258 -
Reputation
48 GreatPersonal Information
Occupation
Product Marketing Manager Entertainment at Vectorworks, Inc. for Spotlight + Vision and Braceworks
Homepage
www.vectorworks.net/en/spotlight
Location
United States
Contact Info
Skype
fbrault812
Recent Profile Visitors
2,443 profile views
This may not be what you are looking for, but you can either use the Vectorworks Origin menu set under Tools->Origin-> to drag the VWX internal origin to the red dot, or Show Snap Layers, select all, and then drag the Red dot by it's center point to the VWX internal origin...
Ability to export PDF pages and images directly
Frank Brault replied to karstenwolfGL's question in Wishlist - Feature and Content Requests
@KLAD: This would be useful in the case when the recipient of a file with PDFs or other resources does not have access to the original PDF. -
@karstenwolfG: Currently, transferring a pasted PDF file from Vectorworks is supported with the File->Export->Export PDF... command. -
You may be able to reduce the intensity of the BG shader section of the Texture definition...
The Simple Stair object, defaults to just this type. It is available in the Building Shell toolset in my workspace, but the location in your configuration depends on the product you are running. If the stair does not insert as desired, use the object Info Palette to set the Style parameter to Masonry. You can configure a lot of details that you may need, such as hand rail(s) and specific number of treads and riser height, either by double-clicking the tool icon before inserting or in the Object Info palette once the stair object is inserted in the drawing.
Have more than one Units type in a drawing
Frank Brault replied to MHBrown's question in Wishlist - Feature and Content Requests
Hi Mike, I just checked and something that I used to be able to do in the software is at least partially disabled; What I found is that that you can edit an existing dimension object units mark in the drawing space to change the units mark, such as to edit the inch text (") to a meter (M) and the dimension object redraws to the new length as determined by the units mark that you entered in the dimension object. This is not as useful as I recall, by a long shot. I remember that at one time, if you edited a units mark in a dimension object label, the result was, rather than changing the length of the dimension object, the dimension would remain the same length and would change it's text to the display the existing length in the new units mark; This no longer works as I described above; Sorry that I didn't check this before posting... -
This probably doesn't fully address your needs, but although each VWX file can have only one designated drawing unit, you can edit the unit on individual dimensions to whatever you want. Frequently, there will be instances in a project where I want to assign a unit to a dimension different from the one assigned to the file. Obviously, this does not address scenarios where it is desired to assign the dimension a particular unit to one sheet, and a different unit to another sheet within the same file, but I have often adjusted the units of a few of the dimensions on one part of a file when the scale of the detail is wildly different from those of the rest of the file. Not what you are asking I know, but this little known feature has helped me to occasionally address this... -
Hi Bruce, You may be able to store your preferences, or multiple sets of preferences as VectorScript scripts that you can run from a menu command in order to load saved preferences after a crash. (obligatory recommendation to re-install Vectorworks if Vectorworks crashes frequently) To save a preference set, open Vectorworks to a blank file and manually set your prefs, for a particular type of project, or you could also just open an existing file that uses the desired prefSet. Then, export the file with the File->Export Script command, to a folder that you can get back to on your machine. The file that you created has all of the geometry that was in the file in addition to the prefs settings. So, navigate to the Vectorscript text file that you just created, and open it with a text editor. You will see the script that begins with {Global Characteristics} with the specific prefSet that is saved with the file, as shown below: {Global Characteristics} DrwSize(1,1); SetUnits(0,2,0,0.0254,'m',' sq m'); PrimaryUnits(0,2,2,2,6,TRUE,FALSE); SecondaryUnits(7,0,2,FALSE,FALSE); SetPrefLongInt(162,2); ... COPY ALL the statements down to... | V {End of Global Characteristics} Select and Copy this text, including the line that says {End of Global Characteristics} and paste it into a new blank text file document and save it to a convenient folder on your hard drive. Then, when you want to load back your prefs, to the desired Vectorworks document file, just open the desired file, use the Tools->Plug-ins->Run Script command to navigate to the desired script file, and the prefs will be loaded. You can do this for any prefSet variations that you require. Not quite one button preferences, but more versatile because you can have multiple prefSets. Let me know if you have any questions or if these instructions could be clearer...
You can do a custom selection of lighting objects; also you could turn off ambient lighting…
Apply Different Textures to Extrudes
Frank Brault replied to Sky's question in Wishlist - Feature and Content Requests
You may have tried to apply the texture after using the Convert Text to Polylines command and ungrouping. If you want control of individual characters, you should extrude individual chars in separate operations... hth... -
What is happening with wall joins in horizontal section viewports?
Frank Brault replied to Ride's question in Troubleshooting
Just a guess since I haven't seen your file: It could be that you need to manually join the wall joins that are failing here... hth... Also, check the Merge Cross Sections option under advanced properties? -
Hi Ross, Vectorworks has a different system for handling shortcuts while using tools; The help is here: Tools->Workspaces->Edit Current Workspace Switch to the keys tab to view the default mode bar hotkeys, or select the tool tab to view the default tool hotkeys. https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FStart%2FModifying_tool_palettes_and_tool_sets.htm&rhsearch=default tool&rhsyns= &rhhlterm=default tool ...but the short answer is: While editing a polyline with the reshape tool (shortcut access: '-' hyphen sign), at any time you can access each button group directly by the keyboard. So while in the reshape tool, hit 'u' to switch among modes in the the first button group to access the 'Add Vertex Mode' (plus sign icon). Then drag on a handle in the document window to add a vertex without letting go of the mouse. You will find that all operations within the tools are accessible with hotkeys. Different from Bluebeam of course, but complete within the Vectorworks universe...
- 1 reply
- 2
- polyline
- reshape tool
(and 1 more)
Tagged with:
'Multiply' / Transparent fill colour objects
Frank Brault replied to Amanda McDermott's question in Wishlist - Feature and Content Requests
Hi Amanda, I responded to this wishlist - feature post here: -
Hi Amanda, I believe that placing your fill object below or underneath all the other objects to be seen against the fill object, would produce the intended effect with few exceptions. One consideration would be the layer structure of your document that would possibly make it difficult to place your fill object in the necessary position in the object list. This may make it necessary to create a custom layer for the purpose of managing object fills which may be as simple as placing it as the bottom-most layer. I may not be understanding your request completely. So please, reply here if I am mis-understanding your request...
From what you give, it may be one or more of several possibilities; As Pat says, we can help if you provide specific information on your process. Ideally, you can post your file here. As a 1st guess, try using Final Quality rendering on your scene.
