kenpayson
    24
Reputation
2 Neutral
Personal Information
  • Location
    Santa Fe
  1. Did anyone ever figure this out? I'm on VW 2020 and can't get any of the options to create a solid black text.
  2. Still having this issue in VW 2020. Very frustrating.....
  3. Thank you for this post - I was about to post the same complaint about the color-b/w batch changes. I eagerly await the bug fix.
  4. Everything has been smooth (knock on wood) for me for a while now. Looks like they finally fixed it!
  5. Wow I hadn't heard about this -fortunately I have a retina display on my MacBook Pro and a Thunderbolt apple external display. Hope all works when I upgrade. With all these issues I think these software developers need to take some time off - are they really improving anything?
  6. I am finally planning to upgrade to Mojave from High Sierra. It sounds like it will be no worse?
  7. I can't get them to admit this is an issue - but it persists, though isn't as frequent as it used to be. Not sure why as they haven't issues another SP update for a while... Thanks for letting me know I'm not crazy..
  8. I'm on High Sierra w/ Service pack 2 - same problem. I hadn't heard anything back from anyone on this and was beginning to wonder if it's my graphics card. Have you had any other issues w/ 2019 + Mojave? If not I may as well upgrade. thanks, Ken
  9. I updated to SP2 today, hoping my issue would be solved, but it wasn't to be. Since upgrading to VW 2019, my worksheets placed on annotations of sheet layers sometimes show up in the wrong location, only to show up in their proper locations after c-c and then v-v (zooming out and then back in) See attached screen shots. In the first one, I've selected 'all' in the annotation and the orange square shows where one of the worksheets should be when the sheet layer is first opened. That blank square is where I have to click in order to select the sheet layer, which can be seen (but isn't clickable) in the wrong location. Anyone else have this issue? It occurs on older files as well as new ones native to 2019. Thanks, Ken
  10. Hello Vectorworks - it seems there are a lot of issues with worksheets - please fix!! Thank you.
  11. My worksheets are in Sheet Layer annotations. The sheet layer opens with the worksheet in the wrong location. When I zoom in or out, the worksheet snaps back in to it's proper location. See attached 'before' and 'after' screen shots. I hope this is fixed soon.
  12. I also have worksheet issues - the program (Architect) doesn't crash, but worksheets on sheet layer annotations show up in the wrong place till I change the zoom level. This happens with new 2019 files as well as older ones that have been updated. Not sure what's up?
  13. I had a problem with wall and 'window-in-wall' and 'door-in-wall' behavior in 2019 and it persists with SP1. This is frightening as I'll be working on a 3D model with some very complicated wall shapes, as well as mostly straightforward level height walls, and the doors and windows seem to move or disappear without warning. Undo still won't work with walls. Many times a wall will become 'frozen' - the doors and windows won't be moveable or changeable when inserted in the walls. This is not only slowing down my production by more than 50% since I have to constantly redo work, but I'm not sure if the file will maintain any level of integrity. I'm on a deadline and now forced to deal with these issues. I regret upgrading to 2019.
  14. I started using 2019 2 days ago and there are many odd things happening with editing, copying and pasting walls. I have experienced the undo issue - where a wall will unexpectedly go to an odd angle and when I try to undo, undo stops working completely. Very disappointing. I already cleared 2018 off my computer and now fear I'll need to re-install it just to get my work done. Here's the file in progress: 4044 MADISON 9.27.18.vwx
