Content Count
44 -
Calendar
Everything posted by Martijn Wingelaar
Worksheet formula help needed
Martijn Wingelaar replied to Martijn Wingelaar's topic in Vectorscript
@ MullinRJ That works thanx for the help. -
Let me try that thanks. -
Hello Users. I've got a worksheet formula translation problem. I got this code from my excel file. But that doesn't work with my worksheet. Does anyone has a solution? =ROUNDDOWN((E6-SUM($H$9:H9))/D10;0) I added my xls file as well for reference how the code should work. Greetings M Wingelaar. Worksheet code question.xls
Hello Users. Did anyone had this problem before? I try to insert multiple truss connections on a truss. But as I insert new ones the other disappear. Any ideas?? Greetings Martijn Schermopname 2020-08-28 om 19.57.51.mov
Hello Guys. Sorry for the late responce. But I was on a small holiday. 🤘😀🤘 But i'm gonna look into the files and options. I hope i get it working. Fingers crosed. Greetings M Wingelaar
Hello M Graf. Thanks for the response. I'll have a look at it. Greetings Martijn.
Hello Users. Can someone help me with a small problem. I'm trying to make a a connection between 1 and 2. Where if the outcome is smaller or equal to let's say is 0,5. It will show a a zero in my WS1 worksheet column E. Can't get it to work. Should be quit straight forward i think. Any ideas? Greetings Martijn WORKSHEET 4_ v2020.vwx
create report doesn't create a report
Martijn Wingelaar replied to Peter Telleman's question in Troubleshooting
Ben je er al uit? Greetz Martijn. -
Hello Mike. I've got the same with your drawing. But I've inserted some structural elements and a truss and ..... tata.... That works. Maybe it's the house rigging points tool. Personally i don't use those. Cause if you add a "house rigging point to a knot" on a beam. You get the knot loads but it won't calculate the load on the beam "Structural Member". If you use the click inserting mode it will work by the way. But not on a inserted truss. It won't snap. Greetings Martijn. Insert Bridle-quicktime.mov
Hello Peter. Sorry for the late respons. Check this post i've posted a while ago. Greetings Martijn.
Hello Mike. You probably need to change the Bridle Preferences. I use the Apex Height setting most of the time. But the problem with the tool is it works the wrong way around. Don't add a hoist. Add the truss and then create the bridle. In the truss a red square/diamond will appear click. And the bridle will be created. Choose replace down leg with hoist from the object info pallet. And that's it. The thing is that all your choices in the Preferences menu are the choices you don't want to use. But we don't have a choice. Hope this helps greetz Martijn.
Marionette node with Braceworks symbol
Martijn Wingelaar replied to Martijn Wingelaar's topic in Braceworks
Hello Justin. I use the hinge that way but I liked the wrapper couse it made the angle adjustment easy. I hope there is a solution with a Braceworks symbol. -
Hello all. BenV posted a cool node last year. He made a swivel CB. Now I took his idea to use it with a truss bookcorner I've had a job last week where I needed it with braceworks. The only problem is that the symbol is on in an angle but with the node I can adjust it I only don't get it working with a braceworks truss symbol. Does anyone knows if that's possible and how? Greetings Martijn Bookcorner example.vwx
Hello Scott Good question but... The eye-bolts are connected to a structural member "beam" I've been drawing a lot of structural members to speed up my bridle drawings. But it turns out that my drawings are becoming really slow. And it takes a lot of time for VW to process all the data. And the member is divided in to parts which means the bridle tool will snap diagonal instead of horizontal. Greetings Martijn
Guys why don’t you make your own symbols? Just edit the stockbridle file I’ve posted mine a while ago and updated it for my personal use a lot after that (beamclamps, basketsteels,all length i use....) take a look and edit the stock file
Can't calculate small cantalever
Hmmmm Bummer- 2 replies
- braceworks
- rigging
(and 2 more)
Tagged with:
Hallo Forum users. Does anyone know why i can't calculate this small cantalever? Weight wise should it not be a problem. Any idea's? Greetings Martijn. Braceworks error.vwx
- 2 replies
- braceworks
- rigging
(and 2 more)
Tagged with:
@ Moritz and all other users. Again. A bad Tool. So what if I want to create a 3 leg bridle and all the hanging points are at a different height? Like in a spaceframe with an extra level? "Image 1". Leg 1 at 11m, Leg 2 at 15m, Leg 3 at 19m. This happens a lot weight wise. Now in the tool I have to give a trim height that's for all the legs. This is the wrong way around. Snap to a House Rigging Point or Structural Member. Set this as trim height. Some more things I think are strange. 1: Bridle leg angle. How can you choose the max angle? What's the max angle? 120 degrees? Why if I want to make it 130 with a load of 500Kg I get an equal load of 590.31Kg in both legs. If I use 1t steel then what?? 2: Bridle leg length. How can you choose the leg length before you've created the Bridle? Metric you can choose steels with a 25cm interval. Leg 1 should always be the shortest. And "you prefer this one without a S.T.A.C or Chainclutch". What does not work in the Bridle Configuration. The creator of the tool is thinking the wrong way. Is not a Rigger and got the advice from the wrong people. There are some good examples of how it should work. 1: http://www.vectorbridle.com/ a vectorworks plugin 2: http://bridlecalculator.com/ a AutoCAD and Bricscad plug-in
Structural member
Martijn Wingelaar replied to Martijn Wingelaar's topic in Wishes Granted / Issues Resolved
Just updated to SP1 and it’s working now- 1 reply
- 2
Can someone draw a round tube as a 2019 structural member for me. I need a 300mm roundtube thickness doesn’t matter with a length of 5305mm. I wanna use it in braceworks but i can’t draw it in spotlight. I think you need Designer for that Greetings Martijn
Hello Sebastiaan. I've started so redo all the steel length and chains. I'll add my file. I'm still working on it now I only got metric length. And I also discovered that you can only snap to a hoist hook with a 3 lag bridle. And leg one should always be the shortest without a chain or S.T.E.C. Greetings Martijn. Stock Bridle.vwx
Hello Users. I've been trying the Bridle Tool. But I think is a mess. They tried to make something but didn't understand how. 1st The bridle doesn't snap to a hoist that's inserted with the Hoist Tool. You can change the downleg for a hoist. But what rigger start with designing bridles before you got a hoist. 2nd Why do is there always a downleg "what's called a drop or stinger in the business". A downleg should be used if the hoist does not have enough chain length or you need a steel for a deadhang. 3th why is there a 4 leg bridle choice. A 4 leg bride won't work cause there's always a leg who does nothing cause steelwirerope is never exactly on the mm. 4th They should change the trim height to apex height. If the tool snaps to a house rigging point or structural member you don't need a trim height you need a apex height. What I'm missing is the text from the bridle configuration in the drawing instead of the assembly diagram. How is the rest thinking about this? Greetings Martijn.
Hello Users. The Create Report List All Symbols function is gone in VW2018. Is there a way to do this in 2018? I use it a lot to check DWG imports or other VWX drawing i get from 3rd party suppliers. Anyone? Greetings Martijn.
