57 -
Create steelflex slings from existing slings in the library
Martijn Wingelaar replied to ldenambride's topic in Entertainment
Hello ldenambride. If you are going to make your own pickups. Maybe it's a good thing to keep in mind is that all the by Vectorworks provided slinging methods are actually wrong. And disapproved by most truss manufacturers. I have made my own it's not so difficult to do. Greetings Martijn -
matteo17 started following Martijn Wingelaar
Hello Matteo17. Yes you have. Under Hoist Tools - Hoist Standard-Euro - C1. But you have to check if all the data is correct. By most of the hoist the body weight and chain weight are incorrect. Greetings Martijn
Hello forum users. I am trying to create a Data tag from a selection of trusses. Is there a way to do this? I can't figure out how to do this. I try to get all the length of the used trusses in a selection. Greetings Martijn.
Stefan B. started following Martijn Wingelaar
Hello Forum users. I've got a question? Is there a way to get a Data-Tag rotate/align with a Bridle Leg? I've got a Data-Tag for my steel wire length as I configured it in the Bridle Configuration. Now I add the Tag to every bridle leg and the manually rotate it with the rotation tool. And this is a lot of work. Is there a way to auto rotate it to the leg? Greetings Martijn. Rotate along bridle leg.vwx
Quick and Dirty venue beams for Bridles/beam loading
Martijn Wingelaar replied to Wood's topic in Braceworks
Hello Wood. I'm a Dutch rigger and I'm having a lot of mail contact with jcogdell. All you're problems you've got I also discovered a few years a go. But I figured a lot of ways to work around the issues. First.. And this is how I see it. The auto bridle tool doesn't work. If you take structural members the snap point are never exact where you want your bridle. I prefer to draw a line "for a 2 leg" over the hoist crossing the beams and then draw a bridle. If you need a 3 leg bridle 🤔 how does vw knows from where you want to connect the legs. It always chooses the closest knots or snap points. For this part.. I don't care about influence lines or any of the advanced BW calculations for the venue steel. You can turn the influence lines off in your classes. But those calculations are really important. You can maker on a 5m or 16ft beam 20 3 way bridles and a 3 way can be quit flat "if you know your rigging" So the forces in X and Y can run up extremely fast while the Z forces stay the same. This.. Why aren't baskets being generated with the 'Assign parts automatically' button? Is in my opinion the worst tool in the BW plug-in. A 4 way bridle is retarded but the auto parts does not work at all. It just throws in steels at random blah blah blah. I discovered this this week. Make your plot create all your bridles make sure everything is good. Take the Select Similar Tool "magic wand". Select all bridles go to the Bridle Configuration. Delete for all legs all steel Leg 1,2,3 and Down leg. Then add the basket and Basket Dimensions for just one bridle if you got 3 way bridles select one of those. Then when you exit the Bridle Configuration. All fields are empty and every bridle has a basket and basket demensions. I do a lot of +200 hoist shows and adding steel for a bridle is just a ty job. But you have to do it. I created a simple data-tag just for steels. I add that to every leg in my drawing "that takes max 20 min". So when I add steels I can see what bridle I already did and when I print a bridle plot for the markout. I've got all steel length for every bridle "Shot 1" You can configure your hoist also through the Spotlight - Spotlight Numbering menu. You can tweak a lot of things there. Finally I think you should not try to skip steps in the rigging design procedure. Designing a rigging plot takes skill and time. All the automated tools I think are a nice extra. But if you start to trust BW to do all work and calculations for you...... nahhh I don't know. I wouldn't blindly trust it. Greetings Martijn. -
Hello Forum Users. I'm trying to make a Data-Tag for my bridles. With the steel length that I assigned in the bridle configuration tool. My Data-Tag is build to first show the Basket and then the Leg Steel info. But that means the basket is always on the left side or beginning. But sometimes I need it to be on the end. Depending how the leg is configured. Is there a way to mirror the Data-Tag with the text? I've added a sample file if that helps. Greetings Martijn Data tag auto mirror.vwx
Hello everyone. Question. There is a new Data-Tag function where you can display the bridle parts in the tag. But? you can only display from one leg and i can't get the info from the other legs. Anyone any idea if it's possible to combine the data or the data-tags? Greetings Martijn. 1106062597_Bridledatatag.vwx
custom F34 truss corner can't get the angle right
Martijn Wingelaar replied to Frans Jansen's topic in Braceworks
Hello Frans. What you can try to do is: Create a truss hinge. If you go to the Eurotruss FD34 Corner resource. There's a hinge folder. You can insert it into a new file. Then edit it. Select all exit the edit and paste in the drawing. Make it into a new symbol and convert to truss. In the truss properties choose the hinge tab. Under conectable with type F34. That should work. Greetings Martijn.- 1 reply
- 1
Worksheet formula help needed
Martijn Wingelaar replied to Martijn Wingelaar's topic in Vectorscript
@ MullinRJ That works thanx for the help. -
Let me try that thanks. -
Hello Users. I've got a worksheet formula translation problem. I got this code from my excel file. But that doesn't work with my worksheet. Does anyone has a solution? =ROUNDDOWN((E6-SUM($H$9:H9))/D10;0) I added my xls file as well for reference how the code should work. Greetings M Wingelaar. Worksheet code question.xls
Hello Users. Did anyone had this problem before? I try to insert multiple truss connections on a truss. But as I insert new ones the other disappear. Any ideas?? Greetings Martijn Schermopname 2020-08-28 om 19.57.51.mov
