JackBuilt
107 -
Everything posted by JackBuilt
Forgive me for such an elementary question. Can I insert a Slab and have it slope ie: a garage slab that drains towards the garage opening? On another note can a depression or recess of difference in thickness be made? Say for an elevator pit, or for stepped-down space or garage entrance weather lip. Grazie, thanks, merci
Hello Juan, I went back through my history and it was actually not 2021 help, it was 2016. I have been searching around and wound up here. https://app-help.vectorworks.net/2016/eng/VW2016_Guide/ResourceBrowser/Using_the_Resource_Browser.htm#XREF_12623_Using_the_Resource
Thanks for this tip. It seems the associative points can be determined by the green squares. Yes, I get them on the wall vertices but not on the PIO window objects anywhere. I can move walls and have the Associated dimensions update. Just need to figure out the PIO settings that will allow this as well. Thanks again.
Case in point. VW 2021 help linked me to a 2012 Resource Browser YouTube video this morning! WTH?
Are you saying the raised heels are outboard of the bearing wall? Modifying the trusses is possible with a prescribed repair of glue, gussets (plywood) and nails. You will most likely need to devise the repair yourself on paper and have it P.E. stamped IMO. Raised heels outside wall.pdf
Howdy, Is there a repository of sharing style resources? I am looking for a wall style that uses Zip-R or similar sheathing. Thanks Jack
it might not apply here but I think there is a firmware patch related to the throttling also. Personally I wish I could get those specs (well discrete graphics with big RAM) in the 13".
Does this info consider the new 16" MBP? Seems like the new 8 core i9, or even the 6 core i7 - either with the Radeon Pro 5550M 8 GB should be pretty powerful.
For my latest house my 2nd story will be partly comprised of a bedroom closet and laundry built within living space trusses over the garage. I'm planning currently to "fake" the walls with the wall tool and model the roof. The walls will have a clipped 45° from ~6' to full height. I guess i can just reshape the walls to match the truss profile Recommendations for workflow for this?
Laser Measuring As-built (auto import to .vwx)
JackBuilt replied to DesireeRoss's topic in General Discussion
Leica have recently introduced the BLK2Go. https://blk2go.com. Can't find price yet. My Structure Sensor with Canvas app does make a mesh .obj which can be imported. Haven't manipulated any meshes yet. I think there is some promise considering the relatively low investment. -
Clip cube top view section viewport at level to capture coffered ceiling with some some 2D annotations for non-captured elements?
Definitely bringing our sticks and plenty of golf balls to lose!
I installed 2020 before starting to model this deck. It remains true that once you make a solid subtraction to a framing member it is no longer a framing member PIO. I used extrudes for the stair carriages. On another note For the life of me I could not get the rails I wanted out of the rail tool (RDI vinyl rails). So I wound up fully modeling them.
- 4 replies
- framing member
- custom
(and 3 more)
Tagged with:
What process or tool allows modifying a framing member while retaining the plug-in attributes. ie drawing a deck using 2x12s and cutting the member to be stair a carriage? Is this possible?
- 4 replies
- 1
- framing member
- custom
(and 3 more)
Tagged with:
IMO this is one of the main limitations of the Story setup. The software should do the hard parts of the math for you via the Story setup diaglog. Thereby if as often is the case you change house elevation during to dig for some reason you can simply make 1 edit that cascades the changes through the model. I posed this question in one of the model set threads. I try to set my 1st floor Z to anticipated or surveyor designated ELV. Then I do the math for all the layers or stories. For simplicity the Story setup dialog should allow that method and alternatively allow setting Z to zero but/AND allow you to input a "0" House Z = DTM 604.67 as an example. Further the dialog should maybe allow you to point to the reference DTM file. Doing it that way might take some of the confusion out.
Thanks a million Mike. Thats what I needed.
- 16 replies
- 1
- window tool
- color
(and 1 more)
Tagged with:
Window_Problem.vwx Started new template file. Created class for shutters. Gave it a texture. Created a window with rustic shutters. No textures.
- 16 replies
- window tool
- color
(and 1 more)
Tagged with:
Thank you for the help guys. I have something buggy going on but I copied mike's window into my file and changed my shutters to his shutter class and I can now change the texture of the rustic shutters. Interestingly even if I change the window's shutter class to a class I created I cannot change the texture AND the graphic control is still dictated by Mike's imported class. Dunno don't care that much at this point. This house will be sided and done soon. I'll be updating to latest SP or 2020 and check to see if this is resolved for my next house.
- 16 replies
- window tool
- color
(and 1 more)
Tagged with:
It seems that my issue is that I am trying to color or texture a "Custom Shutter". Tried on Wes' shutter.test file as well (switch to custom shutter and texture does not apply). As shown I am using the Rustic shutter and I cannot change its attributes it seems without changing the window itself as well. Opening Wes' shutter.test gives me window classes along with window and trim classes. My own file does not have these classes. Wes did you create these classes or are the generated by the Window tool?
- 16 replies
- window tool
- color
(and 1 more)
Tagged with:
I am in fact running 2019 SP3. This file was created in 2018 if memory serves my correctly.
- 16 replies
- window tool
- color
(and 1 more)
Tagged with:
Looking at the Window Tool Settings dialog as posted there by Mike, the only classes that are created by window insertion are Glazing. The other <Window Class> does not appear to exist in my file. I did create a class for the shutters but it has no effect on the already inserted shutters.
- 16 replies
- window tool
- color
(and 1 more)
Tagged with:
The windows are VW2019 Windows tool objects. Update Plug-in objects did not seem to work. In the OIP I can change the Texture such as Arroway Walnut Black getting me close but that changes the window and the shutter at the same time. Thats the closest I can get to what I want for now,
- 16 replies
- window tool
- color
(and 1 more)
Tagged with:
