MullinRJ
1,987 -
Posts posted by MullinRJ
Hi Bruce,
I was able to duplicate 12 rectangles along an Arc, arclen=685m. Also converted it to NURBS and it still worked. Can you describe your shapes and steps?
Raymond
Thanks, Patric,
It's never as easy as it first seems. You obviously like puzzles, so, over time it will get easier. One of the joys of programming in VW is that you are manipulating images, so you can see the results of your efforts as you work, and sometimes the mistakes are more beautiful than the desired results - sometimes. I'm glad you're enjoying it.
Petri,
At times, I've used the indirect method for sorting arrays. I've not tested this, but for large arrays with a lot of data in each cell (as with a large structure), I wonder if the indirect method might be faster. If I ever figure it out, I'll let you know.
Raymond
Though not ideal, you can measure in 3D with the 3D Polygon tool. The length shows up interactively on the data bar. To get rid of the poly, you'll have to click again on the last point to end the tool then delete it.
Raymond
There is also a TextAlongPath PIO. You may need to add it to your workspace if it's not already loaded. It maintains the edit-ability of the text. I haven't used it so am not sure of all the options. Give it a try.
Raymond
Have you tried "Text Along Path" at the bottom of the Text menu? You'll need to select the text and the path for the menu to activate.
Raymond
Hi Petri,
???You almost had it. With a few minor changes it now works.
Raymond
PROCEDURE CentrePoints;
VAR
???obHd : HANDLE;
???clockWise : BOOLEAN;
???t : INTEGER;
???x, y, dx, dy, a, aR, a1, a2, r, d, l : REAL;
???x1, y1, x2, y2, x3, y3 : REAL;???{ added these to make it compile }
???v1, v2 : VECTOR;
BEGIN
???obHd := FSACTLAYER;
???GETPOLYPT(obHd, 1, x1, y1);
???GETPOLYLINEVERTEX(obHd, 2, x2, y2, t, r);
???GETPOLYPT(obHd, 3, x3, y3);
???v1.x := x1-x2; v1.y := y1-y2;??????{ make vector v1 point away from point 2 }
???v2.x := x3-x2; v2.y := y3-y2;??????{ yes, points away from point 2 }
???a1 := VEC2ANG(v1);
{??a2 := VEC2ANG(v2);}????????????????{ don't need this anymore }
???a := ANGBVEC(v1, v2)/2;??????????{ remove 180 from calculation, as v1 is now reversed }
???aR := TAN(DEG2RAD(a));
???d := r/aR;
???l := SQRT(r^2+d^2);
???{ use clockWise condition to add or subtract angle a to/from angle a1 }
???clockWise := GETOBJECTVARIABLEBOOLEAN(obHd, 652);
???if clockWise then a := DEG2RAD(a1+a)
???else a := DEG2RAD(a1-a);
???dx := l*COS(a);
???dy := l*SIN(a);
???LOCUS(x2+dx, y2+dy);
END;
RUN(CentrePoints);
Hi Patric,
???I think you should see your negative coordinate problem go away. One of the problems you were having was that you were swapping elements in the handle array, but not in the pX & pY arrays. You also needed to swap the same components in the pX and pY arrays when you swapped a handle in the H array if you wanted the handles and associated coordinates kept together.
???With an array of structures, you will be swapping whole structures from one position to another, guaranteeing that the X and Y travel with the H. This is why I proposed building the structure this way. Less things to go wrong when you finally get around to sorting the data the way you want.
Raymond
Patric, I think if you simplify your data structure, it will be a lot easier to manipulate the elements.
Start by defining a "Structure" that you'll store in an array. It should contain a handle and a point.
TYPE
???SymbolPositions = Structure
??????H :Handle;
??????P :Point;??????{ also a structure (predefined) }
???end;??????{ SymbolPositions }
Now create an array to hold these elements.
VAR
???SymPosArray :Dynarray [] of SymbolPositions;
It is not yet dimentioned, because you don't know how many elements you will put into it. This you will figure out at runtime.
You may also need to create a variable of the same type as your structure that you can hold one array element in.
???SymPos : SymbolPositions;
Next, in your main program, you need to count how many objects you want to collect data on. There are many ways to do it. I'll leave it to you to find the best way as I don't know how your drawing is structured. Often, you will select all items of interest then run you program against the selected objects, but that's only one way.
When you have the count, CNT, you ALLOCATE your array size. The array is linear, as each element is a Structured variable, but each element has two parts, actually three because the second element of your structure, P, is also a structure of TYPE Point, where P has two parts, P.x and P.y.
To access an element in your array, you can say:
???SymPos := SymPosArray[7];??????{ data stored in array position 7 - H and P}
To access the pieces of your structure, say:
???SymHnd := SymPos.H;???????????????{ from a single variable }
???SymHnd := SymPosArray[7].H; ??{ from an array of structures }
Since the point data in your structure is also a structure, acess it like this:
???SymX := SymPosArray[7].P.x;
???SymY := SymPosArray[7].P.y;
This may be a lot for starters, but it is much easier to modify your code if your variables are built in a way that makes the code easier to manipulate. KISS is my guiding light. Now, back to the big picture...
Your main program will have a format somewhat like this:
BEGIN
???{ Count your symbols }
???CNT := { some function to count them }
???Allocate SymPosArray [1..CNT];
???{ Read your handles and XY values into the array }
???SymHnd := { Get your first handle }
???for I := 1 to CNT do begin
??????SymPosArray.H := SymHnd;
??????GetSymLoc(SymHnd, SymPosArray.P.x, SymPosArray.P.y);
??????SymHnd := { Get your next handle, usually with NextSObj(SymHnd); }
???end;
???{ Now you can sort }
???{ I would try the VS command SortArray() here, but you may have to do it manually. }
???{ To sort on both X & Y variables, you need to sort your primary variable last. }
???{ The rest of your program... }
END;
Have fun,
Raymond
No, but it has been wished for, for a very long time.
