight does work, it is a bit much to change the line weight on every part of the drawing, multiple layers, etc. Particularly when different line weights are used with a specific purpose in mind. Half of the drawings I work with are created by another user, otherwise I do change line-weights in the drawings I create.
  3. I'm using VW2011 on Win 7-64 bit. When I print my project file, all dimension lines are missing as well as some lines on objects. I have tried printing to multiple printers and the issue remains. I have tried exporting to PDF as well as printing to PDF (via Acrobat Pro) and the lines show up in the PDF, but still do not print out when I print the PDF.
