Siva
Content Count
41 -
Community Reputation
0 NeutralAbout Siva
Rank
Greenhorn
Personal Information
Occupation
Architectural Technologist
Location
Toronto,On. Canada
Thank You Jim. Its working. Siva.
When I click install VectorWorks, I get a message " InstallVectorks can't be opened because the identity of the developer cannot be confirmed." Anyone has suggestion. Siva Imac 10.8.5
Memory error when saving file, vwtmp file being created, why ?
Siva replied to John Whyte's topic in General Discussion
I have the same problem. An year ago I posted this on this forum. No one gave a suitable solution. Siva. IMac OSX 10.8.5 VW Architect 2014 -
Thanks Jim, the problem I have is with this VWTMP existing, whenever I tried to save my file, I get a message "The file save operation failed. Please try again, or save to a different location". I have to save as and replace the original file or manually have to delete this VWTMP file. Siva VW 2014 Architect Imac Intel 10.8.5
Sometimes when I save my file it creates an additional file with VWTMP extension. How can I avoid this? My files are saved on server. Thanks. Siva VW 2014 Architect Imac Intel 10.8.5
Thanks for your info. Yes. I use Sketchup. I an unable to access your site:techboard.nemetschek.net. Can you help me on this please. Thanks. Siva.
It is VW 2009, 2010, & 2011. This color wheel is within the program. A colleague of mine running this same program on Windows and he has no problem. Siva.
Draw an object (rectangle or polygon). Give a fill. Click on the fill at attribute palette. Color pattern opens. Click on color wheel at top. When you try to move the slider on the right side up or down to darken or lighten the color, program freezes and crashes. This happens on VW10, 11 & 12. I wish I can attach a picture to explain more clearly, but I don't have my own web site to do that. Can somebody help me how to resolve this please. Thanks. Siva. Mac, Intel Core 2 Duo OS X 10.5.8, 2G ram
I wish the parking tool can be modified to used on a curve line. I know this is available on Landmark, but this will be more useful on VW Architect to do large site plan. Siva Pushpanathan VW 10 Architect Imac 10.6
If you accidently press any number buttons on the right side of the key board it changes to corresponding view. Thanks. Siva.
Thanks, a lot of steps but it worked!
Michael, I have 2010 sp1 (build 114226) 1. Done 2. in organization window, design layer tab made new layer 3. see 2 4. ok 5. no source button/dialog so what is next?
Hi, I am new to vecorworks and want to know just how to Reference a file. I have a plan, i want to insert it into a site plan. I have opened the site plan and referenced it in the Organization window, but the plan does not show up on screen of in the resource browser. Is there a tutorial out there because the manual is CRAP! Thanks,
Yes ionw, you are right. The layer colors are own. When I turned it off, its working. But usually it doesn't happen in earlier version. Thanks for your help. Siva.
After importing an old file to VW 2010, when I use the reference marker tool, it comes with a black fill. This doesn't happen in brand new file in VW 2010. Any suggestions please. Thanks. Siva. VW2010 Architect w RW Imac 10.5.8
