CraigN91
    6
Reputation
0 Neutral
Personal Information
  • Location
    England
  1. Forgot to mention that, i have created a symbol of the stretcher, header, stretcher which is the left side so i can quickly add these bricks in and have done the same to the adjoining bricks so shouldnt take long to piece together Craig
  2. Hi thanks for all the advice, i have attached a image of the start to the model i have created. By creating the brick size in front view then extruding to create the 3d brick, i then using the 2d polygon in plan view drew from the corner at a 5 degree angle, then extruding this i selected the two objects and subtracted solids in order to get the different angles. This is probably a very basic way to do it but seems to have worked as i am not very knowledgable with the programme! if you are wondering why the 4th course is blank i intend on having a straight course to diversify the shape. Thanks for the help everyone!
  3. Hi there i am looking to create brickwork similar to that of the 290 mulberry building, see the attached links. Does anyone know a way in which to create this style of brickwork using Vectorworks 2012 or 2011 either is fine. Thanks Craig http://www.google.co.uk/imgres?q=290+mulberry&um=1&hl=en&client=safari&sa=N&rls=en&biw=1280&bih=622&tbm=isch&tbnid=BRp_n9T6SRzmYM:&imgrefurl=http://prjctns.wordpress.com/author/gsidari/page/3/&docid=dS9_dcFFxFAOTM&imgurl=http://prjctns.files.wordpress.com/2009/10/290mulberry.jpg&w=3072&h=2304&ei=C4AtT8TlB4TR8gOXya3zDg&zoom=1&iact=rc&dur=633&sig=113337119844186801311&page=1&tbnh=133&tbnw=177&start=0&ndsp=18&ved=1t:429,r:4,s:0&tx=66&ty=51 http://www.google.co.uk/imgres?q=290+mulberry&um=1&hl=en&client=safari&sa=N&rls=en&biw=1280&bih=622&tbm=isch&tbnid=hBIPUDn2KDCbhM:&imgrefurl=http://www.designbymany.com/content/290-mulberry-condominiums&docid=V2OP1VHEkgUadM&imgurl=http://www.designbymany.com/sites/default/files/3432946718_65be673334_o.jpg&w=1024&h=768&ei=C4AtT8TlB4TR8gOXya3zDg&zoom=1&iact=hc&vpx=655&vpy=317&dur=620&hovh=194&hovw=259&tx=148&ty=167&sig=113337119844186801311&page=2&tbnh=128&tbnw=171&start=18&ndsp=25&ved=1t:429,r:22,s:18[/img]
  4. I am using VW 2011 and the latest Rhino V5, i have created an object in rhino, exported as 3DS and then Imported it to VW however it seems to be 100 x smaller than the stuff i already did in VW is there any way to get it to the right size?
  5. Thanks for the help, the screenshot is exactly what im trying to do! Will give it ago now Thank you
  6. I am creating a Dome shaped building using Vectorworks 2011, I have created the shell using the 3D Hemisphere tool however i want to cut the triangular windows out of the dome. If anyone knows how i will be able to do this as when i try it will only draw the triangle in 2d plan. Hope someone can help
