Content Count
89 -
Community Reputation
10 GoodAbout Simon Allan
Rank
Apprentice
Personal Information
Occupation
Visualisation for Entertainment Design
Homepage
www.exactly13.com
Location
United Kingdom
Recent Profile Visitors
Interesting to read you got better results with HLR in VW2020. I was curious so did a test on a simple drawing (5 viewports on one sheet, all HLR) that I am currently working on in VW2019. Here are the results. VW2019 (SP5.3)=345 seconds VW2020 (SP1)=373 seconds Like usual...disappointing.
Looking great Scott!
ok...All understood now, I think. So just to confirm, doing hidden line renders on curves may not be able to show a perfectly smooth curve? If so, is this a bug that can be sorted or "just the way it is"? Thanks
OK, so why does the other object (the one using the non curved profile) render without issues? I have tried various segment amounts and it still seems unpredictable. Are you saying this is how I fix it? If so, can you please give more details as I could not find that command. Thanks
Using an extrude along path (my path was a circle cut in half) and the same profile (with rounded corners) I get the same "faceted edge" result. The only difference was the 3D conversion setting behaved as expected in that it got worse the lower the setting was. It was still faceted when set to "Very High" though.
@Charlie Winter My main focus is to get VW exchanging data with C4D via MVR. I am also interested in the potential with media servers especially relating to pixel mapping. I personally believe MVR will only grow and get widely adopted when it is working to a point that other 3rd party applications can utilise it.
I don't use vision at all and and neither do any of my clients.
Thanks. Hopefully someone can clarify if this is a bug or user error. I would have hoped that this particular issue (lack of rotation) did get looked into during SP3 testing as this was first brought up back in November.
Thanks for looking at this Kevin. I changed the setting to low on the file I uploaded and it behaved as your pictures show. I also tried on another drawing (sadly I can't share that one) that has the same issue and lowering the 3D conversion setting had no effect. Neither did adjusting the segment angle of the sweep. I think it has something to do with the profile shape and that curves are present. It also might be a hidden line thing too. Either way, the behaviour, as you pointed out, does not make sense.
Hi, Been having some issues trying to get a smooth sweep when using a profile that has curves in it. I have attached a simple sample that shows the error. You will need to zoom in on the edge to see it but it is not a smooth curve. I dont know if this is a graphics setting or something else. Any help appreciated. thanks. Sweep Issue_VW Forum.vwx
Now on SP3 and still getting issues. I drew a new version (attached) of the test plot in SP3 just to be sure and when importing back into VW, all the fixtures disappear. The fixtures are in the drawing because I can select them...but that is because I know where they are. I also see the don't have the rotation info with them which was the main issue in the original post. From what I can tell, the difference between SP2 and SP3 was SP2 showed a place holder for the fixture. I know there have MVR updates in SP3 so I am not sure what is going wrong. Please advise as I am trying to get some progress on this much hyped feature. Thanks MVR Test Export_Rev03.vwx
Count me in Evan!🙂
Hi Henry, I use VW, C4D, Stage, Corona and PS. I am still waiting for a 'one solution fits all' but in all honesty, I have given up as I don't think it will happen anytime soon 🙂 I change my workflow depending on the client and what they want but currently I am moving more to this: Starting in VW or C4D using stage plugin. Get everything built and then render with Corona but don't use any beams. Take various passes into PS and finish. Below is an image that is about 20% Cinema/Stage and the rest is PS. This was before I started using Corona. Whilst there is no VW in this, there is nothing to say that I could not have started the build using VW. I have in fact taken the C4D and imported in VW for CAD drawings. This is now the same Cinema file with loads more work put into it, mainly from Stage.It is about 80% C4d/Stage and the rest is PS. Again, this was before I started using Corona. Some more images from the above way of working. As you can see, there is a bit of a difference but the first method was way faster that the second. The second also allows for me to start animating but that is a fair bit more work to say the least. I would say the first method gives a more "conceptual" look whereas the second method gives a more polished look. I tend to prefer something that sits between the two though! If I did these again, I would have a slightly different approach in that I would use Corona and would end up photoshopping more beams, lens flares and atmospherics in. Another big factor is what render power you have and the timeline you are up against and that will often dictate which route I take. Stage is great to get set built and nice looking renders in a very fast way. Of course C4D can run a bit slow when you start trying to render hundreds of beams though 🙂 I did try rendering in VW but had the same frustrations other people mention. The stuff Evan and Wesley show are great examples of what can be achieved with different workflows and I recommend you take a look at the images on Evans website as there are many stunning examples. Seeing these is what got me looking at Corona (Thanks Evan!) and I have really enjoyed using it....but ask me again in 6 months and it maybe that I am using Octane or Redshift etc etc! In fact, a lot of the decision to go with Corona was because of my hardware...but if Apple produce another Pro let down then I am heading to Windows...but that is another story. I would say, looking at your renders that it is definitely worth trying to take them through PS before you make any decisions about other purchases though. I think if you held back on adding in all the beams and atmosphere in Capture and tried to add them in PS you may be pleasantly surprised with what you can achieve. I hope this info helps in some way but as long as you are prepared to pick the workflow that best suits the job and be open to learn new workflows, then you are off to a good start. Cheers Simon
Hi Dave, I was curious so went back and checked my file as I am now on SP2. Here is what I found... I took the VWX file Mark supplied and added a straight piece of Tyler truss to it and updated the VPs on the SL. Below is a screen shot of the PDF produced using my Mac Pro. Specs in signature. As you can see, all is OK. I then went onto my MacBook Pro. Specs in signature. As you can see, things are still wrong. On the MBP I then rendered HL in the DL the corner block showed the simple class (blue box) but the straight piece did not and displayed correctly. See below... Both machines on SP2 running VW2019. The only difference is the OS version and graphics card. I then exported the file to VW2018 and all worked as it should on the MBP. All I can conclude is VW2019 is still not working as it should. I have included the VW file in case you want to try. @dbrumbach Hidden Line Truss_Visibility issue.vwx
Kevin, Did you read my original post? I put my post here as it only involves VW at present. I am only trying to go out of VW and straight back in using the MVR. I have not introduced any third party software yet. I have read the wiki here https://gdtf-share.com/wiki/MVR_File_Description#Node_Definition:_Matrix and can see the rotation is defined but it is either getting lost during an export or import in VW...or maybe it never existed in the first place?