Raymond
Hi Michael,
???Yes, there is. My website is quite lacking, but the Reshaper software is up to snuff with VW 2009. If you want to try a DEMO, send me the last 6 digits of your VW Serial Number and I'll send you the software and a KEY. It's free for 30 days. It will make positioning of 3D objects quite easy, compared to the confusion you are probably having.
Raymond
Actually, it says you have 16,777,216 TB, meaning you are looking at ~16.8 Million Terabytes, or 16 Exabytes. (exa = 10^18)
That's a BIGGA BYTE. (Not Normal)
Raymond
The toggle for "Snap to Loci" may not be in the VW Prefs window anymore, but you can still toggle it On and Off with this one line VectorScript (VS).
SetPref(5, not GetPref(5));
For the moment, I'll assume you know how to employ a VS. If not, start here: How to use a VectorScript
If you still need help, write back and more instructions will follow.
Raymond
Would it help if the origin was 3D?
???I think it would help a lot of people if the User Origin was completely definable as an XYZ offset from the Absolute Origin. But, more than that, if all the readouts (OIP, DataBar, Floating DataBar, Rulers) showed the same coordinates it would make huge difference in how people perceived working in 3D with VW. Being able to select whether the display showed Absolute or User coordinates would be icing on the cake, but this is all just my opinion.
Raymond
Hi Mike,When you move the 2D origin the Rulers move with it. The 3D Origin remains where it was.???I think the second sentence is not entirely true, but depends on what you use as your basis of reference. The problem is that there are too many bases that conflict with each other; Rulers, Data Bar / Floating Data Bar, OIP, Pink Drawing Grid; and no way to force them to be consistent. This is a major shortcoming in the User Interface. An option to align them, to show or hide the shift, would be a huge step forward in the "Ease Of Use" category.
???The OIP does show an origin shift in 3D views, but not for every 3D object. Check out 3D Polygons and use the OIP to investigate the coordinates of the vertices; or place a Sphere, or 3D Symbol, in a drawing and the OIP will report its center with the origin shift in all views. The X & Y values show the shift, while the Z value remains fixed.
???This is the philosophy I have taken with Reshaper, to show the XY origin shift in all views, as it is what the user is most likely expecting to see. Additionally, Reshaper also reports 2D & 3D positions side by side, allowing the user to work in the reference frame that is most meaningful at the time. Keeping it consistent was one of the hardest things I have ever achieved.
Raymond
Hi Michael,
???I have not seen this. Could you post a file that shows this and outline the steps you used to see the shift in Z?
???In developing Reshaper I do extensive testing of 3D objects in 3D space; on Design Layers, in Symbols, in Groups and other container objects, all with and without a shifted origin. In all that time I have not seen the Z value move with respect to an origin shift. If it is happening, I would love to see a file that shows this.
???When you say the Z value moves, are you referring to the coordinates reported along the bottom of the drawing window when you hover your 2D or 3D cursor over an object? Or, are you using the OIP to report XYZ values? The data display bar at the bottom of the drawing window and the Floating Data Bar do not show origin shifts in 3D views. It's very confusing, and I consider it a bug, but it's been that way "forever". The OIP, when it does show position, shows the origin shift in a fashion more consistent with the user's expectations. On the other hand, Reshaper shows everything you want to see, the way you want to see it. (Couldn't resist.)
???To test coordinates and displayed readouts, I suggest placing 3D Loci at known points and use them to gauge where things are.
???As to your wish, it's a popular one.
Raymond
FM5. I would like that, thank you. I sent you an email at a welho address. Did you get it? If it is no longer valid would you send me a current address?
info@siriussolutions.net
I am not a power user, nor even a regular user. I have an older copy of the program and have set up a database or two with it over the years. I still use FoxBase for my DBase needs. I know, I show my age and my willingness to adapt.
I think I may have one around here you can use.
Let me see....
You should try it Mr. Mullin . . . .
LOL, I should, I do, but right now it is not working so I am working on it.
Petri, That should be easy enough to code.
There is a slight difference in how the two tools work that in my mind would make them a little difficult to merge. The 2D Move tool moves objects in the screen plane, both 2D and 3D objects alike. X offset means move to the right or left, while Y offset means move up or down, all relative to the current view.
The 3D Move tool moves 3D objects along the absolute X Y & Z axes, regardless of the view. This is where I've stopped thinking how to proceed. Any suggestions how it should work as one tool?
Pat, You're too fast for me...
Hi Petri,
There are two undocumented commands, but they work on individual objects.
HScale2D(h: HANDLE; centerX, centerY, scaleX, scaleY: REAL; scaleText: BOOLEAN);
HScale3D(h: HANDLE; centerX, centerY, centerZ, scaleX, scaleY, scaleZ: REAL);
HScale3D does not work for Groups of 3D objects.
For 3D Groups I scale from the top with HScale2D using Scale_X and Scale_Y, then from the front using Scale_X=1 and Scale_Z. A Redraw will be needed to see the results.
HTH,
Raymond
Try:
=ROUND(A1+0.499)
This will round 3.001 up to 4, but 3.0001 will round down to 3. If you want more precision add more 9's after the 4. It's okay to have more 9's than you need, but having less will yield incorrect results.
HTH,
Raymond
Renderworks - YES
Vectorworks - NO
Duplicate Along Path broken in Vw2009
in General Discussion
Posted
Hi Bruce,
???I get the same result as you, but only with a LINE as the path. I used an ARC twice as long and didn't have a problem.
???I can see no reason why it shouldn't work. It's a BUG.
Raymond
